You need balast or you will trash your front axle!!!! really?
/ You need balast or you will trash your front axle!!!! really? #321
I think it's a simple matter of the counterweight (PHD) being too light...... ;)
Can't tell the model of loader/tractor...but I think it's more than just counterweight.
Looks like the loader was only able to take enough weight off to slide the load. As soon as it cleared, down it went
In that case the ballasteer was also too "light".
/ You need balast or you will trash your front axle!!!! really? #322
Not on file, and the counter weight is off with the neighbor. He uses it to off set his front end snow blower. I use the back blade in winter.
But "visualize" an 18" X 18" X 24 + tall block of concrete with Cat 1 tool bar pin ends sticking out the sides about 6 inches up from the base, and a pair of straps with top link holes out the top. It does a great job of settling the tractor when on hilly lands, (the only kind I have ;-)
Sounds just about what my dad had on the 8N.
/ You need balast or you will trash your front axle!!!! really? #323
Your written/verbal description is good enough for me. That helps me out. Thanks, CalG.
How about one that is 8.89 cu ft ? I've had it for a little over five years now and works good.
Thanks for your picture, CB. That baby looks HEAVY! I have to ask: What is the purpose of the two, angled PVC pipes cemented in the top of the block?
BarnieTrk :thumbsup:
/ You need balast or you will trash your front axle!!!! really? #324
Storage?
See alot of guys cement in pipes to store things like a shovel, rake, axe, etc
/ You need balast or you will trash your front axle!!!! really? #325
When I had a backhoe on my tractor it took plenty of weight off the front. I had to put a 1000# weight on top of the bucket so I could steer. Without the backhoe I adapted the same weight to go on the 3ph.
/ You need balast or you will trash your front axle!!!! really? #326
Obviously a staged picture, as he could not move the stack of lumber. People do the dumbest things sometimes for a picture. Then complain when they have engine lube problems.
About the very heavy counter weights on the small tractors, consider what could happen if something breaks on the hitch. You could wind up like this photo. Except unplanned and you might wind up dead. A little caution is advised, if you need a ridiculous amount of counter weight to use the loader them you are operating beyond the loader and tractor design limits. Its all good until someone gets hurt.
/ You need balast or you will trash your front axle!!!! really? #327
1335 lbs heavy. Not counting the weight of any steel, which probably cancels out the hollow space from the tool holder tubes.
/ You need balast or you will trash your front axle!!!! really? #328
Storage? See alot of guys cement in pipes to store things like a shovel, rake, axe, etc
This, they have a hole in the bottom to let water drain out, it's around 1400 lbs give or take with the extra steel inside it.
/ You need balast or you will trash your front axle!!!! really? #329
So taking a SUBSTANTIAL load off the front axle is not difficult for this little tractor ;-)
Sounds like it! :thumbsup:
/ You need balast or you will trash your front axle!!!! really? #330
Caution and an accommodation of the specific situation. ... I have used a ridiculous amount of counterweight only once. If was during a repetitive unloading task where I wanted to keep as much weight off the fronts as possible because I had to run over grass. It prevented forming ruts.
/ You need balast or you will trash your front axle!!!! really? #331
Hand tool holders... ahh, a good idea!
Makes sense to have a drain hole at the bottom of the tubes, as water WILL get inside them one way or another; and around Michigan, with water inside the tubes, the water would freeze (in the winter) and possibly/likely damage the concrete weight itself. I doubt the ice would simply push up & out of the tube.
I like the lifting eye/hook also placed in the center of the weight. A short section of chain cemented into the block (4-5 links inside and 4 to 5 chain links exposed to the exterior of the block) would also work well for lifting purposes.
I could also see having a couple of sections of 1/2" pipe or re-rod concreted into and at the rear/top of the the weight block that could secure a lift-off diddy/tool box with a secured lid - the box would likely contain a few small wrenchs/tools, bolts & nuts, length of chain, hitch pins, a pair of gloves, wipe cloth rags, etc.
BarnieTrk
/ You need balast or you will trash your front axle!!!! really? #332
I think most of these front axle failures are due to heavy load on a paved or no slip surface . Twisting and turning with the front end engaged . The front tends to turn a bit faster resulting in a bind , then a bang .
/ You need balast or you will trash your front axle!!!! really? #333
Argeed....or running a front tire into a tall curb, stump, large rock, etc. This especially gets dicey when going down hill with a heavy load.
BarnieTrk
/ You need balast or you will trash your front axle!!!! really? #334
Do you find that shovel handles or rakes or whatever stick too far out the bottom? Could catch the ground, or brush in the woods and break a
handle? If I was doing a design like that, I'd probably but some expanded metal or something in the bottom so none of the handle sticks out
/ You need balast or you will trash your front axle!!!! really? #335
Obviously a staged picture, as he could not move the stack of lumber. People do the dumbest things sometimes for a picture. Then complain when they have engine lube problems. About the very heavy counter weights on the small tractors, consider what could happen if something breaks on the hitch. You could wind up like this photo. Except unplanned and you might wind up dead. A little caution is advised, if you need a ridiculous amount of counter weight to use the loader them you are operating beyond the loader and tractor design limits. Its all good until someone gets hurt.
I don't think it is staged picture. I think he was able to lift the stack of lumber off the trailer. Then as he backed up with the load high the tractor tipped over.
/ You need balast or you will trash your front axle!!!! really? #336
Or the load was to much he couldn't lift it off the trailer, slid it back till it came over the side and couldn't hold it
There was a guy in the Mahindra section a while back that did just that (slid 2000 lbs out of the bed of his truck with a sub cut rated to lift 800 lbs). Tractor couldn't hold it, tipped forward damaging his truck, Then blamed the tractor :confused:
/ You need balast or you will trash your front axle!!!! really? #337
This X 2
/ You need balast or you will trash your front axle!!!! really? #338
My theory as well back on post 314
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
