plans for soil screener
/ plans for soil screener #1
not2old
Scotch Creek, British Columbia
2010 Massey GC2610TLB
I figured that this would be the best place to look for plans to build a soil screen/shaker but a search brings up everything but that. I find it hard to believe that a search only shows one thread for a grizzly screen. Any suggestions for what words to use for my search or anyone have any other suggestions for help? I'd prefer not to use a trial and error method for construction. If nothing comes up, I will try to post my build.
THANKS
/ plans for soil screener #2
Have a look at the "Similar Threads" at the bottom of this page.
Also, don't use the 'Search' (magnifying glass) function, I believe that it's busted. Use the Google Custom Search box, above it.
I didn't know what I was doing wrong. The problem with the search function shouldn't surprise me- ALL COMPUTERS HATE ME
THANKS
/ plans for soil screener #4
Nah, you didn't do anything wrong... I only learnt about the magnifying-glass function (lack thereof) the other day.
/ plans for soil screener #5
A few years back I built a 50'x75' garden by scratching the area with my backhoe 18" deep piling it then screening it all. The screener I built was on the cheep but worked better than expected. Total cost $50 for the piece of 9 ga. chain link fence and metal strapping,had the pressure treated lumber from a deck I removed. You have to go to a fencing co. for the fence, the big box stores only have 11 ga. crap. I didn't stretch the fence fully since the holes would be to big, so I tightened up the openings and secured it with the strong back straps in three places. Basically used a 9' length of fence in a 6' run.
Since the pictures I have added a couple more boards to the sides to better contain the soil.
The only downfall I have found is that some odd shaped rocks, roots, and branches will sometimes clog the screen, so I keep a metal leaf rake handy. Other than that I am very happy with the results, dig a hole with backhoe, place screener in front of hole, screen out soil, rocks roll into hole.
/ plans for soil screener #6
Nice work! How long did it take to build?
/ plans for soil screener #7
Consider making the "screening panels" easily removable - I have three screening panels for mine, all of which use 2 x 4's (on edge)
The one I use the most is 1" square wire netting ... works good to clear most all debris down to around 1/2" - 3/4" diameter.
The second uses a cattle panel from TSC, which I believe has around a 4" mesh - good for larger rocks.
The third uses hardware cloth with 1/4" mesh ... good for cleaning dirty gravel.
/ plans for soil screener #8
After plowing my garden spot, I'm going to have to build one of these things, :thumbsup:
I've got rocks from small to 20 pound that I've pulled out......
/ plans for soil screener #9
Weeks of planing and about a day and a half to build. I actually built it in the shop in my basement ( like a boat), only I was able to partially disassemble and send it out the basement door for transport and reassemble.
I tried to pull the larger rocks out by hand, 8-10" a and over so as to not damage the fencing.
/ plans for soil screener #10
Thanks. Couple of other questions: what angle is the screen at? Looks to be about 45*....
And the metal strapping- where did that come from?
Can you remove the screen by hand, or only by using the tractor?
/ plans for soil screener #11
Hello Avmcane
I'm in the process of building a rock sifter patterned after yours. In looking at the pictures you posted I cant really see how you attached your 9ga. fencing material to your framing .Can you go into a little more detail into how you went about it? I purchased a box of 1 1/4x22ga. metal strapping,(the type they use in residential framing to tie structural members together) I posted a couple of pictures of how far I've progressed but I'm trying to figure out the best or strongest way to attach the fencing material.
/ plans for soil screener #12
Hello AVMCANE
JUst wanted to add that in the pictures I posted,I only have the two shorter front legs attached to the framing .They are cut at a 45 degree angle, I've yet to install the hind legs which would position the main frame at 45 degrees
/ plans for soil screener #13
This is the tractor I'll be using to load and screen approx. 10 yards of rock and dirt20191202_123256 (1).jpg
/ plans for soil screener #14
The scrap yard I frequent sometimes has chain link fence, gates, quarry screens, etc.
For small amounts of soil like a garden a chain link gate propped at angle up between trees or posts might work.
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
208320 (A58375)
208320 (A58375)
Zero Turn Mower (A59231)
Zero Turn Mower...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
