Pin Hole Too Big
/ Pin Hole Too Big #1
Mike in Dewey
Dewey, AZ
Kubota L39
I just bought my first tractor (Kubota L39 TLB) at a Lyon & Son auction and made a mistake. I thought I壇 looked over everything pretty well but missed the pin-hole elongation on the swing frame that the alleged mechanic covered up by welding a large fender washer to the top of the pin and then painting it all Kubota-orange. The manufactured 1-1/4 bored holes (top and bottom) now have nearly a 1-3/4 outside diameter. So now the questions.
Should I cut my losses early and simply purchase a new swing frame and pin roughly a $1000 investment in parts, or do I take the assembly to a machinist to attempt a fix? And, if the latter, should the pin holes first be filled with metal weld and then rebored, probably sized for a sleeve bushing, or do I attempt to cold-weld (JB Weld or metal epoxy) a top and bottom sleeve bushing (1-1/2 OD) or flanged sleeve bushing (again 1-1-2 OD with the flange (1-3/4 OD) being closer in diameter to the elongated holes), or do I have the holes resized for a high load, sealed ball bearing (the one I found has an OD of 2-9/16??
My concern with filling the holes first with metal weld before having them rebored is that the resulting heat may make that area of the frame too brittle and the inherent voids in the weld may compromise the needed strength. My concern with the cold weld options securing sleeve bushings is that the fill won稚 be strong enough for the imparted forces. My concern with making the holes bigger for a ball bearing (or even leaving them the size they are) is losing the meat of the frame and possibly making the whole assembly too weak.
And as a side, what would have caused this in the first place? The other (left) side frame hole and pin look good as new. Why would one side get so buggered up and not the other? Was this likely caused by the original swing frame being defective or is this type of wear to be expected?
Any knowing experience or intelligence would be greatly appreciated.
/ Pin Hole Too Big #2
Proper repair would be to bore to a larger size and bush it with a interference fit bushing. Any proper machine shop will be knowledgeable about this procedure.
That being said welding it up shouldn't cause any of the mentioned problems it is made of a mild carbon steel not any time of high carbon that should be hardened by heat.
/ Pin Hole Too Big
Thanks, aarolar. My knowledge of bushings (McMaster-Carr) indicates that the available 1-1/4" ID bushings are all 1-1/2" OD. With the oversized holes now being 1-3/4" OD (roughly), is the correct procedure to put a bushing in a bushing to get to that diameter, or are thicker-walled bushings available, or do I simply leave it up to the machine shop? If possible, I'd like to do this just once and eventually pass on this tractor to someone that doesn't have to worry about this particular issue in the future.
/ Pin Hole Too Big #4
A machine shop can make a bushing in whatever OD and ID is needed. A welder might just cut out the worn out bushing and well in a new bushing. Guys build their own backhoes and buy bushings to be welded so brand new bushings in the correct size are out there.
/ Pin Hole Too Big #5
I would recommend taking it to the machine shop and let them give you repair options and a price to do it. I've repaired a few in my 30 years as a machinist and we always welded them up and rebored to standard, but that was on larger machines and those bores received hardened bushings just like when new. I imagine this did not have bushings? I wouldn't try fitting bearings. Hardened bushings would be a better fix. Very important to keep all those pins and bushings well greased!
Kim
/ Pin Hole Too Big #6
As JimRB said the machine shop will make custom bushings to fit the need.
/ Pin Hole Too Big
Thanks to all. I'll take some drawings to a local machine shop and get an estimate. If it's less then new, we'll put them to work. The holes within the swing frame did not have bushings and the pin is stationary within them. There is a bushing within the swing cylinder's rod knuckle, which is supposed to rotate about the pin, and that seems to be well lubed. Perhaps at some point during its 720 hour life the assembly seized resulting in the damage. I guess it doesn't really matter; however, I'll likely remain annoyed with Ahern Rental for purposely hiding the problem rather than properly addressing it, and not disclosing the issue before they sold the tractor. On the positive side, I'll get to break out the wrenches, get a little dirty, and add to my knowledge of this part of the whole.
/ Pin Hole Too Big #8
That is why you go to auctions early and really look over what you buy. The quick fix by a rental company is a standard practice for them. Nothing to get upset about. That is the way the game is played. I am sure you held a little back when bidding to cover for things like this. Give it to the machine shop and get a bid for the work- they do this stuff every day.
/ Pin Hole Too Big
That is why you go to auctions early and really look over what you buy. ... That is the way the game is played.
2458n - There could be an entire discussion on the expected honesty of one that sells something to another. We all understand that if it shines it sells, and that the buyer should beware, but if the seller purposefully hides a defect, if they sell you a house and know that the foundation is cracked but is also well concealed, or put sawdust in the transmission of that old Buick to quiet the grinding gears, or remove a safety because it was annoying to them, or do whatever else they can to obtain a higher price than the item deserves, is not that fraud if they are aware of the issue and it isnot disclosed? Is that what you are suggesting is the proper way to play the game?
In this case the seller was using an auction because they knew that it was the most expeditious and economical means to eliminate a large quantity of depreciated assets. Buyers expect to pay less at an auction because the sellers are willing to accept less for several reasons that make financial sense to them. One of those reasons should not be, and never have I seen it documented, that an auction grants the seller tacit authorization to freely commit deception. I absolutely understand that items are sold as-is, but that definitely does not mean that if the seller knows of a significant issue regarding most anything that is sold, whether it is a dealership or an auction house or a private owner in another state, that they get to remain silent about expensive or safety related issues of which they are certainly aware.
As-is means that the seller is not aware of anything beyond the obvious. Ahern Rentals, which owned and serviced the tractor I bought, is one of the worlds largest rental businesses and certainly tracks the maintenance and problems and everything that needs to be done for all of their capital goods, just so that they can continue to rent the items and maintain their return on investment. Their records (which they did not share) knew that the tractor they were attempting to sell had problems that they had willfully concealed, and also knew that if discovered or disclosed that the offering price to buy would be reduced. They would be stupid to rent a tractor to a business, that was also expecting to generate a profit in using that equipment, if they knew that he tractor was likely to fail, thereby costing the renter money along with bruising both of their own good names, and I doubt that Ahern is stupid. No, the welding of a large washer over that oversized hole and painting it orange was done only for the auction crowd, and it was only done to hoodwink the potential bidders and hope that the winning bidder would not have the gall to demand fairness. As-is never has and never will mean that the seller gets to legitimately paint over known problems that prospective purchasers are not expected to see.
If everyone was well aware that a business or a person was apt to conceal known flaws related to a large percentage of that which they sold, who would buy their products except for probable scrap or possibly parts? Who would ever purchase and sit on such a machine that would likely have hidden a weakness that could cause them unanticipated pain or financial misery? The answer is, no sane individual, so I reject the premise that one should expect to repair an unknown failure just because an item is purchased at an auction. If it is missing a bucket, absolutely, that is obvious enough. If there is a puddle of oil under the transmission or the tractor does not start or the hydraulics do not work or a tire is flat - ya, those you are expected to see, and by offering a visual inspection of the property those such things are being disclosed. But if the one offering the goods goes out of their way to hide or obscure a problem, then that certainly sounds like fraud and not what we should obligingly accept from any seller. Sure there are some and maybe many out there that thrive and profit in using deceit, but we usually term them crooks and the civil society is supposed to, eventually give them their due justice.
Yep, I believe in the Golden Rule and expect mostly good in this world and occasionally seem to be charging windmills. And yes, I have already contacted the Clark County, NV District Attorneys office to see if they would like to investigate possible criminal activity, and I am looking into civil litigation (small claims court). Nothing ever got done that was not started and others should not be too surprised if their expectations are low and that is exactly what they get.
/ Pin Hole Too Big #10
I agree on talking with a machine shop or two and explore your options.
Do you have any pictures of the parts needing attention. I have done alot of pin/bushing jobs on sloppy backhoes. But am unfamiliar with the L39 setup. Specifically, are we talking about a small piece that can be taken off and taken in to be machined? or are we taking about practically taking everything apart to get to a sizable 150# chunk of metal?
Pictures would do me wonders.
/ Pin Hole Too Big #11
in the very first post is was noted that the tbl was looked over and the noted area in question was overlooked. you saw the bad area after it was purchased so you could have seen the area before the purchase. whose fault is this. the auctioneer? yours. if you saw it you probably would have bid differently. might not have purchased it and wouldn't have the tlb and the problems. I'm sure with or without the repair you still purchased it cheeper than new. be happy that you have a tractor instead of sue happy! take to machine shop and have fixed and be happy!
/ Pin Hole Too Big #12
It's easy to understand your angst with this situation, but there's a reason equipment, furniture, cars, and PEOPLE go to auctions. If the item for sale is in top condition, an individual will sell their goods in the classifieds and can afford to wait on the right buyer. If the item in question is average to below average in condition, send it off to a consignment or auction. Companies must watch cash flow and inventory turns, so their first choice may be auctions. If that piece of equipment was perfect, the service technician would have likely told his buddies ar a "shill" in the audience to bid on the item. Over the last 40+ years, I've bought and sold maybe a hundred cars, motorcycles, trucks, tractors, etc., and two (2) of them came back. Almost every item I bought didn't run, and I built engines, transmissions, differentials, suspensions, etc. and passed it on. I never did this intending to make a lot of money - it was a hobby that didn't cost me anything. The two cars which came back (mis-installed head gasket and bad brakes)? Well, I repaired them both and sent the customer on his merry way, but that is NOT t.
/ Pin Hole Too Big #13
Was the paint fresh, or had they been running it like that for a while?
IMO, fresh paint on something at an auction is a red flag. If they had been running with the washer for a while, they probably put it on to get it back in service while they were getting a replacement in (or waiting till the next budget year to order a new one).
True, but if they have been using it like that for a time, they may not have considered it to be more than "normal wear and tear" for such a machine.
Aaron Z
/ Pin Hole Too Big #14
My only experience is with auto auctions, so this may not apply.
The auction houses I'm aware of have a dispute resolution process. If a problem is brought forth within a certain period of time, the auction will freeze the funds transfer to the seller and investigate the issue.
A car collector friend of mine bought a very expensive classic only to find major issues. He prevailed in his dispute and got his money refunded.
/ Pin Hole Too Big #15
There is a saying that I tend to go by. "You get what you pay for" Nuff said except for "There are no free lunches".
I got here via the road of hard knocks just like everyone else does.
/ Pin Hole Too Big
Attached is a picture of the large fender washer moved just a touch which shows the oversized hole on the swing frame - a block of steel that does weigh roughly 150 lb. Even though I and others exercised the tractor in the rental/auction yard, the washer and pin didn't move enough to show the oversized hole until the first day I started to use it at home.
I'm still in the process of building a rolling cart that'll take the weight of the mainframe and stabilizers along with some supports for the boom/dipperstick/bucket assembly so that once all the pins are removed, I can then get to and remove the swing frame. Someone asked if there was new paint on the tractor, and there was, but there was also new paint on nearly all (all?) of the several hundred pieces of machinery up for sale. In fact, they'd all been pressure washed and buffed up shiny, just so the dents and dings and bent and broken parts would be less distracting. That's all fine and expected, but I am surprised with those that accept that purposeful deceit is part of the game and should be graciously accepted. Too many of us seem to have become callused and complacent toward the wrong side of humanity. A few will not, and if in the future you purchase something that met or exceeded your best expectation, be sure to thank the seller along with those that decided not to get callused but instead got even.
/ Pin Hole Too Big #17
Got a picture of the other side?
Maybe I am seeing it wrong, but if the washer is welded to the pin, and if the pin is the diameter it looks like looking at the top, then that hole looks twice the size that it is supposed to be. Hard to believe there would be THAT much wear. And what I can see of the hole does look round.
Can you take that pin out and get a pic of whats going on?
When you were first describing the issue, I was under the impression that they welded the fender washer to the swing post, basically making the hole smaller to fit the pin again, but not for the whole thickness. Doing that WOULD tighten up the slop, but wouldnt last long as the washer would wear out in no time.
If what you are saying is correct, and welding the washer to the pin only to cover the hole, did NOTHING AT ALL to help, only to cover up a problem. Would be like filling a crack in the boom with bondo and painting over it to make it look like it wasnt cracked. I agree if this is the case, deceitful.
/ Pin Hole Too Big #18
Are both sides that way, or just one?
It seems that much slop should have shown up by pushing the boom back and forth by hand.
What happens when you pull the two bolts that hold that pin (#70 below) in? Did they perhaps put an undersized pin in the hole?
Aaron Z
/ Pin Hole Too Big #20
Aaron Z
Kinda my thoughts in requesting a pic of the other side as well.
If the boom swing cylinders were push-pull (DA) type (rather than push only SA like a snowplow), and the one cylinder is good an tight, pushing the boom my hand wouldnt show anything unusual.
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
New 4ft Bushog Rotary Cutter (A65579)
New 4ft Bushog...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
