If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #351
No there is not. There is no "tow" or "freewheel" provision on the Toolcat.
/ If you have Toolcat questions, ask them here... #352
With the engine off, is there any way to roll or move the Toolcat D series?
DEWFPO
Yes and no. You would need to release the brakes. If you had a porta-power.:thumbsup:
/ If you have Toolcat questions, ask them here... #353
I have a set of 'bolts' that install in the axles that disengages the drive and allows you to 'roll' the Toolcat. Possibly this is only for B series?
/ If you have Toolcat questions, ask them here... #354
"Yes and no. You would need to release the brakes. If you had a porta-power."
Where would this hook up to and would it release both front and rear brakes?
DEWFPO
/ If you have Toolcat questions, ask them here... #355
Does anyone know if these work on the D series?
DEWFPO
/ If you have Toolcat questions, ask them here... #356
Dennis,
How does one move one of these (say onto a trailer or tow truck) if something malfunctions and you can't drive it?
Thanks, Walt
/ If you have Toolcat questions, ask them here... #357
To clarify brake release; the A,B,&C series with straight axle does have the access to install a tapered blot kit to mechanically release the brakes. D series and later (independent wheel suspension) does not have this.
On all series; even with brakes released the motors would still created a hydraulic lock that would skid the tires unless pressure is released. Easiest, but NOT EASY, would be to remove the shuttle spools from the motors.
To get one on a trailer or rollback, winch it on letting the tires skid.
/ If you have Toolcat questions, ask them here... #358
/ If you have Toolcat questions, ask them here... #359
Thanks Dennis, DEWFPO
/ If you have Toolcat questions, ask them here... #360
DEWFPO
I have my porta power set up with a test coupling that connects to to the port block. It acts like an acumulator. Pump it up to 35 psi turn the key on lower the TICs.That will release the brakes. step on the traction control after setting the direction control lever and tow or push away. FYI you may need to give the porta power a few more pumps to maintain the 35 PSI.:thumbsup:
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
1999 C Bar Stock Trailer (A60463)
1999 C Bar Stock...
WANCO LIGHT TOWER (A60736)
WANCO LIGHT TOWER...
2020 Deere 50G (A53317)
2020 Deere 50G...
1605 (A57192)
1605 (A57192)
