plans for soil screener
/ plans for soil screener #1
not2old
Scotch Creek, British Columbia
2010 Massey GC2610TLB
I figured that this would be the best place to look for plans to build a soil screen/shaker but a search brings up everything but that. I find it hard to believe that a search only shows one thread for a grizzly screen. Any suggestions for what words to use for my search or anyone have any other suggestions for help? I'd prefer not to use a trial and error method for construction. If nothing comes up, I will try to post my build.
THANKS
/ plans for soil screener #2
Have a look at the "Similar Threads" at the bottom of this page.
Also, don't use the 'Search' (magnifying glass) function, I believe that it's busted. Use the Google Custom Search box, above it.
I didn't know what I was doing wrong. The problem with the search function shouldn't surprise me- ALL COMPUTERS HATE ME
THANKS
/ plans for soil screener #4
Nah, you didn't do anything wrong... I only learnt about the magnifying-glass function (lack thereof) the other day.
/ plans for soil screener #5
A few years back I built a 50'x75' garden by scratching the area with my backhoe 18" deep piling it then screening it all. The screener I built was on the cheep but worked better than expected. Total cost $50 for the piece of 9 ga. chain link fence and metal strapping,had the pressure treated lumber from a deck I removed. You have to go to a fencing co. for the fence, the big box stores only have 11 ga. crap. I didn't stretch the fence fully since the holes would be to big, so I tightened up the openings and secured it with the strong back straps in three places. Basically used a 9' length of fence in a 6' run.
Since the pictures I have added a couple more boards to the sides to better contain the soil.
The only downfall I have found is that some odd shaped rocks, roots, and branches will sometimes clog the screen, so I keep a metal leaf rake handy. Other than that I am very happy with the results, dig a hole with backhoe, place screener in front of hole, screen out soil, rocks roll into hole.
/ plans for soil screener #6
Nice work! How long did it take to build?
/ plans for soil screener #7
Consider making the "screening panels" easily removable - I have three screening panels for mine, all of which use 2 x 4's (on edge)
The one I use the most is 1" square wire netting ... works good to clear most all debris down to around 1/2" - 3/4" diameter.
The second uses a cattle panel from TSC, which I believe has around a 4" mesh - good for larger rocks.
The third uses hardware cloth with 1/4" mesh ... good for cleaning dirty gravel.
/ plans for soil screener #8
After plowing my garden spot, I'm going to have to build one of these things, :thumbsup:
I've got rocks from small to 20 pound that I've pulled out......
/ plans for soil screener #9
Weeks of planing and about a day and a half to build. I actually built it in the shop in my basement ( like a boat), only I was able to partially disassemble and send it out the basement door for transport and reassemble.
I tried to pull the larger rocks out by hand, 8-10" a and over so as to not damage the fencing.
/ plans for soil screener #10
Thanks. Couple of other questions: what angle is the screen at? Looks to be about 45*....
And the metal strapping- where did that come from?
Can you remove the screen by hand, or only by using the tractor?
/ plans for soil screener #11
Hello Avmcane
I'm in the process of building a rock sifter patterned after yours. In looking at the pictures you posted I cant really see how you attached your 9ga. fencing material to your framing .Can you go into a little more detail into how you went about it? I purchased a box of 1 1/4x22ga. metal strapping,(the type they use in residential framing to tie structural members together) I posted a couple of pictures of how far I've progressed but I'm trying to figure out the best or strongest way to attach the fencing material.
/ plans for soil screener #12
Hello AVMCANE
JUst wanted to add that in the pictures I posted,I only have the two shorter front legs attached to the framing .They are cut at a 45 degree angle, I've yet to install the hind legs which would position the main frame at 45 degrees
/ plans for soil screener #13
This is the tractor I'll be using to load and screen approx. 10 yards of rock and dirt20191202_123256 (1).jpg
/ plans for soil screener #14
The scrap yard I frequent sometimes has chain link fence, gates, quarry screens, etc.
For small amounts of soil like a garden a chain link gate propped at angle up between trees or posts might work.
Harrell 6710 (A64119)
Kubota L3901HST
Kubota L3901HST
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Case SV280B (A62177)
2023 Kearney 102"x32' Gooseneck Trailer (A64119)
2023 Kearney...
Rice Lake RoughDeck AX-1 Truck Scale (A61573)
Rice Lake...
