mow or graze
/ mow or graze #1
dennisleary
Brooks, Ca
kubota 4760
I have a dilemma and I wonder if someone could help out. I unexpectedly came into possession of 23 acres of oats/vetch, and I'm trying to figure out the best course to take. One thing I was considering was to mow it all down using the rotary cutter, and then find someone to bail it, or disc it in.
The other thing I was thinking about was just to mow it and use it for mulch, just let it sit. I'd say the vetch is a few weeks away from flowering.
the third thing I'm thinking about is to have the plot grazed down by goats - I found a guy in fresno who is willing to bring up 600 goats to tackle the job. I like this idea because the goats would manure the field a bit, and save me time/fuel.
Seeing as how my long term plan is to put an orchard on the acreage, and I want to bring the soil fertility up in the meantime, does anybody have any recommendations about what to do? Thanks.
/ mow or graze #2
I like the idea of the goats doing the job and your field getting fertiliser out the deal. A chain harrowing job after the fact will clean everything up and you'll be able to see the lay of the land better.
However, on top of a reliable source of water that all livestock requires, goats need a specific type of fencing in order to keep them in and your neighbours happy as a result.
/ mow or graze #3
It won't be worth baling if you cut it with a rotary cutter.
/ mow or graze #4
Oats and vetch make great cow hay and ti builds up the land as well. We raised it on 11 ac field for a few years and had to quit. My dad was 6' 1" and it was taller than he was. We cut it and bailed it and then raked it and bailed i again. I have never seen anything like it before or after. Ed
/ mow or graze #5
I like the goat idea also. Along with adequate water and fencing - do you have close neighbors that might object to 600 goats. I know just a few of the little beasties can raise quite a stink. 600 would be a whole other matter and might lead to questionable neighborhood relationships.
/ mow or graze #6
If the neighbours don't like the smell of his goats, they can move. :)
/ mow or graze #7
Goats are escape artists so good fences are mandatory. The natural route seems to offer the most benefit and least effort. An occasional burn can be good for the soil as well.
/ mow or graze #8
If you don't have to put any money into it, the goats are your best bet. Forget about baling anything you cut with a rotary cutter. Since your long term goal is an orchard, make a deal with a local cattle, sheep, or goat producer to graze the land until you are ready to plant an orchard. Oats are an annual so don't expect much after it's grazed off. You'll either have to inter-seed perennial grasses or replant annuals every yea. With careful grazing you can improve the land with minimal expense. It will require some good fencing and stock water but you can also charge by the head for providing the feed and water.
/ mow or graze #9
If you have turning plow, I would recommend just turning it all under to naturally compost. The organic matter put back into the soil is going to be much better than a bunch of little pills of goat crap that may end up in one localized spot. Vetch is a nitrate producing plant so it makes for good fertilizer when turned under.
/ mow or graze #10
Any time we have tried to bale winter grass it's been a real pain to get it dry enough. It takes at least a week to cure and spring weather is very unpredictable here. You live in sunny Ca so probably not a problem for you.
/ mow or graze #11
That's what I'm looking at currently. I ran Haygrazer for high volume production for years, but with the funny weather we have been having it wasn't working out. So Last year I started in on Rye (fall planting) in that field. With our monsoon spring last year I got rained out and baled a very mature crop. This year I planted in our recent dry, warm spell, and maybe I can get it off a little later when ripe for the picking. Farmer's Almanac says normal rain for the spring. We'll see.
/ mow or graze #12
My biggest concern for this situation would be; I'll say I like the goat idea.
When the land has been eaten down and it's time for the goats to go, do you trust the goat owner to come get his goats and go?
/ mow or graze #13
Every year the Goats-R-Us comes through for fire abatement... they charge $800 an acre to do the work.
The fence is simple rebar with a single insulator that is electric... several hundred goats with one goat tender in a slide in camper and two herd dogs...
The dogs are awesome... they never rest and two dogs keep the herd in check...
Goats R Us - Home
/ mow or graze #14
Goats R Us - Home
Something like this what I figured OP meant when talking about goats. Looks like we'll never know as he has started 6 threads and doesn't reply to any.
/ mow or graze #16
They come every Spring... it is a big deal... if not addressed the city/county can and has hired the work out and liens the property... they also charge for reinspect ion here.
It was not always this way and some have gotten in trouble for being too aggressive like discing or tilling in a endangered species zone.. mowing is preferred... grazing ok.
/ mow or graze #17
Mowing and then turning soil fastest way to start on your next project. Grazing goats take time and money. I have been using a few goats to get a pasture area under control. They are fun and provide for some good fertilizer. I help remove trees and shrubs after they kill them. I also mow it late in fall just to clean up stubble. The goats do the rest. 7 goats per acre is recommended but for a fast clean up 600 would look like a locust plague! 😀
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
