L185 2wd smoking after warmup
/ L185 2wd smoking after warmup #11
The tractor had been sitting around before I picked it up, would that make the rings stick? (I was reading that could happen) I could flush the engine or is that a NO NO?
I would just use a quality oil and run it for a while. I have known people in the past that used the 5 minute oil flush added to their oil and ended up spinning their cam bearings.
/ L185 2wd smoking after warmup #13
The reply by Agvg above would be my recommendation as well. Be sure the thermostat is functioning correctly and make it work and get hot while the oil in the crankcase is fresh. Fully warm then a good workout.
/ L185 2wd smoking after warmup #14
As said before work it hard and make sure it runs up to temperature, also give it a heavy dose of fuel conditioner. Make sure it has fresh clean diesel.
Ok, I will drain the diesel that is in the tank, It was full when I bought it and I have not used it all it. I thought It did not have a thermostat? I will check again.
/ L185 2wd smoking after warmup #16
You are right it uses a siphon system. So you are good that way. Work it hard.
/ L185 2wd smoking after warmup #17
You may be correct on the thermostat. Make sure the screen for the radiator is clean and you have good air flow through the radiator before you work it hard.
I drained the diesel out of the tractor today, The diesel was brown? and smelled like oil from the furnace. So I put a little clean diesel in it and dumped that. I put more clean diesel in it and ran it a little. I did not get any diesel conditioner today but I will go to napa tomorrow for some.
I used the L185 today to just pickup driveway stone after raking, I noticed less smoke after 10 minutes or so. So could it be the crappy fuel I took out? The clean diesel was almost clear. I also put some Stanadyne diesel conditioner in the diesel.
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2011 FORD F-550 (INOPERABLE) (A60736)
2011 FORD F-550...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2013 Ford F-550 Ambulance (A59230)
2013 Ford F-550...
