I wish I could weld
/ I wish I could weld #61
sdef on this wave break at Pier 66 down town Seattle. I fired 12 welders for a he!! of a lot less than what that welder did to you. First order of wire for this project was 3,500- pounds.
/ I wish I could weld #62
Agree, but get a good textbook too. The problem with videos is that they provide snippets of good information but generally fail to go over theory and safety in an organized manner. I bought several welding books but find that just one is head and shoulders above the others as an organized text with clear photographs, specific exercises at each level and is clearly written. That text is Welding Principles and Applications by Larry Jeffus. It is in the seventh or eighth edition now but I am very happy with the sixth edition I got used from Amazon. You get what you pay for, this is not a cheap book but used (about $25) is is a great deal. It is used in vocational ed programs and is so well done that you could literally teach yourself to weld and also understand safety etc. It isn't an industry reference manual, it's a well thought out textbook. The author taught welding for many decades.
I got two copies used from Amazon (one for the summer place) and paid about $25 each. Well worth it. Welding: Principles and Applications: Larry Jeffus: 978141852751: Amazon.com: Books
My copy arrived in today's mail. I used your link and got the "Sixth Edition". Saved several dollars from what the 7th seemed to be going for. How is the best way to tackle this? Start at page 1 and go from there or just try and answer questions as they come up?
Let's name the club. I'll throw out:
"WHERE's THE PUDDLE".
Who will count the votes?
/ I wish I could weld #63
I solved the where is the puddle question by getting a lighter shade of filter. Neighbor gave me a old helmet he had from work. Could not see s*** when striking a arc. He had worked at the tank plant in Lima Ohio. Now weld with a 10 and can "see".
/ I wish I could weld #64
My copy arrived in today's mail. I used your link and got the "Sixth Edition". Saved several dollars from what the 7th seemed to be going for. How is the best way to tackle this? Start at page 1 and go from there or just try and answer questions as they come up? Let's name the club. I'll throw out: "WHERE's THE PUDDLE". Who will count the votes?
If you have no welding experience I'd suggest starting with chapter 1. If you are brushing up then skim. I didn't do all the exercises but I think they are very useful if you don't have someone to watch you weld and give you feedback.
Rule 1: The puddle is tough to see without cheaters.
Rule 2: Until you see and control the puddle you ain't welding, you're probably glue gunning.
/ I wish I could weld #65
Name the club
1) "Newbie Old Guy Welding Club"
2) “The Over The Hill Cheaters Welding Society”
3) "WHERE's THE PUDDLE"
4) “Old Puddle Seekers”
5) “Over The Hill Newbie Welding Club”
suggest a better name
/ I wish I could weld #66
I need "cheaters" so I'm in!!!
I'll take a stab at it..."Grumpy Old Metal Melters".
/ I wish I could weld #67
Grumpy Un-couth Metal Melters = GUMM
dadgummit!
"Dad you have a big chunk of food in your teeth." (Dad hands dentures to kid) "Here you pick it out I'm busy. And don't eat it that's part of MY lunch."
I thought I better have another try at the stick welding game. My first mini project is to reinforce a wooden carry box with steel, which gives me plenty of chance to practice butt joints.
Actually, if truth be told, I spent a lot more time with the angle grinder, removing slag holes and starting again, than I did melting metal. I seem to be able to make two types of slag :-
Bad slag - This stuff just doesn't want to come away. When part of it finally does, it will almost certainly be covering something very ugly underneath.
Good slag - This is almost self peeling, needing only a gentle push to reveal something underneath that almost looks like a proper weld.
Now I need to figure out how to make more good slag than bad - or buy another pack of grinding discs :)
/ I wish I could weld #70
My welder will be here next week. I hope I look as good as you starting out.
Anyone have thoughts on acquiring steel to burn? I hate to spend a bunch of money on stock just to burn up.
/ I wish I could weld #71
Find a metal recycler in your neighborhood. They'll sell you some.
I also go to ironwork shops/welding shops etc and buy scrap. They'll either give small amounts to you or sell by the pound.
/ I wish I could weld #72
Thank you. I was thinking about the scrap yard. Have to run up there at lunch some day.
/ I wish I could weld #73
I forgot to mention another spot to get practice steel: the local dump. Ours has metal recycling in a big pile and no one cares if I pick through it. Great for sheet metal and tubing.
/ I wish I could weld #74
I'll check dump next time I'm there. There are guys there that pull stuff aside for the scrap yard. I can probably pay them scrap price.
I was surprised at how little steel I needed once I started to practice butt joints. For every joint I would weld it, then grind it out and try again - sometimes having to repeat the same joint several times before it looked right. After that, I move on 1/2" further down the bar, cut it off, then try and join it back together again. This way only foot or so of steel can keep me happy for hours. :)
/ I wish I could weld #76
If you go on welding web and read up on the number of guys that have died and been severely injured from using brake cleaner, you would NEVER EVER use it again. Throw it away.
DANGER using BrakeCleaner to clean your Parts
Ironic. ... Surface cleanliness is extremely overrated in stick welding. Pristine is when it has to be 100% as opposed to high 90s.
/ I wish I could weld #77
View attachment 463489 View attachment 463490 View attachment 463491
Buy a cheap needle scaler. Good for slag removal and peenig the bead to remove stress. ... Also, get some 3/32" 6011 rods to spot fill imperfections using about the same amp you use for an 1/8" bead.
,,,,A die grinder with 1/4" carbide ball cutter is good to clean out pocket imperfections prior to touch up.
Thanks, I will have a look out for the needle scaler and ball cutter.
In this country 6011 doesn't seem to be widely available, at least not to people like me who would only buy small quantities, it's all 6013 or 7018. I have just been given a pack of Lincoln 6013 rods by a friend. Tried them last night and found the flux coating on these to be much more tolerant than the non-branded ones I had, making it easier to re-strike and tack things up.
Also had a quick go with these new rods at welding vertically, nothing fancy, just trying to run a bead up or down. That's hard ! I quickly realised fully vertical is way too ambitious for me at the moment and tried it instead at 45 degrees, as the training book recommended. Played a little with the current and still struggled at going up. Going down at 45 degrees was much easier, possibly because in that direction, it is easier to see where the weld pool is going. I can see I will need a lot more vertical practice, or if not resign myself to welding in just 3 positions - on the flat, perfectly level and horizontal :).
/ I wish I could weld #79
Eric I wouldn't recommend you run 6013 or 7018 vertical down hill! There is a trick to running any rod with heavy slag vertical down hill! 6011 or 6010 is a piece of cake to run vertical down hill.;)
/ I wish I could weld #80
Most of my welds are DC electrode negative. I had trouble in corners. I read somewhere that when welding in corners with DC, magnetic fields can make the weld puddle difficult to control. I switched to AC for these corners and had much less problem. Another tip that I picked up from a Brit, was to keep a piece of scrap nearby on the work piece. I strike new rods on that scrap for a few seconds to heat the rod up before I go to the work piece. It's a poor man's rod heater, and really, not so much waste for a non-production environment.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2022 Winnebago Minnie Camper, VIN # 54CTM2N23N3059086 (A61165)
2022 Winnebago...
2016 BOBCAT T650 SKID STEER (A62129)
2016 BOBCAT T650...
INOP/NON-RUNNING 2011 Ford F-550 Cab and Chassis Truck, VIN # 1FDUF5GT9BEB33435 (A61165)
INOP/NON-RUNNING...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
