You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #141
Not calling anyone out because I have valued and enjoyed all of this discussion, but I do encourage some thought on this if you are still struggling. I noticed something here that a few folks are missing and it is critical.
When one loads a loader, or forks, or a grapple - that weight/force is not being placed directly in front of the axle like in the case of a snow plow on a truck. The loader connection points to the tractor are typically located closer to the operator station and thus the forces are distributed to both the rear and front axles through the tractor frame. It is the distance to fulcrum where the force acts that is important here. One can still load the bucket sufficiently to "unload" the unweighted rear, but point is you are not placing and distributing the force directly at and beyond the front of the front axle.
This concept allows fun center of gravity toys like this to function.
So - adding 1,000 pounds on your 3pt can easily and fully counter balance a full 1,000+ pounds in your loader due to where the forces are actually acting. In this case your loader force is always acting behind your front axle, and if the load is extended far enough forward, or heavy enough to push the center of gravity past the front axle, then it will tip up. (That would be the case where someone pushed down on the eagles wings and your finger is the center of gravity/front axle).
That tipping forward will never happen if you have proper counter balance beyond the rear axle, AND your operating front axle loads will be at or below a fully unloaded tractor scenario. Having counterweights protrude past the rear wheels is a little bit of a pain for agility, but placing just 500-1,000+ pounds a good distance outward of the rear axle will let you do wheelies all day with a completely full loader and a football team hanging off the loader. This is why I sometimes use a heavy duty cutter for counter weight as it places some of the weight at a greater distance and provides a greater force/moment acting on the rear axle fulcrum which in turn helps reduce the loading on the front axle in all circumstances.
To help with the wheels on ground vs lifted issue, think about the split second before your rear wheels lift off the ground. At the point, all four tires are still in contact and yet the force on your front axle is almost at its maximum stress. If you placed your pinkie finger on the loader bucket and pressed down, then the rear wheels would lift off the ground. The difference in force on front axle in those two scenarios is negligible. The force progression is continuous and nothing special happens when the rear wheels finally come off the ground. The force on the rear axle simply goes from one pound to zero pounds...
Conclusions:
1) Counter balance weight at almost any distance behind the rear axle can and will offset similar weights/forces added to the frame of the tractor and thereby front axle when using a loader. More weight, and or greater distance from the rear axle will amplify the effects of lightening the front axle load. The impacts are far greater than just a nominal 10% or so mentioned earlier since the loader is imparting its forces towards the middle of the tractor which is not too terribly much farther from the rear axle than are the ends of your three point hitch and added counter weights. (Box Blade, Cutter, etc...)
2) Center of gravity is important to understand as well as fulcrums and force amplifiers. (Distance from fulcrum, etc...) Front end loaders are designed to place the actual working forces as close to the CG as possible, but moving them up or down can change the situation drastically in seconds. This is why counter balance rear of the rear axle is so effective at correcting problems associated with overloaded front axles.
3) Perhaps your front axle might not break of wear out right away if not using proper counter weighting, but it is safer, makes the tractor handle better, and keeps the front axle loaded within its working limits so I would suggest it. (And so as not to be accused of being a hypocrite, I do use my loader without counter weighting from time to time for light work, so shame on me.) :eek:
Stay safe everyone!
this is what I was trying to get at in a humorous way in post 93. One person called me on it and the rest ignored it.
The weight of the fel and it's load is transferred to a point where the loader and the lift cylinder are attached, somewhere between the 2 axles thereby transferring some of a loaded fel's weight to the rear of the tractor.
Also the higher you lift the load the more weight is transferred to the rear axle. I have proved this many times in actual use.
When moving snow with my old Ferguson 2wd, I had a place in my driveway that had a spot where it went downhill very gently for only about a total of a 2 ft drop over 20 feet. If I drove down that drop, dropped the snow load and then tried to back up, if it was icy, I'd lose traction. If I lifted the empty bucket up 5 or 6 feet, enough weight would transfer to the rears so that I could regain traction.
It's not as simple as the sticks and weights exercise or the toy tractor example as presented in this thread. The front axle weight (and the rear axle weight) will vary because of the mounting position of the fel and it's cylinders and the height of the load.
BTW, when I took the bucket off my Fergie's fel, I could easily lift the frontend when the bh was on it, like in the pic.
   / You need balast or you will trash your front axle!!!! really? #142
Where the loader mounts is irrelevant. Its where the load is placed. ANY weight added forward of the front axle CL does NOT add weight to the rear. It takes weight OFF the rear.
Raising the load higher lesses the amount of weight taken from the rear axle, because you are simply moving the load closer (in the vertical plane) to the front axle.
Skid loaders and telehandlers have loader mounts that are even behind the rear axle. And adding weight in the loader bucket STILL takes weight off the rear tires
Oldpilgram....using a backhoe as an example......
Would you agree that a 3PH backhoe takes weight off the front axle?
What about if you had the same size/weight backhoe but was a frame mount that the frame attachment point is clear up at the front axle? Would that somehow act like a big revers counterweight and overload your front axle?
   / You need balast or you will trash your front axle!!!! really? #143
of course the point at which the loader is attached to the frame moves some of the weight to the rear... the further back it's attached, the more weight is transferred.
Why do you think that a skid steer has it's loader pivot over or even behind the rear wheels? It's not for looks. It's to move the weight back so it doesn't fall on it's face. Put the hinge point further forward and more weight moves to the front.
The further back, the more weight is on the back. The higher the load, the more the weight shifts to the pivot point of the loader resulting in more weight on the backend.
   / You need balast or you will trash your front axle!!!! really? #144
Wow James that sounds like a hair raising experience! So the 3 point ballast would not have kept the rotation of the tractor around the front axle pivot from continuing?
Would have thought the 3 point arms/top link would at least keep the tractor from going over- unless it was to flip also?
I can't say that 3 point weight has not caused problems for me either...
One time trying to push dirt back with the Gannon boxblade the force caused an old weld to break on the left 3 point arm mount.
The left rear tire (14.9x 28) backed over the gannon and went up in the air (wife said 2 feet!) before I could get the clutch pushed in and slammed me into the ROPS ringing my bell pretty good.
Luckily No front axle damage was done :laughing: can't say the same for the mount on the Gannon and my pride,we all make mistakes and stuff does happen, hopefully we all learn from mistakes and experience.
Thats a good question, and also would the angle of the rollover have caused the rock to hit the ground before the point of no return? I don't know, but I pushed it back and the roll was in a static condition. I was not willing to find out if it would have went all the way over or not..:eek: I was glad when the wife went around to the high side and dropped the loader joystick, and the high side tire then hit the dirt.
   / You need balast or you will trash your front axle!!!! really? #145
of course the point at which the loader is attached to the frame moves some of the weight to the rear... the further back it's attached, the more weight is transferred. Why do you think that a skid steer has it's loader pivot over or even behind the rear wheels? It's not for looks. It's to move the weight back so it doesn't fall on it's face. Put the hinge point further forward and more weight moves to the front. The further back, the more weight is on the back. The higher the load, the more the weight shifts to the pivot point of the loader resulting in more weight on the backend.
Simply not true. How else would you mount the loader on a skid steer? If you move the arms forward it is going to compromise the lift height or move the load farther out which comprises load capacity. As you lift up the weight does redistribute to the rear axle, but simply because the weight moves closer to the front axle. A skid steer doesn't tip over because the load is much closer to the front axle than a tractor, and a skid steer is quite heavy to counterbalance the load. You could move the location of the arms anywhere on the machine and as long as the distance between the bucket pins and the front axle doesn't change it won't make any difference.
LD-1 is absolutely correct. And I am a non-professional engineer :laughing:
Sorry for busting zzvyB6 but I've know a lot of MIT engineers who couldn't engineer their way out of a paper bag!!
I had two different roommates in college, both engineers, who whenever they were stuck on a problem would ask me to explain it to them - because I was really good at that stuff. I was of course... a music composition major!!! (at the time)
I think there is a lot of confusion because people don't necessarily explain their positions clearly & completely (myself included). Or the reader doesn't understand what they are trying to say even if it is reasonably clear (myself included). Or the reader gets tired of reading all these long winded comments and quits halfway through to respond (myself included). And maybe one of these possibilities is the case with this example.
But in case it's not, if anyone thinks the attachment point of the loader makes a difference as to how much weight from a rock in the bucket of the FEL (not the fell itself) is transferred to the front vs rear wheels, that person needs to start a post # 1 of this thread and read the whole thing again! :laughing: If said person still believes the attachment point makes a difference, I suggest you seek empirical evidence of your claim (please be sure to adjust for the inevitable weigh shift when you move your loader attachment ) :)
You are absolutely correct that having a loader further back on a machine moves more weight to the rear compared to the front of a machine. You are absolutely incorrect that the hinge point has anything to do with it. It is completely dependent on where the weight is, not where the hinge point is.
Skid steers are designed how they are mostly to keep them compact. Also to keep the front wheels close to the load and minimize the leverage arm created by the portion of the loader/bucket that is forward of the front axle. Wheel loaders typically lift more weight than similar size skid steers and they don't have the pivot point in the back.
   / You need balast or you will trash your front axle!!!! really? #148
After 147 posts I've decided I'll keep the 1100 pounds on the 3 point. It works for me!
   / You need balast or you will trash your front axle!!!! really? #149
   / You need balast or you will trash your front axle!!!! really? #150
I'm not an engineer but I did take several years of physics in high school and college. Maybe the laws of gravity and deflection have changed since then.
Perhaps I've said it wrong.
The lift cylinder anchor point to the tractor is where the weight is actually lifted. The further back that lift point, the further back the weight is applied to the tractor. I incorrectly stated the pivot point of the loader.
With the skid steer, the pivot point is over the rear axle so the lift point of the cylinder can be further back so more weight can be supported by the rear axle (actually spread the weight more evenly over both axles by moving the weight to the rear).
If people say that is wrong, then it's a matter of semantics or you guys are all nuts!
CFG Industrail MX15RX (A53317)
CFG Industrail...
Bucket (A55973)
Bucket (A55973)
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
NEW Landhonor LHR=EPC40 Plasma Cutter (A59000)
NEW Landhonor...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
