Snow removal with a 3 pt blade
/ Snow removal with a 3 pt blade
I bought this today... it's an 8. I really was looking for a 6. Should I cut it down? It seems like it will be too big for the tractor, especially when I get a load in front of it.
/ Snow removal with a 3 pt blade #22
What's the trick to using a blade to cast the snow in the desired direction without needing to reset the angle?
Keep the sway chains a bit slack, and then when the blade engages the snow the blade will push the frame off to the extent of the sway chain, giving the blade just enough angle to send the snow where you want it. And that could be either right or left. This of course applies when the blade is set square to begin with.
One pass down the gut without a care as to how the snow is rolling off.
Then a pass rolling the snow left, then a pass rolling the snow right. (in my case, it's four passes to the right ;-)
/ Snow removal with a 3 pt blade #23
View attachment 461393View attachment 461393
It needs to be at least 1.15 X the width of the rear tires, so that it will cover your tracks when angled. I wouldn't cut it down without some measurements first, and then not until using it for a few times. May be just fine.
/ Snow removal with a 3 pt blade #24
bjorn I have a buddy that lives up there, Skip Myers. I visit him now and then.
Anyways with the rear blade, at the most angle it should cover you tire tracks. You may even want it a tad wider if you ever have install rear tire spacers or you have reversible rims for extra width. Dont know if your model actually does that.
I can also completely swing my blade around-180 degress if and when needed, rarely, but nice.
You could carefully measure and make your marks, but use it awhile to see where you stand before cutting it down. Then give it a nice coat of orange paint!
My tractor is 65" wide.... that's 1.47x my width. The rims are pretty deep offset, wouldn't be able to reverse them. The blade does swing around 180 degrees. I'm planning to put rear hydraulics on the tractor, an angle cylinder for this blade may be part of that install.
/ Snow removal with a 3 pt blade #26
CaIG if the arm the blade is attached to when level to the ground it will be level regardless which side you plow to. It has to be level when the blade is resting on the ground or very close to it.
/ Snow removal with a 3 pt blade #27
I would keep it at 8 for now. Give it a try. With the 8 footer, you could have a much steeper angle on it to help it scour the snow better. With the steep angle, you could let it clear only 6 feet of width. You can always cut it down later.
/ Snow removal with a 3 pt blade #28
I'm not sure how this applies to sway links, more like a top link setting. Can you expand on your expression?
/ Snow removal with a 3 pt blade #29
bjorn, I would guess that after you use it in a real snow, you'll find that the wide blade will push the tractor to the side when a load of snow gets built up. Using rear chains will be a big help (sorry if I am repeating someone's earlier advice) in controlling that- and providing traction in snow.
You can always cut it down later. I suppose you could always weld the cutoffs back on, as far as that goes. I found that my biggest problem with a rear blade was leveling it for sloped or crowned surfaces- now, our front plow floats from side to side, and is heavy enough to follow the surface, so no problem.
/ Snow removal with a 3 pt blade #30
That finally prompted me to install my hydraulic side link.
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
EZ-GO Electric Golf Cart (A60463)
EZ-GO Electric...
