gladehound
Well there are people who still believe the earth is flat. Better known as the Flat Earth Society.
duh - how else would the earth be!
Well, there you go. If he don't get it after seeing this, he is never going to get it.
I would be extremely surprised if either tractor makes it to 5,000 hours with solely loader use without major overhaul. Tractors simply aren't made for this kind of abuse. If you need 5000 hours of loader service than you should have bought a wheel loader.Well, its a complex question to answer, small tractors with an very light duty front axle will of course have more use of it in most lifting applications than a 300hp Fendt with super HD axel. But the answer is yes you reduce the wear. Im quite sure you will se very different wear on two tractors one with a suitable ballast and one with filled tires after 5000h of loader use.
A cube????duh - how else would the earth be!
And what's your opinion on the lever arm length ( 3 point ) that he needed to achieve his result....
For those with a quick attach loader, removing the bucket/ forks etc when not in use would do as much for the front axle as a 3pt weight box that is 3x to 4x heavier than the attachment removed from the FEL. Might make me pay a little more attention to having an attachment on when I don't need it. Sure would like my front axle to last as long as I have my tractor, while if I'm lucky could be 45 more years.
We have a JD model A in the family an no problem with the tricycle front end after 80 years or so. But no loader and it hasn't run a lot in the last 30 years.
I don't think there is a problem with most of the newer tractors today as all of them seem to have heavy duty front axles. But I can easily remember when the Deere 4020 equipped with a fel could have axle problems. Some of the farmers back in the day would put a front axle from a 5020 on as a replacement. As fels have become a "must have" I don't see it as an issue today.
If you ballast your tractor for the loads anticipated it will perform better and be safer to operate.
It was a ~2' by 3' by 2.5' ish chunk of concrete with chunks of steel and granite rocks in it which weighs 2000# per our truck scale. It is mounted on a set of 3 point forks.Would be curious to know the dimensions of that weight and wheelbase and all.
For 2000# on the 3ph to remove 3000# from the front, one would think the weight would have to be 1.5x the wheelbase behind the rear axle.
If you say it was only about 5' back the wheelbase would have to be just 40".
I know you were guessing/assuming on numbers, and scales don't lie. But either that weight was alot heavier, or alot further back
No. Its wrong because we a re not talking a static condition. Enuf has been said about the greater front loading possible with rear ballast that it should have been called to your attention as obvious. If you use your loader lightly, counterweight will reduce front load. If you use your loader to capacity pushing and lifting, then rear ballast and counterweight will enable much more weight on the front axle -- up to the combined weight of the entire tractor, its ballast and counterweight, and the load supported on the loader. The tractor will move but not travel in this condition because the rear wheels are skimming and you cant steer. If you use the loader a little lighter duty youre able to steer and travel as needed with about 90% of all combined weight on the front axle.We had a big discussion on this last summer? With oversized and he did not believe it aboutballast until he did a real test on the scales. Now he is a believer.
When I needed to move a bunch of logs I did that except the boom was in the closet position. That is too much ballast and causes the tractor to bounce. If I extend the boom out it will lift the front wheels off the ground. I'd say that relives the stress from the front axel.Ballast? Put on a backhoe, cradle a big rock, extend the dipper and lower the boom. Just watch out turning around![]()
It would have to be pretty long or a whole lot of weight, but you don't want to achieve my results. With such little weight over the front you can't steer without the split brakes.And what's your opinion on the lever arm length ( 3 point ) that he needed to achieve his result....
