Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,761
Agrisupply will not have the TM1900 in stock until late May. Shipping to CO will be another $501, so I am officially looking for good alternatives.
I haven't seen anyone actually buy and review the WoodMaxx. I am wondering how any of these compare to the Betstco ones on ebay? What do people think about the different levels of Value Leader models I see there?
EF vs EFC, vs EFCG, etc? And which one would be closest to TM1900?
I was about to pull the trigger on the WoodMaxx flail if I hadn't found my Maschio. You can get an awful lot of mower with the WoodMaxx and the shipping is "free".
Keep in mind that the WoodMaxx and the EFCG are HEAVY. I hooked my mower (similar in weight to those two) up to my old tractor to move it around (Bolens/Iseski 27hp) and the 3 point was straining to lift it. I think it would have been fine for mowing since the mower rides on its back roller, but something to consider depending on your tractor.
/ Let's talk flail mowers #2,762
My JD 4410 hydro is 35 HP and 28.5 PTO. Has anyone used it with the 73" Caroni TM-1900? It is right at the cutoff of HP.
/ Let's talk flail mowers #2,763
My Kioti DK40se has about 33hp at PTO. I run my mower routinely at 2100rpm which is well below PTO of 2500. I wouldn't hesitate for a moment using the TM1900 on a JD4410.
/ Let's talk flail mowers #2,764
I run my old 917 (think its over 72") behind my L3200 (32hp, 25PTO if I recall) just fine. The nice thing about a mower that is to wide is you can just slow down to make up for lack of HP if needed.
/ Let's talk flail mowers #2,765
My Kubota 3450 is 37hp and runs my 73" Caroni like a dream, you should have no problems whatsoever!
/ Let's talk flail mowers #2,766
Good reading, quick question:
Would my Kioti CK 25, not HST, be able to handle a 6 ft Alamo flail mower? PTO is approx 20 HP.
/ Let's talk flail mowers #2,768
I'm looking at a used one that is 6 ft. I guess I should hold off and wait for a smaller one. I sure dont want to overload it. I should have mentioned, I would use it for mowing. My 2 acres is cleared and we keep it mowed with a finish mower so it wont be used for anything big. You think it could handle that?
/ Let's talk flail mowers #2,769
Yes, it would probably be OK under those circumstances. Straight mowing shouldn't be a problem. It is only when you are breaking in new ground that they have to work hard.
/ Let's talk flail mowers #2,771
Cool. I think I may have to jump on the band wagon. The biggest reason is debris. I am concerned with the finish mower that I'm gonna hit one of the kiddos when mowing. Of course I have asked them to stay clear, but still, projectiles can travel long distances.
/ Let's talk flail mowers #2,772
Exactly why I switched to flail. I also have a medium duty bush hog but use it only in remote locations. Too many homes and kids within range of bush hog projectiles in the fields I now mow only with flail.
/ Let's talk flail mowers #2,773
I found a used Mott 72" flail near me. It looks to be in decent shape. I'm going to check it out on Thursday. Anybody familiar with this unit or vintage?
/ Let's talk flail mowers #2,774
Hi, I'm looking to buy a 5' Flail mower to finely chop up cover crops and agriculture crops. I have been doing some research but can't seem to figure out which blade type (duck foot or Y blades) would be best for finely chopping up the vegetation.
Also my tractor has a clutch / gear drive trans where the PTO disengages when the clutch is depressed to change gears. Having never mowed with a PTO mower before, what procedure do you guys use to engage the mower and get up to the proper pto rpms?
I have read some flail mower specs state the gearbox has a "internal over-running clutch" . Is this something I would need given my tractor's gear drive trans?
Thanks for any advice.
/ Let's talk flail mowers #2,775
I think the Y blades are probably better for mulching. The "duck foot" style is generally used for finish mowers though it should be clear that either type of blade will get either job (finish or mulching) done.
To engage the mower, lower RPMs to near idle before reengaging the clutch. Usually need to be a bit over true idle or the tractor might stall but not much over idle. Certainly not at PTO speed or anything close to it.
Sorry, I don't know what an internal over-running clutch is. Maybe one of the other guys can help with with.
/ Let's talk flail mowers #2,776
1) I would get the Y blades
2) Disengage the PTO; Hook up the mower; Raise the mower (assuming your 3pth works with the PTO disengaged); Put it you tractor in gear and head to your first pass. Before you get to the start point, engage the PTO and bring the engine RPM to PTO speed the lower the mower and cut away. Just remember the flail is not a brush hog and you will be mowing between 1 an 3 MPH - find the right gear and you shouldn't have to use the clutch.
[edit] - I see Island doesn't like to engage the mower above idle. I agree if your engine PTO speed is 2000+. However, since my tractor's PTO speed is 1200 engine RPM it really doesn't make a difference fo me
3) An overrunning clutch is usually attached to the PTO Shaft. Unless your tractor is rated at a higher HP than the mower gear box or the flail has only one belt you shouldn't need it.
Just my 2¢ - YMMV
/ Let's talk flail mowers #2,777
You will need the overrunning clutch, either built-in the flail gearbox/driveshaft or a separate clutch attached to your pto shaft. Without the overrunning clutch, the back half of the tractor is separated from the engine by the clutch and all it does is uncouple those two devices. When you push in the clutch to stop forward motion, the spinning flail rotor will continue driving the transmission forward because it is all connected via shafts and gears. An overrunning clutch will allow the transmission to stop while the flail spins, to switch gears or reverse and will re-engage the transmission when it comes back up to speed. Get into this situation one time, with the flail pushing the tractor forward, and you will be looking for a clutch.
/ Let's talk flail mowers #2,779
Not trying to start a pi$$ing contest but I just bothered to look up your L3800 on TractorData and and all models of the L3800 have a "Live PTO" not a "Transmission PTO". That means it has a two stage clutch that allows you to change gears by pushing the clutch pedal down 1/2 way while the PTO continues to spin. Pushing the clutch all the way in and the PTO is disengaged. Therefore if you want to stop just push the clutch in all the way and the mower cannot push you forward.
This link explains the different PTO types:
TractorData.com - Power Take-Off
/ Let's talk flail mowers #2,780
I think the HSTs have a transmission PTO. The HST negates the bad behavior & need for overrun clutches. Think the gear machines are live.
At any rate I have a L3200 HST & no issues. Really the only reason for the clutch on my machine at all is engaging the PTO. Don't believe the gear machines have any bad behavior requiring an overrun clutch either.
JOHN DEERE 5510 TRACTOR (A64278)
JOHN DEERE 5510...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2015 Freightliner (A64119)
2015 Freightliner...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
