McCormick 3 PT stuck
/ McCormick 3 PT stuck #1
kl9
La Crosse, WI
Deere
Pretty straightforward. I don't know a lot about tractors, but the 3 pt is stuck in the highest position (with an attachment on it so it isn't a weight issue). I believe there is plenty fluid in it. Any suggestions? Someone told me to change the hydraulic filter first. I hope it isn't the hydraulic pump.
/ McCormick 3 PT stuck #2
Uncertain about your McCormick but most 3 points are gravity down, power up. I did say most, but not all. Most of ours do not even require the engine to be running to drop the 3 point. Two of ours, however, have electronic 3 point and need to have at least electric power to the control in order to drop, but at that point those 2 drop under gravity, not hydraulic power. Is yours electronic control or does it have a mechanical linkage to the control valve?
Good question. I'm not sure as I'm going to be borrowing the tractor from a friend. I could look more into that. If it isn't going down on its own I might be missing something from an electronics perspective?
/ McCormick 3 PT stuck #4
Possible the needle valve to control the drop rate is screwed all the way in?
/ McCormick 3 PT stuck #5
Any idea of the model number?
/ McCormick 3 PT stuck #7
It appears the X10.50H is a Kioti DK500se in red. Maybe those guys can help.
Guys?
I figured it out. It was the needle valve being screwed all the way in.
/ McCormick 3 PT stuck #9
Thanks for the update, easy fix!
Correct. I was trying to say I confirmed that was the issue.
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
3268 (A63117)
3268 (A63117)
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
