3PH / Backhoe hose loop bothers me.
/ 3PH / Backhoe hose loop bothers me. #21
:thumbsup:
/ 3PH / Backhoe hose loop bothers me. #22
Were you able to order new hose end fittings so you can shorten the existing hoses? I saw at my local NAPA store that they have a hydraulic hose end crimper in store for customer use.
Not yet.
I haven't decided if I'm going to shorten the hoses or have new ones made. It depends on costs. My valve is supposed to come tomorrow and I'll be taking measurements, notes, then head to Spokane to get the fittings & hoses, where they make them in house. The biggest issue is getting to the rear fitting under the seat but I'm sure I'll manage when it comes time to do it.
/ 3PH / Backhoe hose loop bothers me. #24
Not yet.
Take off the entire seat/frame- that's what my dealer did, when installing my second remote, and I did again later when installing a rear mounted diverter for my T-N-T cylinders. That way it's easy to plumb things exactly where you want them to go.
Ok, I assume it will be self explanatory as I start to remove the seat then next the base/cover correct?
My valve came today BUT, it was missing the mounting holes that I was looking forward for it to have. (sigh) a little delay. :-/
/ 3PH / Backhoe hose loop bothers me. #26
Clamp it down with one or two square U bolts. :thumbsup:
Bolting it on with those is like failing to put a cherry on top of a perfect sundae.
In other words, **** no! ;-)
/ 3PH / Backhoe hose loop bothers me. #28
Heard that!
Can't you take the assembly to a metal fab shop and have them bend/punch a bracket to your specs? That's what I'd do- then you get exactly what you need from whatever metal you choose?
I do this kind of thing all the time- there is a good metal shop not too far away, and they take a few days, but give me what I ask for....
I can fabricate. I just prefer to stick with the original plan. No sense going the trouble when I can get the correct valve delivered to me rather than spend more $ and time to make a bracket when it's unnecessary.
/ 3PH / Backhoe hose loop bothers me. #30
BUMP Did you get this project finished?
/ 3PH / Backhoe hose loop bothers me. #31
inquiring minds want to know. ;)
Getting close! I got the correct valve & T fittings and I'm now waiting for these specialized couplers with female JIC's that I ordered. (fingers tapping)
Then when they come in, I'll take off the hoses to get them cut/fitted with the customized ends, make a simple bracket, and slap it all together.
I'll promise pics.
All the parts came it today and they are exactly what I hoped except for the Stucchi flat faced couplers which was a little bigger than I expected but not a problem.
I went and got new hoses made, which had to be measured carefully and the orientation of the end fittings is very important because you can't just twist the hoses. All the ends have 90° JIC ends.
I made the bracket and the paint is drying at this point but I was able to dry-fit everything. The pics shows the female coupler on the right, male on the left. I switched sides (after the pics were taken) to give more clearance of the TnT which clears the couplers. Late tomorrow, it will be complete & reassembled with final pics. In the meantime, check out the progress.
/ 3PH / Backhoe hose loop bothers me. #34
Gooder-un :thumbsup:
All done!
I decided to use the valve handle as a "key" and store it in my tool box to prevent accidental switching.
This shows the position of the TnT cylinder at the highest position. Absolutely no obstruction at all. Better than I envisioned.
With the BH hoses connected, it still allows ample slack even with the tractor loop removed. MUCH better!
It was a fun project thanks to ALL who contributed suggestions & ideas, it wouldn't have reached this level of quality without you guys and I truly appreciate it!
/ 3PH / Backhoe hose loop bothers me. #36
Yep, that is the way the factory should do it :thumbsup:.
/ 3PH / Backhoe hose loop bothers me. #37
For those who want to go this route what was the final cost to do this? Looks nice.
The valve was $32.40, the custom hoses about $75 (you could probably go cheaper), 2 "T" fittings are $15 ea. The flat faced couplers were $170 for two pairs of couplers. A little over $300 for this setup. Worth every penny to me. The couplers had a nice benefit of having very little fluid loss when decoupling and easy to wipe clean. Also, it has an accidental release protection built in. To release, the collar has to line up with the indentation on the backside.
The major factor was the lack of a particular T fitting that I was looking for but didn't exist. The one I got has #10 JIC on each end and a #8 ORB on the side port that connects to the valve. If they'd make one end a NPT, the overall cost would have plummeted to approx $140 since I'd be able to reuse the couplers. It's important to know that the JIC & ORB allows fixed mounting position whereas the NPT doesn't. This wouldn't matter on the coupler ends. I could use adapters but this would have made the assembly too wide and I wanted it tight between the 3PH arms.
John Deere 7700 (A64119)
John Deere 7700...
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
