Yanmar 150d workshop manual/ loader manual
/ Yanmar 150d workshop manual/ loader manual #21
/ Yanmar 150d workshop manual/ loader manual #22
Very possible the YM150 is a cobbled together tractor as stated in Hoyes avoid list. It clearly starts life as a YM1300D.
/ Yanmar 150d workshop manual/ loader manual #23
Who do you suppose made up the YM150D hood banner and why?
/ Yanmar 150d workshop manual/ loader manual #24
Don't know but Hoyes shows a YM150 as an avoid tractor as it is Korean made according to them but in reality it is a YM1300 which is a Jap grey market in this case.
/ Yanmar 150d workshop manual/ loader manual #25
And you know this how? This tractor has an external air filter. The YM1300 does not.
/ Yanmar 150d workshop manual/ loader manual #26
And I think the external air cleaner uses a different intake manifold, if its like my similar YM186D where the manifold has a flat flange where it emerges from the side cover and the donaldson filter is bolted to that.
So it appears to me this might be a YM1300 with YM155 components used as needed to overhaul it. Who knows where the YM150 hood decals came from, maybe Ebay.
/ Yanmar 150d workshop manual/ loader manual #27
I'm with Normde thinking maybe the Korean YM150. No reason to have a YM150 hood decal or where would it even come from?
/ Yanmar 150d workshop manual/ loader manual #29
On the Trans.13000-xxxx or 1300D-xxxx and stamped which should be correct. But he also said there wasn't a Ser. # Plate on the Eng. Block. With that being gone who knows what Eng. was used or what all was cobled together. It's really sounding like a Frankenstienermar.
Well am going to call a 1300D for now. Next problem is the axle leak on the front axle gear case. Does anyone have anything to share on changing the axle seal ? (should I start another post with a different title?) Got a seal from aftermarket seal and hydraulics supplier.(SKF), but have not been able to get a workshop manual, only have the parts manual for 155D, which looks identical for front axle so any help appreciated. Boltz
/ Yanmar 150d workshop manual/ loader manual #31
I also just required a yanmar ym150d. Any help on info. About it would be greatly appreciated
/ Yanmar 150d workshop manual/ loader manual #32
I have just acquired a ym 150d and can't find anything on it.
/ Yanmar 150d workshop manual/ loader manual #33
Welcome to the forum. :welcome:
Are you sure it is not a 1500? Pictures maybe? After reading back through this old thread I see it could be a 150. No doubt a rare one if it truly is. Have you read through the entire thread?
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2026 Electric Tricycle (A64194)
2026 Electric...
