Chipper pto driven wood chippers
/ pto driven wood chippers #1
gravelman
NH
Kubota 2650
Hi folks...gravelman here...im thinking of getting a 3pt ht pto wood chipper. burning is a pain nowadays. any recommendations. It would be on my Mahindra 55 hp tractor Anything over 6" or so i use for fire wood or fire pit so nothing big would be needed. Thanks much
/ pto driven wood chippers #3
You may want to look at WoodMaxx- they have some excellent reviews and a decent price
/ pto driven wood chippers #4
Hand feeding limbs gets old really fast... I don't have a hydraulic feed but pretty sure I would like one. Mine just drops the chips to the ground. They pile up pretty fast and clogs up the discharge area. Get a blower on which ever one you buy. Good luck... it's nice to reduce a brush pile, but then you have a pile of chips you need to deal with. Good for walking paths.
/ pto driven wood chippers #5
I am also looking at the hydraulic Woodmax. The reviews are good, the price is right, and there are some video reviews online.
ok, i will do that..and thanks very much
ok, thanks for that..very much
excellent...thank very much
/ pto driven wood chippers #9
Over the years, I've owned several different chippers and also shredders... These days, I just make brush piles for the animals, they rot down quite fast, so I just keep adding to the top of them...
It's just so much FASTER and much easy to pile the brush on my tractors pallet forks, then drive to the pile and dump it on top...
SR
/ pto driven wood chippers #10
I needed a woodchipper in 2012/2013. Rental would be about $600/week. Bought a Jimna
Thread here
The Woodmaxx base model looks identical. Since Ranch Hand Supply seems to have gone away Woodmaxx looks good.
SR
Even better just let the tree die and rot in the woods. That's even EASIER.
/ pto driven wood chippers #11
Here is my opinion for what it's worth. I own a chipper and I have no brush piles anymore and don't want any. I dislike burning brush and a chipper makes chips and those chips always find a place in the flower beds or around trees.
Having said that, I would NEVER get a gravity feed unit like a Wallenstein, thats a PITA waiting to happen, besides they are overpriced for what they are. So are the Woodmax hydraulic feed units plus you have the extra mechanicals and hydraulics involved (they have their own pump, storage tank and drive motors, all at some point will require maintenance and or replacement). It's a chipper, it's a part time tool. I have a huge wooded parcel and I might have my chipper on my tractor a week each season, maybe....
I bought a Jinma mechanical feed 8" chipper, Woodmax sells it as their 'economy' chipper for much less than the more complex hydraulic feed ones. Mine handles an 8" hardwood log, no issue though I only chip up to 2" because everything else goes to a guy who splits the stuff and sells it to campers (I don't heat with wood and don't want to).
I've owned the chipper for 5 years, used it hard and have has no issues other than I resharpen/replace the knives yearly, I happen to own a machine shop and I jig the knives on a surface grinder and sharpen them properly because the knife angle has to be held to 27 degrees for proper feeding, something you cannot do manually. The big issue with any chipper not operating properly (stringing chips / clogging and overworking / slipping, breaking drive belts) is dull knives.
The Jinma / Woodmax economy chipper is a mechanical drive infeed roller setup just like the hydraulic drive but with a right angle gearbox and driveshaft driving the infeed rollers, really no difference. It pulls in the branches at the correct feed speed, in fact, I've chipped a large amount with mine (dumptruck loads) and I've never had to replace any driveline components, just grease the driveshaft and pillow blocks on the PTO input end and the drive rollers.
I highly recommend it as a part time (which is what you need) chipper. All the Woodmax chippers are Chinese anyway. They come over in a container from a Chinese factory, just like their backhoes and all their products. Why pay huge bucks for a hydraulic unit when a mechanical infeed works just fine.
I'm here to tell you it does, in fact, mine is on my Kubota right now, I'm doing spring cleanup.
Get the least expensive Woodmax or shop for a Jinma (same thing) from Circle C tractor. Mine is bullet proof. BTW, Circle C sells all the replacement parts, knife sets, belts, infeed parts and sheet metal, just like Woodmax. No difference except price.
Thats my 2 cents. Take it how you want to, it's your money. No, mine isn't for sale either.....:D
/ pto driven wood chippers #12
That wouldn't be "better" for me... I like to harvest the "saw log" out of the tree, then there's fire wood in the tree too! Then there's trimmings off my orchard trees and.................
BTW, I don't burn ANY brush piles or leaves either...
SR
/ pto driven wood chippers #16
Having owned a manual feed chipper I personallly would skip it and get a hydro feed. The manual is a pain in my opinion and sold it after a while. Yes, they are cheaper but small stuff does not always feed and just jumps around, big stuff will slap you silly depending on how it is catches. The hydro is a much smoother operation and you can just stick a limb in and walk away to get the next one. They adjust if the chipper starts to bog down and really don't have much extra maintenance - they do have a drive motor but other than that it is a tank, roller and a few hoses. Not much more of a big deal than log splitter.
/ pto driven wood chippers #18
My reasoning for a hydraulic drive is very simple. I have run large commercial aborist chippers extensively. There is no comparison in safety and productivity between the "chuckum in there" and the hydraulic feed units. Anyone can go cheap and run some ol crappy old technology stuff but why? The hydraulic feed drum systems are superior to the old ones period. The Woodmaxx unit to me seems well built and they seem to have excellent customer support.
I could go on about ease of cleaning the units out,having a chip that can be used for some thing, the ability to back some piece out if need be and last but not least the ability to save your butt with the panic reverse bar. I would NEVER run some old unit without a hydraulic feed, ever. To each his own. Go git one. gee haw whoa, git.
/ pto driven wood chippers #19
None of that is germane to a limited use situation (as I thought). The mechanical feed works just as well for a limited use machine as the much more expensive hydraulic feed.
I don't need to 'git' one, nor do I want one.
The OP wanted opinions on consumer grade pto chippers, not an arborist unit. If he wanted that, I'd steer him toward a Chipmore with hydraulic infeed staged to the engine load verses infeed speed. A mere 30 grand should get you in the door for thew base unit.
For the life of me, I don't know why threads like this get posted with 'pie in the sky' comments with no real bearing on the question asked.
/ pto driven wood chippers #20
As do I, in fact I "also" completely cover all of my gardens with the hay/grass I cut. Here's my front garden getting "mulched in",
Glad I don't have that problem... but then again, we do enjoy seeing the deer daily...
BTW, I bet you spend a LOT more on fuel "chipping" than you ever will on "pest ammo"! lol
SR
Probably more on fuel than rounds. It certainly don't strain the tractor, I'm running a 100 pto tractor on the chipper, or about 3 times rated input ponies. Never even spools the turbo up. I have a wife to contend with and she don't like the piles of brush (my main impetus for getting a chipper in the first place). A happy wife is a happy life.
You garden is maybe 1/4 the size of mine. Mine 'grows' every year or so it seems. We give a lot away and I have a good friend who has a vegie stand in the city. I grow zuchini (wife beaters) and sweet corn for him all the time. This year he's put in for Brussels Sprouts. I make a little on the produce, about enough to cover my sweat equity. I happen to like winter stored carrots, potatoes and onions, frozen stuffed peppers and frozen shelled corn, cauliflower and sprouts to go with my elk, duck and deer meat.
The wife's draft horses make plenty of poop and she beds on straw I bale and hay I bale so feed is of no consequence and the bedding goes in the garden too. This is excellent potato and carrot ground. Last year I dug at least a ton of spuds and we had 5 bushel baskets of layered carrots in the root cellar. I gave away at least 2/3rd of the potatoes to the family, they all like the 'home grown' versus store bought vegies. I just need to figure out a way for them to come help....;)
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
KUBOTA TE6583T - 6 BASKET HAY TEDDER (A64278)
KUBOTA TE6583T - 6...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A67148)
2024 SILVERBACK...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
