Yanmar 2310d won't move
/ Yanmar 2310d won't move
There was not a gasket on a one of them.
/ Yanmar 2310d won't move #82
I don't have a 2310 parts manual but according to the 276 and 2210 manual there should be gaskets on the ones mentioned.
You misunderstood Winston...I'm saying that the ones I mentioned did not have a conventional gasket on them when I took it off, they had the "gasket sealent in a tube" type on there. I'm just wondering on the ones that do require the use of a gasket, is there a difference in using an actual replacement gasket from a parts store, as opposed to buying a big tube of permatex and doing all of them for $5 - $10.
And there was nothing on the drop box but the o-ring, but there isn't anything listed in the manual either so I guess an o-ring is fine.
Sorry to be confusing...
/ Yanmar 2310d won't move #84
I'm slow to catch on. I understood you, just saying I would buy the gaskets if it were mine or buy material and cut them. Sealant will probably hold fine, just seems right to put it back like designed.
And I agree. I just don't know enough about it and thought if there was no difference I would use the goop stuff. I'll order the ones I can get.
All parts including gaskets ordered from Hoye this morning.
Parts have shipped. I believe everything I need to put this baby back together are scheduled to be here tomorrow. Can't wait to see if I can get it done. :)
/ Yanmar 2310d won't move #88
Good news. Best of luck. I'll be watching and rooting for you. :thumbsup:
/ Yanmar 2310d won't move #90
Now hopefully the correct gaskets and parts are one the way. Since you was the one that took it apart and found the problems then putting it back together with the correct parts is usually the easiest thing to do. I hope it doesn't become a roll of the dice and you just get lucky getting everything you need.
Been a crazy week at work with the power. I'm a network administrator and we found out that our emergency generator is not hooked up correctly.......oops, but at least not my oops, just my mess to clean up. Anyway, I got a chance to work on the tractor today.
Got the new brake stub axle put in, and then put the differential lever back together.....then stopped. You can turn the brake axle by hand, but it is really hard to do. And when the differential pedal is pushed it isn't moving the lever...something wrong. Got mad and stopped. I need to take those two pieces back off tomorrow and start again fresh.
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2022 EZ-GO ELITE...
GENIE AWP-36S MAN LIFT (A63569)
GENIE AWP-36S MAN...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
John Deere 6105D Tractor (A64047)
John Deere 6105D...
2008 New Holland T2420 (A60462)
2008 New Holland...
