Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,022
gg
/ Grappling fun - A Picture Thread.... #1,025
Don't you hate it when you're brushogging and find a nuisance stump? No problem when you have your grapple!
Step 1 - Quick grub and gentle push
Then just pop it up and away you go to the burn pile! (Darn things are like icebergs - always more than meets the eye!)
/ Grappling fun - A Picture Thread.... #1,027
That's a nice setup, Snowback!
Thanks dragoneggs! Enjoying the heck out of it so far. Really capable machine and that cutter and grapple took some abuse today. (Tractor too - that type if tract is like Lewis and Clark type work.) I've only had the OEM bucket on one time to move some yard mulch back at the house. I'm sure the grapple will get a rest someday...
/ Grappling fun - A Picture Thread.... #1,028
I'm impressed with the whole set up. Those look like some serious logs your machine picked up.
Thank you !!!
Bucket grapples are treated like second class citizens here but they really do have plenty of capability especially if care is taken in the way they are mounted and they are combined with a tooth bar. They excel in utility and are a blessing for us guys with older tractors that lack quick attach plates and have pin-on buckets.
gg
/ Grappling fun - A Picture Thread.... #1,029
Thank you !!! Bucket grapples are treated like second class citizens here but they really do have plenty of capability especially if care is taken in the way they are mounted and they are combined with a tooth bar. They excel in utility and are a blessing for us guys with older tractors that lack quick attach plates and have pin-on buckets. gg
No! Bucket grapples are not second class citizens in Grapple Nation.... They are simply less common. Most 30+hp tractors these days have SSQA and it therefore makes sense to simply get a regular grapple as a second FEL implement, but for someone with a pin on standard bucket, adding a grapple thumb to that bucket makes all the sense in the world.
/ Grappling fun - A Picture Thread.... #1,031
Fun times cleaning up this week. Piled a bunch of big logs for later burning, and burned a bunch of small stuff and stumps that I uprooted. What a great tool!
/ Grappling fun - A Picture Thread.... #1,032
Fun times cleaning up this week. Piled a bunch of big logs for later burning, and burned a bunch of small stuff and stumps that I uprooted. What a great tool! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464791"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464795"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464793"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464799"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464801"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464802"/>
Do you get nervous burning that close to the tree line?
/ Grappling fun - A Picture Thread.... #1,033
I have seen several threads saying their tractor just quit running or a hydraulic hose burst.
Do you have insurance that will cover the tractor when it burns up?
/ Grappling fun - A Picture Thread.... #1,034
It would be a bit unusual for a hydraulic hose to burst while dumping a load. I've busted one on my grapple but it was when I rammed the grapple into brush and some debris snagged the small hose right at the cylinder attachment.
Sure, tractors can occasionally quit for no reason but again that is pretty darn rare. I stall mine periodically when mowing or digging but I've never had it stall when simply dumping a load or reversing.
/ Grappling fun - A Picture Thread.... #1,035
Well that one is a pretty small fire, I wouldn't make one of those 20 foot mounds that close though. I think he would be safe as long as the fire doesn't get much bigger. Assuming damp conditions.
/ Grappling fun - A Picture Thread.... #1,036
Do all the bucket grapples pictured use/require another hydraulic circuit, or 3rd function?
Has anyone bought and used these: BC-3: Westendorf Attachments for Tractor & Skid Steer. ??
They don't require any hydraulic modifications for use, and are made for pin-on buckets, but I wonder how well they would work.
Thomas
/ Grappling fun - A Picture Thread.... #1,037
That's the deal k0ua - you nailed it. Thanks also to the others above with their concerns as well. I understand and appreciate it - for both my safety, and for the woods around our place as well. Probably not the most cautious approach dumping limbs onto fire, but I was satisfied that appropriate precautions were taken in case of tractor problem or rogue wind storm.
1) It had rained an inch or so the prior day and a half - nice soaker came through SE Texas and it was drizzly for the first half of week
2) Humidity was off the charts and it was overcast - no measurable wind as well
3) Only smaller stuff and the odd medium size stump were placed in this fire
4) Fire was never bigger than what you see in the original picture as it burned down as fast as I could collect a new load of tops, limbs, and large pieces of mulch debris
5) Out of frame on the right was my dirt bucket with a fire extinguisher and rake/shovel - (Worst case scenario I could have pulled that fire back by hand and put it out with dirt in conjunction with the extinguisher.)
I'm sure it was wet enough that I could have built a big log pile and lit if off. In that event I would not touch it with tractor until it came time to push in stragglers at end of day. I respect fire more than most after a good number of close calls and hard lessons while younger and "inquisitive". :D (I will only share those over a beer or cold tea.) At the end of the day I like to document 1% of what I do each work day, and I enjoy sharing my efforts and learning from all y'all as well! Thanks for the dialogue that makes me think.
Now - here is that exact same spot about five months ago with a slightly bigger fire. :eek: (Posted a while back as well.) This guy was far more of a go getter than I will ever be! These two pics are sequential and no trick photos. Git 'r done! If you want A+++ land work around Houston you should call Keys and Sons!
/ Grappling fun - A Picture Thread.... #1,038
I only ask because I will have to burn. I plan on having about 100 feet from the nearest vegetation, and digging a good hole to do the burning in.
/ Grappling fun - A Picture Thread.... #1,040
That pile and burn spot is about 75'-100' away from the trees - wish it were more, but I have a larger open area where bigger burns can be done. Still lots of trees and fuel around, so conditions are key when we burn. I will soon be completely cleaning out fuel and deadfall for another 100' in all directions from this spot. On the day of this burn it took some nursing and my Canadian Boy Scout firestarter kit to get this one going.
Wow, firenado, cool given, the low risk for wildfire that you cite.
My small burn was this week with nice moist conditions and no wind. It was a low risk fire in a very low risk environment. That picture where the crew was working and that firestorm took off was last year and had a much bigger fire going in a little less than ideal conditions, but still only a few days out from a major rain event.
The key in my opinion is to keep burns very small and controlled with good weather until you are ready for a big pile cook off. For the latter you should watch for a good rain event, dig a hole if possible, and make sure there is little to no wind. Those guys who have big open fields/pastures definitely have an advantage on ability to burn at their leisure.
JOHN DEERE 6420 TRACTOR (A62130)
JOHN DEERE 6420...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
2018 CATERPILLAR 289D SKID STEER (A62129)
2018 CATERPILLAR...
UNUSED PEANUT WAGON QUICK HITCH (A62131)
UNUSED PEANUT...
2022 Kubota Z422-54 Zero Turn Mower (A63118)
2022 Kubota...
2009 International 7400 Service Truck with Crane, VIN # 1HTWGAAR19J160617 (A61165)
2009 International...
