You need balast or you will trash your front axle!!!! really?
/ You need balast or you will trash your front axle!!!! really? #183
My Daddy always said "never play another man's game". :D
Using your much more eloquent description, there is a situation where adding rear ballast weight adds to the forces experienced by the front axle rather than lessening it.
I think ovrszd is absolutely correct. There is one instance when adding rear ballast (counterweight) INCREASES the static forces on the front axle...
When the rear tires are off the ground! (am I right ovrszd?)
/ You need balast or you will trash your front axle!!!! really? #184
Correct. Until the rear tires return to Earth, the more counter ballast you stack on the rear, the more force is exerted on the front axle. :)
/ You need balast or you will trash your front axle!!!! really? #185
:cool2::drink: Who needs an engineering degree!
There is another... when they are still on the ground but have allowed you to lift a weight with your FEL that you could not have lifted without the 3pt counterweight.
And yet another... when you are facing nose down on a steep enough hill with or without weight on the FEL
/ You need balast or you will trash your front axle!!!! really? #188
Very good Ron!!!! :)
/ You need balast or you will trash your front axle!!!! really? #189
yes an interesting phenomonen occurs when I have my little light 5 foot scrape blade on my tractor that I use to repair my gravel road. In interesting thing happens if I don't keep the tractor in 4WD. When I go to get a bit of gravel from the gravel pile and I go down the steep hill nose first in 2WD, the rear tires become so light that the compression braking(or stomping on the brake pedals for that matter) wont keep the tractor from going down the hill at a high rate of speed.. Wheeeee.. down we go.
You can hear the rear tires slipping on the gravel because they are so light there is no traction any more. The COG of the tractor has shifted towards the front and with even a light load of gravel in the bucket there is not enough ballast on the 3pt with the light blade to keep the rear tires planted hard on the road surface, so they slip. If I put the ballast barrell on that doesn't happen with light loads. Of course if I keep it in 4WD it doesn't happen either.
Of course If I wasn't an idiot, and backed down the steep slope, it would not happen in 2WD either as the COG would shift to the downhill side once again, but this time placing more weight on the leading axle which in this case is the rear one.
/ You need balast or you will trash your front axle!!!! really? #190
But how many Beers can you drink?:rolleyes:
/ You need balast or you will trash your front axle!!!! really? #191
Just imagine all the physics/math calculations your tractor has to go thru so it knows how to act in a given scenario.:thumbsup:
That's why all the new tractors have computers. ;)
/ You need balast or you will trash your front axle!!!! really? #196
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=458316"/>
I saw my first yellow jacket of the season. That's one nice thing to not worry about during winter.
/ You need balast or you will trash your front axle!!!! really? #197
I haven't seen any of Satins evil companions yet, but it is still February.
/ You need balast or you will trash your front axle!!!! really? #198
/ You need balast or you will trash your front axle!!!! really? #199
/ You need balast or you will trash your front axle!!!! really? #200
If you lift 1000 pounds with the FEL your adding a 1000 pounds to the front axle regardless how much weight you have on the rear.
Ballast on the rear helps with keeping the rear tires in contact with the ground but it doesn't take any load off of the front axle.
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
