If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #341
When my drive motors starting going and even till I replaced them, the engine never stalled.
/ If you have Toolcat questions, ask them here... #342
Have a model A and for the last week it been acting funny. Engine runs goodand all the rest but when in drive, it will slow down and same for engine rpm 2 or 3 seconds. Today it stalled the engine when snow plowing but wasn't moving realy fast. Looks to me the drive pumps are failing. Could it be something else. Any experience with that kind of snags. Thanks.
You should not be able to stall the engine. Check your fuel and air filters. Sound like an engine issue.:thumbsup:
/ If you have Toolcat questions, ask them here... #343
The only time I ever stalled the motor was on a very cold day (engine and fluids not totally warmed up yet) and I engaged the snowblower which happened to have the fan blade frozen solid to the blower and I didn't notice it. It immediately stalled the engine before the bypass could kick in.
DEWFPO
/ If you have Toolcat questions, ask them here... #344
Ok, Guys! I'm ready to drop the bomb and buy a 2007 5600. I'll be buying it from a dealer up in Wisconsin and shipping it to North Florida.
There are 3049 hrs on the clock and a good deal of bed rust as it was a municipal plow and sidewalk cleaner. Given the amount of chems they use, I'd say the bed is in pretty good and repairable condition.
What questions should I ask the dealer before settling on the price. About $5K less than anyone else I've seen of late.
The tires are all but worn smooth. Which I'd expect from a quad-steer on city sidewalks.
It's got the 7/14 connector. Although, I'm not ure I even know or will ever need it.
I've asked for and received a series of pics and all seems really good for the age and use.
There is a problem with the boom. It appears that when the bucket is laid flat on the ground one corner is higher than the other.
However, I've got an LS tractor for all my FEL work. So it's not a deal breaker for me.
Give me some questions to ask this dealer to settle the jitters in my heart about buying a machine like this sight unseen!
/ If you have Toolcat questions, ask them here... #345
What Series is it?
You can tell from the serial number (thanks to SSdoxie).
Make sure you get one of these with it. Utility Vehicle, Toolcat, & Tractor - Operation & Maintenance Manual
You could also request a Service Manual and a Parts Manual. :thumbsup:
/ If you have Toolcat questions, ask them here... #346
Isn't the manual available as a pdf file?
I'll ask when they open. Will be driving home today but the navigator can communicate via iPad.
Be kind to the Mrs., Guys!
Selling my '11 Ranger Diesel to fund some of this venture.
Hope I'm doing the right thing.
Too many joint replacements over the years can't even get into, or out of, anything Kubota nor Deere make
in the UTV realm and the Polaris Brutus/BobCat 3600 both are severely under powered.
Which drops me at the ToolCat platform. Nice place to be but it's got to work.
/ If you have Toolcat questions, ask them here... #347
Have the dealer plug in service analyzer and copy the service codes and warnings for you. This will tell you if there are any issues with the unit like it being overheated or electrical problems.
/ If you have Toolcat questions, ask them here... #348
The manual is paper or CD Rom.
Have the dealer put the optional step on it, to make it easier to get in and out of.
/ If you have Toolcat questions, ask them here... #349
"Have the dealer put the optional step on it, to make it easier to get in and out of."
X2.
DEWFPO
/ If you have Toolcat questions, ask them here... #350
With the engine off, is there any way to roll or move the Toolcat D series?
DEWFPO
/ If you have Toolcat questions, ask them here... #351
No there is not. There is no "tow" or "freewheel" provision on the Toolcat.
/ If you have Toolcat questions, ask them here... #352
DEWFPO
Yes and no. You would need to release the brakes. If you had a porta-power.:thumbsup:
/ If you have Toolcat questions, ask them here... #353
I have a set of 'bolts' that install in the axles that disengages the drive and allows you to 'roll' the Toolcat. Possibly this is only for B series?
/ If you have Toolcat questions, ask them here... #354
"Yes and no. You would need to release the brakes. If you had a porta-power."
Where would this hook up to and would it release both front and rear brakes?
DEWFPO
/ If you have Toolcat questions, ask them here... #355
Does anyone know if these work on the D series?
DEWFPO
/ If you have Toolcat questions, ask them here... #356
Dennis,
How does one move one of these (say onto a trailer or tow truck) if something malfunctions and you can't drive it?
Thanks, Walt
/ If you have Toolcat questions, ask them here... #357
To clarify brake release; the A,B,&C series with straight axle does have the access to install a tapered blot kit to mechanically release the brakes. D series and later (independent wheel suspension) does not have this.
On all series; even with brakes released the motors would still created a hydraulic lock that would skid the tires unless pressure is released. Easiest, but NOT EASY, would be to remove the shuttle spools from the motors.
To get one on a trailer or rollback, winch it on letting the tires skid.
/ If you have Toolcat questions, ask them here... #358
/ If you have Toolcat questions, ask them here... #359
Thanks Dennis, DEWFPO
/ If you have Toolcat questions, ask them here... #360
DEWFPO
I have my porta power set up with a test coupling that connects to to the port block. It acts like an acumulator. Pump it up to 35 psi turn the key on lower the TICs.That will release the brakes. step on the traction control after setting the direction control lever and tow or push away. FYI you may need to give the porta power a few more pumps to maintain the 35 PSI.:thumbsup:
2008 New Holland T2420 (A60462)
2008 New Holland...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
LandHonor LHR-UBF12 12in Utility Blower Fan (A60352)
LandHonor...
2014 Dodge Charger Sedan (A61569)
2014 Dodge Charger...
2006 Honda Ridgeline AWD Crew Cab Pickup Truck (A61568)
2006 Honda...
