Fuel, 101 way's to get it
/ Fuel, 101 way's to get it #121
i do love my new fueling storage tank. took 1 minute to refuel the tractor..and i didnt have to climb on the tires to do it. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=460845"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=460846"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=460847"/>
That's a good looking garage/shop.
/ Fuel, 101 way's to get it #122
thanks, after 19 years its still a job in progress. Haha.
My biggest mistake was not insulating it the day i built it. I now have it 1/2 way insulated. Was going to finish it this winter but i ended up working all winter doing generators and had no time to finish it. Now its full of generators and i still cant work on it.
Delivery day and trail run. Plan A, buy a transfer pump>done, so far so good. Plan B, buy 30 gal. barrel>done, so far so good. Plan C, buy hand dolly>done, so far so good. Plan D, make unload ramp>done, so far so good. Plan E, forgot about plan E, didn't think of plan E, now plan E is a work in progress, and that is try to figure out a way to keep 1" intake hose in barrel that has a 2-1/4" ish threaded hole, so it is water tight and easy to remove for refilling barrel, so far it has went to plan F.
The fuel pumping was easy, but I haven't attached the filter yet That will be next week. Greasing the zeeks on the excavator was a different story. That's a lot of pumping. By the time I finished, my pecs were on fire. And there always seems to be another one. I'm going thru the manual to make sure I got them all.
You have to get a Dewalt batt. grease gun, just place the hose and pull the trigger, it is so much easier.
I have been reading through this and given the answers I got on my endeavor in my other threads, I need to ask another question. I can mount my Fill-Rite RD 8 vertically on my barrel, but saw someone turned a 90 from the top and had the pump on a board on top of the barrel. Looking at the plastic barrel and the reducer bung, the weak link is actually the top of the barrel around the fitting. I got thinking of the stress of the filler hose leveraging the pump mounted vertically as shown here http://www.fillrite.com/ProductCatalog/4089.pdf , (photo, bottom right hand corner mounted to barrel of the pdf) . I am thinking now of using 316 SS 3/4 fittings (stainless steel) and turn a 90 out of the bung, use a cam lock set of fittings into the pump (for quick disconnect), and mount the pump to a board that fit the elevation of the 90 and will rest on the tank top. Then the only leverage is a turning motion the fitting will take and give if necessary. The cam lock fitting also will give a bit too. I am thinking of using SS fittings to prevent any rust over time and they are stronger than brass or aluminum, at least I think they are.
Am I overthinking this? Thoughts?
Bottom line this whole set up can be moved to a larger tank later if needed.
Are you thinking what I'm thinking, cause I don't my pump mounted on my barrel, I want it separate.
Apparently, everything is denser in Maine! Lol. (especially the women) :laughing:
My wife would say it's the other way around, she tell's me to grow up and threw me out of my fort :(
/ Fuel, 101 way's to get it #127
I'm positive I mentioned/cautioned you about Plan E back in post #30... hang on, I'll check...
Whoops, sorry Mate. :sorry: I got side-tracked by the Mudd's Women question.
So, ah, watch out for when Plan E comes along, OK?
/ Fuel, 101 way's to get it #128
I just got one of those things. Its works great. There are so many zerks on a tractor with a FEL and backhoe they all want to be greased often, too often. A dozen on the FEL alone, about 10 on the just the front axle, then another dozen or so on the backhoe and a few more here and there. Oh well I can always use it on the truck too. I'm gonna go broke buying grease. It's like trying to keep a kid in shoes.
I'm trying to think of ten grease fittings on a front end axle of a tractor, lug nuts don't count. I have two on the axle pivot, but don't hit that has much as the loader zerks.
[Stardate 1329.1] All three women married the lithium crystal miners of Rigel XII.< post 30, I had to double check just to make sure my A.D.D. is under control.:reading:
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2024 Linx UT357714TG (A60463)
2024 Linx...
2021 Bobcat E42 R2 Series (A60462)
2021 Bobcat E42 R2...
CFG QK18R (A60463)
CFG QK18R (A60463)
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2015 FREIGHTLINER M2 26' BOX TRUCK (A59906)
2015 FREIGHTLINER...
