How to Grapple without a Grapple - Pictures please
/ How to Grapple without a Grapple - Pictures please #61
Yep and faster than one of them chain thingies. :laughing:
Nice attachment!!! And you have lots of nice toys to play with as well!
/ How to Grapple without a Grapple - Pictures please #62
This is sort of my dilemma now. Do I just go get some strap on pallet forks and continue to pile on my burnables manually, or do I get a QA set up and have more capacity with forks (I don't move pallets around hardly at all), or do I invest in the grapple (my dream but not sure I can justify the expense)?
I move many more things than pallets using my clamp-on pallet forks, and the "investment" for a pair is minor compared to a grapple. I use clamp on's because I couldn't justify a QA for either tractor. However the "quick-on's" (which don't fit either of my tractors) look even better.
In the picture of bamboo I posted earlier we would run into a pile of the stuff, lift it, then throw a chain over it so we could drive a distance. The attached picturs show some of our lot clearing and the resultant pile. I had an area about 100x75 that was 20yr old brush, saplings, vines, thorn brush so thick as to be impassable. We cut the saplings down and then would angle the forks down slightly, ram forward and lift.
I'd still recommend you get a lightweight grapple, but for a BX25D you run out of lift capacity quickly.
How's that do on a 20" hardwood tree?
/edit - do you even have any trees over 20" DBH?
/ How to Grapple without a Grapple - Pictures please #63
Thanks, after I sold the tractor, I modified a fork frame to use the 3 point cedar tree cutter on the V417.
So much better out front. :thumbsup:
With the chains and linkage it would set flat at the tree no matter what angle the V417 was at.
/ How to Grapple without a Grapple - Pictures please #64
Yep, there are a few big hardwoods around here. I think the cutter was rated for 12" trees.
I was clearing the north fence line after we moved here, cutting some 10" DBH oaks, when it got in a bind and broke a blade.
Now the hardwoods that I deal with are dead, so I just pull them or push them over.
/ How to Grapple without a Grapple - Pictures please #65
Posted the picture before, my nephews skid loader loading stump into my trailer with my pallet forks. My tractor did not have the lift capacity to lift the stump. Little 30 hp cub.
/ How to Grapple without a Grapple - Pictures please #67
Back when I had my Kubota before I upgraded to a bigger tractor. This lil' beast could lift anything as long as there's weight on the back. Of course, I keep things simple.
I fabbed these "tusks" as I call them and they have proven their worth. They were removable so I could use the bucket.
/ How to Grapple without a Grapple - Pictures please #69
Chain and bucket.
4n1
neither comes close to the grapple however.
forks plus thumb for certain things like logs work fine (but anything with a thumb is a grapple)
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 JCB 35Z-1 (A60462)
2024 JCB 35Z-1...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
ATTENTION! PLEASE READ (A60463)
ATTENTION! PLEASE...
