/ Harbor Freight Tools that don't suck #5,583
Gosh some of the HF reviews are scary :eek:
Modifications may be necessary :laughing:
I guess it all depends on what your lifting. :D
So I just spent some time online looking at bike lifts. The choices are pretty limited it does seem, either HF and similar branded variations or the bigger and better lifts (but of course much more expensive).
I was searching to see if I could find the "BlackJack" bike lift I have had just about 20 years now but no luck. :(
But it is virtually identical to a PitBull bike lift. I got my lift at Laconia Bike Week with special show pricing. The sales pitch was pretty impressive a dressed Harley bagger fully lifted and a person hanging off of the side while another moved it around. I wanted the xtra height for easily removing the rear tire with a full fender. Ahh to long for the days of hinged rear fenders.
Overall the floor frame on these are 42" long and 24" wide and 4 inches closed, and the frame contact point width is 16 inches and can lift almost 24inches high where as the import versions are only 32" long and 16" wide, a 14" frame contact width and 16 inch lift. The length of the contact arms are both the same @ 12".
I have my shovel on it right now
I also see some of the newer model motorcycles have issues usings jack lifts without shims and adapters or some sort of modification. //
While Harleys may fit on those lifts, most sportier bikes cannot be used with them as that's where the exhaust system lives. * Paddock stands are used, which have plusses and minuses. HF makes one for the rear wheel. Don't know anyone that uses one. Their dirt bike stand is OK.
I have a Condor wheel chock and it's beautifully made of aluminum. They're also $200. When I had to transport a second bike in our van, I bought the steel HF wheel chock, which is clunky, heavy, and $70.
* Of course if you buy a British bike, they don't leave mounting holes to put spools [except through the rear axle]. So while the front Woodcraft works slick, to take both wheels off at the same time you have to get creative.....Being creative with a 400+ lb $10,000+ motorcycle is not as fun as it sounds.....
/ Harbor Freight Tools that don't suck #5,584
I'm considering a couple of their 44" tool drawers. Anyone with good or bad experience with them?
Roller Cabinet - 44" Red Rolling Tool Cabinet w/ 13 Drawers
I'm think of installing 2-3 of them side by side, one wall of shop, with a work surface on top to time together. Remove side handles so they can be pushed together.
Something like this.
That picture has about put me over the edge for buying a bunch next time they go on sale.
BUT I've four "workshops"
465241d1460996915-harbor-freight-tools-dont-suck-outside-shops-jpg
I've managed to line most of the interior walls with pallet racking
465239d1460996656-harbor-freight-tools-dont-suck-8x6sam_0727-jpg
465240d1460996656-harbor-freight-tools-dont-suck-8x6sam_0773-jpg
And I've got about 100 linear feet of what I use for "project surfaces", all have 3/4 PT plywood topped by 3/4 Masonite, and as in the pics the project surface level is about waist high. Clearance under the beams is 31.75 inches for about half of them, and 36" for the rest of them.
This is where the BUT comes in, reading the HF web site the height of the 44" (and up) wide cabinets is 40 inches plus. Not enough clearance :(
I would really like to be able to put a bunch in and still have the capability to roll them in and out from under the project surfaces. All the shops have nice concrete floors :)
However I've got one of the old HF 2 piece 27" wide combos on casters and the base unit on that is only about 28 inches high.
So my question is - does anyone know of similar rolling cabinets that are fairly wide but not higher than 36"? Northern Tool sells a 41" wide that's 38.75 inches high, close but not low enough.
I'd prefer NOT to buy a bunch of 2 piece unit just so I could slide the lower piece under.
/ Harbor Freight Tools that don't suck #5,585
Put on smaller casters?
/ Harbor Freight Tools that don't suck #5,588
Arrived today via email
2016 CHEVROLET (A59823)
2016 CHEVROLET...
Rooster Weathervane (A55853)
Rooster...
2010 Cadillac SRX SUV (A59231)
2010 Cadillac SRX...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
