If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #331
One big difference is the toolcat will not move or dig dirt like the 247 can. Good luck
But it will still move dirt. This is a toothed 1 cubic yard Versahandler bucket.
/ If you have Toolcat questions, ask them here... #332
I'm considering purchasing a toolcat for my 50 acre farm. I'll use it for mowing, post hole digging, loader work, utility work, etc. Two questions:
1). Can anyone confirm if a CAT 247B attachments will fit on the Tool Cat? I have a grapple rake, post hole digger, bucket, and fork.
2). How does a price of 55k sound with the 72" mower?
I plan to sell my multi terrain CAT, a kubota 331 zero turn and Yamaha rhino and consolidate into one machine. We'd prefer a machine with a cab and AC; that's the impetus for making the change.
Any advice/thoughts would be most appreciated.
JW
You didn't say 5610 or 5600. new series G or leftover series F.
If a 5600 G, be sure it has traction control (HTC).
/ If you have Toolcat questions, ask them here... #333
Xfaxman absolutely correct. I'm probably just more skilled with the CTL 247 digging than I am with my toolcat.
/ If you have Toolcat questions, ask them here... #334
I'm considering a 5600 new series. I don't need the rear PTO and the dump box would be useful.
/ If you have Toolcat questions, ask them here... #335
JW
Yep, 55K sounds good. :thumbsup:
But check for any special discounts at the time you buy it.
/ If you have Toolcat questions, ask them here... #336
4570Man
What I forgot to mention is that the mowing we do is path cutting around our field perimeter more so than tight turning radius cutting. A lawn service cuts around our home. I believe the 72" front mount mower should do the job. Thanks for your feedback.
/ If you have Toolcat questions, ask them here... #337
I've got a Bobcat 62" Lo-Profile bucket for the Toolcat and I haven't been impressed with it's digging capability. There are provisions to add a bolt-on tooth-bar to this bucket and am thinking that this will help digging. Does anyone have any recommendations on a tooth-bar that's not priced like it's made of "Unobtanium"?
Thanks, DEWFPO
/ If you have Toolcat questions, ask them here... #338
Thanks, DEWFPO
Mine are individual bolt on teeth, two bolts each. The dealer threw them in as a discount when I bought the Versahandler bucket.
There are several styles for sale on eBay.
The teeth sure make it dig better.
/ If you have Toolcat questions, ask them here... #339
Thanks Xfaxman, this looks like a good cost effective solution for me.
DEWFPO
/ If you have Toolcat questions, ask them here... #340
Have a model A and for the last week it been acting funny. Engine runs goodand all the rest but when in drive, it will slow down and same for engine rpm 2 or 3 seconds. Today it stalled the engine when snow plowing but wasn't moving realy fast. Looks to me the drive pumps are failing. Could it be something else. Any experience with that kind of snags. Thanks.
Compressor (A55973)
Compressor (A55973)
2012 PETERBILT 386 SLEEPER (A59906)
2012 PETERBILT 386...
2012 MACK PINNACLE WINCH TRUCK (A60736)
2012 MACK PINNACLE...
light tower (A60352)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
