Grapple ETA Root Rake Grapple
/ ETA Root Rake Grapple #1
Ken Mac
Pell City, Al.
Kubota B26 and New Holland TN75
Hey, Folks. My first post here, but not my first rodeo, so to speak. I have ordered the above grapple instead of the Wicked Grapple. Anyone here have this grapple and are you happy with it? Any disadvantages or advantages of this type?
/ ETA Root Rake Grapple #2
I prefer longer bottom tines for stacking material by hand as well as the ability to nab more material per turn.
In two hours I made an 8' x 20' burn pile today using ETA's original Wicked Root Grapple.
Other grapple styles are flat bottomed that allow them to work like a land plane as well as the ability to scoop under piles and then lift up rather than rolling over the top like the Wicked Root or Root Rake grapples.
/ ETA Root Rake Grapple #3
Is this the one? Let us know how it works for you.
/ ETA Root Rake Grapple #4
I have also been looking at this grapple , I just wish they offered a dual lid version of this , I actually just asked about it on the everythingattachments sticky thread
/ ETA Root Rake Grapple #8
Yep, that's her. I chose it because Ted was having a hard time releasing a load of brush in his trailer with his Bobcat tractor. My B26 is a little larger, but not much. I think it will do what I need without that aggravation.
Yep, I have thought about grinding down the teeth on my Monster Grapple, I have never used it for pulling vines or small brush.
Their Wicked Root Grapple that Ted was using in the video, has a more aggressive tooth shape than the your root rake.
I actually bought a used Blue Diamond grapple, but it was way too heavy for my little Kubota, even though it was useful. I experienced the same problem of getting loose from the load with it. I thought about putting it on E-bay as a battleship anchor, but sold it to a friend who has a Case skid steer.
/ ETA Root Rake Grapple #10
Yep, same here. Fortunately at max dump on the V417, the tines are nearly vertical, so I just shake it until all the brush falls out.
/ ETA Root Rake Grapple #12
That's a nice piece of iron you have there. Very handy, I bet.
Thanks.
Yep, very handy. With the front axle fastened to the frame and the pivoting rear axle, it is very stable for loader work.
And with the SSQA and 22 gpm aux hydraulics on the boom, running a 7' brush hog out front is super handy :thumbsup:.
Just to update on Grapple......Picked it up today from freight terminal and got her home. I have to change hydraulic couplers, but initial look left very positive impression. Welds look good and seems to be well made. It must have set outside for a while though, the paint is very dull. I'll update again later in the week when I get to use it.
I was able to use the grapple some today and I think I made the right choice for what I'm doing. It seems well matched with my B26 and works very well. The only complaint is that all 4 cylinder lines were loose.....very loose. But all is well now. I'm happy with it.
/ ETA Root Rake Grapple #15
Being as you're new we can cut you some slack but generally we require pics or it didn't happen. ;)
Matt
Matt
I appreciate the slack GWH. I'm fortunate to get logged in and find my way around this techno world. I'll try to figure the picture thing out, though. Btw, Love the grapple more each time I use it. I've been clearing fence rows and such lately, and today I piled a bunch of them much easier than I could with the 4-in-1 bucket.
/ ETA Root Rake Grapple #17
I would like a grapple, but with longer bottom teeth than the rake.
My thinking was to ensure I could dump a load of brush, etc. at full lift height. I saw issues with small tractors being able to get away from the load at full lift with long tine grapples. I loaded my dump trailer 4 times today with various types of debris and had little trouble dumping loads. Each type has certain advantages and disadvantages. I like this type for my needs.
/ ETA Root Rake Grapple #19
Hey Ken,
I'm also interested in this model, I believe it will be better at raking roots out of food plots and the firewood work I do.
Keep us updated with photos and or videos of your experiences if possible.
/ ETA Root Rake Grapple #20
I'd love to see some photos of this thing in action also
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
(APPROX.36) 1 1/2"X5"X33" CHANNEL IRON (A62130)
(APPROX.36) 1...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
DYNAPAC CA250D SMOOTH DRUM ROLLER (A62129)
DYNAPAC CA250D...
