If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #321
Axle matching will de-stroke pump on the faster turning axle to slow it down to match the other. That is why when one motor gets weak or fails drive stops with axle matching on because it de-strokes the good working pump/axle to match the speed of the bad one.
Thanks,I remember now. I'ts been a few years since my last Toolcat school.:thumbsup:
/ If you have Toolcat questions, ask them here... #322
I have a line in a toolcat that runs and looks very clean but has very high hours (9000) Other than the engine what are other things to be concerned about for service/repair with those hours?
It's a 2011 toolcat 5600 for reference.
/ If you have Toolcat questions, ask them here... #323
Thats a lot of hours! My only concern would be drive motors and pumps getting tired. You also can ask to have a dealer plug into the unit and get a warning code history. This will tell you if the unit was ever overheated,low oil PSI,thing like that.
/ If you have Toolcat questions, ask them here... #324
Thanks for the suggestion, I've just asked for that. Part of the problem is the unit is three states away so it's not like I can just pop over and look at it.
/ If you have Toolcat questions, ask them here... #325
Are you positive it has 9000 hr. or could it possibly be 900 hours? The hour meter on these read to 1/10th. 9000 hrs. on 4 year old machine averages out to little over 8 hours per day, 5 days a week.
/ If you have Toolcat questions, ask them here... #326
It's 9000 and the price reflects it. Was owned by a large cattle company used mainly as a sweeper/snow blower.
Runs and everything works but dealer said it does smoke some and it is being sold as is. If I bought it I'm essentially figuring I'd be replacing the motor in fairly short order just wondering what else to be thinking about. Body is very clean.
/ If you have Toolcat questions, ask them here... #327
I'm considering purchasing a toolcat for my 50 acre farm. I'll use it for mowing, post hole digging, loader work, utility work, etc. Two questions:
1). Can anyone confirm if a CAT 247B attachments will fit on the Tool Cat? I have a grapple rake, post hole digger, bucket, and fork.
2). How does a price of 55k sound with the 72" mower?
I plan to sell my multi terrain CAT, a kubota 331 zero turn and Yamaha rhino and consolidate into one machine. We'd prefer a machine with a cab and AC; that's the impetus for making the change.
Any advice/thoughts would be most appreciated.
JW
/ If you have Toolcat questions, ask them here... #328
I have never used a tool cat, but I can't imagine you will be happy mowing with one after owning a ZTR.
/ If you have Toolcat questions, ask them here... #329
I have a line in a toolcat that runs and looks very clean but has very high hours (9000) Other than the engine what are other things to be concerned about for service/repair with those hours? It's a 2011 toolcat 5600 for reference.
Unless it was dirt cheap I would have to pass. Have you seen what a replacement engine cost? I'm sure everything else that is bound to break isn't cheap either. When you have a high hour piece of equipment or a high mileage vehicle you better be prepared to spend money fixing it.
/ If you have Toolcat questions, ask them here... #330
I can confirm that. I have both and they are interchangeable implements. However that being said, I feel that the two pieces of equipment are complimentary to each other. Although they could overlap many of the tasks we do here, some of the task would be very difficult if not using the correct one. ie: toolcat is great for traming rolls of hay were the 247 would take very long, however the 247 is better suited for stacking rolls at the barn. 247 is better for feeding in the knee deep mud of the feed lot where the toolcat would become stuck. Toolcat is great for carrying tools and ppl for chores liking fence repair or cutting firewood,247 not so much. One big difference is the toolcat will not move or dig dirt like the 247 can. Good luck
/ If you have Toolcat questions, ask them here... #331
But it will still move dirt. This is a toothed 1 cubic yard Versahandler bucket.
/ If you have Toolcat questions, ask them here... #332
JW
You didn't say 5610 or 5600. new series G or leftover series F.
If a 5600 G, be sure it has traction control (HTC).
/ If you have Toolcat questions, ask them here... #333
Xfaxman absolutely correct. I'm probably just more skilled with the CTL 247 digging than I am with my toolcat.
/ If you have Toolcat questions, ask them here... #334
I'm considering a 5600 new series. I don't need the rear PTO and the dump box would be useful.
/ If you have Toolcat questions, ask them here... #335
JW
Yep, 55K sounds good. :thumbsup:
But check for any special discounts at the time you buy it.
/ If you have Toolcat questions, ask them here... #336
4570Man
What I forgot to mention is that the mowing we do is path cutting around our field perimeter more so than tight turning radius cutting. A lawn service cuts around our home. I believe the 72" front mount mower should do the job. Thanks for your feedback.
/ If you have Toolcat questions, ask them here... #337
I've got a Bobcat 62" Lo-Profile bucket for the Toolcat and I haven't been impressed with it's digging capability. There are provisions to add a bolt-on tooth-bar to this bucket and am thinking that this will help digging. Does anyone have any recommendations on a tooth-bar that's not priced like it's made of "Unobtanium"?
Thanks, DEWFPO
/ If you have Toolcat questions, ask them here... #338
Thanks, DEWFPO
Mine are individual bolt on teeth, two bolts each. The dealer threw them in as a discount when I bought the Versahandler bucket.
There are several styles for sale on eBay.
The teeth sure make it dig better.
/ If you have Toolcat questions, ask them here... #339
Thanks Xfaxman, this looks like a good cost effective solution for me.
DEWFPO
/ If you have Toolcat questions, ask them here... #340
Have a model A and for the last week it been acting funny. Engine runs goodand all the rest but when in drive, it will slow down and same for engine rpm 2 or 3 seconds. Today it stalled the engine when snow plowing but wasn't moving realy fast. Looks to me the drive pumps are failing. Could it be something else. Any experience with that kind of snags. Thanks.
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2013 Ford Taurus Sedan (A61569)
2013 Ford Taurus...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
