Ford 3910
/ Ford 3910
Where does everyone get their paint from? My friend was telling me about the epoxy paint that he got from Tractor Supply to repaint his John Deere. He seemed to like it a lot.
/ Ford 3910
This place seems to have a good price on the top link bracket. The lowest price I could find anywhere else was $120. They also have a combo deal on the other lift parts minus the top link and stabalizers. Those I can just steal from the other tractor. Unfortunately the nose piece is well over $200 here so I will most likely buy it from a different source unless the shipping cost makes is comparable. I get free shipping for spending over $500. I'm wondering if the 2600 nose will fit on the 3910. I might just have to check that out. I'm thinking it probably will and maybe the grill will too.
The Shopping Cart : Alexanders Tractor Parts, Your Online Tractor Source
/ Ford 3910 #43
I converted my 3910 from chain stabilizers to telescoping using Cheap Tractor Parts Not sure they are any better source but it's another choice.
/ Ford 3910
I'll check them out. Thanks! I think I can get all the lift parts (everything including telescopic stabilizers) for around $750 and free shipping. Their nose cone is $40 more expensive than what I'm seeing on ebay ($179). Include a new grill for $52 with shipping and some amazon led head lights and I should come in just under $1000. Not to shabby. I think I might just pull the trigger on everything instead of trying to get the stuff from the 2600 to work.
/ Ford 3910
I finally had some time to get this abomination off. I should be able to cut the angle that was welded on it the plasma cutter and then fab and weld up the horizontal piece that's missing. Does anyone know the length, width and height of the straight/flat drawbar? I figure I can just make my own since I have both a mill and a mag drill.
Went ahead and ordered all of the 3 point hitch parts I needed and a fuel shutoff valve since the other one was broken and leaking. Going to hold off on the grill and nose cone until I finish straightening everything up front. Also noticed I need to replace the oring/seals for the throttle/fuel shutoff shafts as they seem to be leaking. I'll try to take more pictures as I delve into this deeper.
/ Ford 3910
Picked up a whole bunch of spray guns for free. I should be able to use one of the hvlp guns to spray the tractor.
I think some of these are clear guns (Sata?).
Scored a spot welder for fixing dents too.
/ Ford 3910
Got most of the drawbar bracket separated from the other steel. Just need to remove the two side pieces and then remake the horizontal piece.
My buddy has the plasma cutter right now so luckily I had my trusty old portaband.
Is anyone using this trans/hydro fluid? I need one more 5 gallon bucket and then I think I have enough to do the transmission and rear end.
/ Ford 3910 #48
Not familiar with that hydraulic oil. I use "303", local brand, it meets the Ford 134 specs.
/ Ford 3910
/ Ford 3910
I may just wait and see what the fluid looks like when I drain it. If it's pretty contaminated then I may just run this as a flush and then switch to the better stuff (actually meets spec) afterwards.
/ Ford 3910
Richard,
Do you have a picture with the telescopic stabilizers in place? I ordered some but I have the straight brackets like the pick you posted and I'm not sure if I should order the angled version so there is no binding. Thanks in advance for your help.
/ Ford 3910 #52
Richard, Do you have a picture with the telescopic stabilizers in place? I ordered some but I have the straight brackets like the pick you posted and I'm not sure if I should order the angled version so there is no binding. Thanks in advance for your help.
Cool deal, looking forward to the progress!
/ Ford 3910 #53
I dont have a good pic but yes you need those angle brackets they'll clamp to the axle housing outside of the fender clamps. I'll try to remember to get a pic today.
/ Ford 3910
Thanks for the info! I'll just give them a call today and have them change the order so that it includes the bracket and u-bolts. It's actually 15 to 20 bucks cheaper per side to buy the kit. I think they are waiting on one part before they ship everything (I'm not in a hurry). Glad I thought about it before they shipped everything.
/ Ford 3910 #55
Here is a pic of the stabilizer and bracket.
/ Ford 3910
Thanks for the pic! That helps a lot. I went ahead and got the angled brackets and u-bolts. Now I just need to source a nose cone and grill. The prices on ebay seem to be all over the place on the grills. I found a couple for around $40 to $50, but I'm a little worried about fitment issues. There are no part reviews on ebay that I'm aware of so I'm kind of taking a leap of faith if I order something.
/ Ford 3910 #58
Thanks for hookin him up with the pic Happy!! I'm at the farm now and just remembered the pic ordeal. Thought I'd check TBN to make sure I got the pic he needed. That's exactly what I would have taken. :)
/ Ford 3910
You guys are awesome! Thanks again for all of your help. I can't wait to get the hitch parts. The first thing I'm going to do is bushhog my field (can't wait). Will make sure to take some good high quality video and post it up here.
Justin
/ Ford 3910 #60
Ouch! That is a rather ugly looking valve stem area. CaCl is apparently eating your rims from the inside.
Good eye, I checked it out tonight, valve stem had a slow and I'm guessing intermittent leak that had probably gone on for a while. The tool end of the cap had rotted off and the calcium chloride must have occasionally leaked out through the hole, it was dry on inspection. I pulled the removable core, wire brushed everything and replaced the core assembly. Rim had rust scale on the outside around the stem, but seems solid after I got the scale off. Glad you noticed it!! That's the beauty of this forum and sharing!!
image-70645965.jpg The culprit
2022 INTERNATIONAL LT625 DAY CAB (A67714)
2022 INTERNATIONAL...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
Unused 2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
Unused 2021...
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A68842)
PALLET OF MEC 8000...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
