Best way to fix these?
/ Best way to fix these? #1
jdl25
Wendell, NC
Kubota L185, L2650
I was not sure what forum to place this request for help in. Please move it if it needs to be moved.
These are fenders off of a Kubota L185.
Are they too far gone? What is the best way to fix if possible? I do not have experience with body or sheet metal work. I have a welder and hammers and sanders...
I am not expecting a showroom finish this is a working tractor. I knew that the metal was in rough shape but did not expect to find this much rust underneath. At some point in the tractor's life there was a poor rattle can paint job. The hood looks good sanded down.
Thanks,
/ Best way to fix these? #2
For functional repairs you can always sand/grind to bare metal and fiberglass patch as well as use bondo (body filler).
Hammer back to shape any dents first.
Big secret is to get to bare metal when doing any body repairs otherwise patches and fillers won't adhere.
Fiberglass and Bondo can usually be sanded back to conform to shape and the norm is to final fill with a finishing putty that then is fine sanded prior to painting. (for a tractor you might skip finishing putty)
I would avoid spray can finishes in favor of good automotive primers and heavier paints sold by the quart.
Use a spray gun if you have one and if not you might just resort to a fine quality brush and carefully apply a brushed on finish.
One trick I have used is to spray the undersides of fenders with automotive gravel guard that body shops usually use on rocker panels.
(kind of a rubbery finish that prevents chipping and is actually paintable)
Hey, good luck and I'm betting that that L185 will look just great once it is all the same color!
Places like Tractor Supply have matching tractor paints 'by the quart'.
Ten four, thank you. I will update with progress reports.
/ Best way to fix these? #4
Those look like they are rusted through in places. You might need to weld a patch on the back side and then fill with bondo.
/ Best way to fix these? #5
;) Take it to American Restoration and have it featured on a prime time television show.
/ Best way to fix these? #6
Several places are rusted through. You will not be able to sand and paint. If your good at sheet metal then patch the rusted out areas.
I would look for a used fender. You may get lucky and find one.
As PILOON stated a spray gun will give the best results.
/ Best way to fix these? #7
If you can sandblast it clean you could get an inexpensive fiberglass patch kit from wal mart (the one with the glass cloth) and make that fender look almost new. As stated above use the implement paint from the local farm supply and spray it on.
Nothing will work very well unless you clean all that rust off really good.
Post some pics when you get it knocked out.
/ Best way to fix these? #8
I would not use fiberglass on a tractor fender. It will never bond to the metal good enough to not separate. Sand blasting would be best to get it clean, but if I didn't have a way to do that, or want to pay for it to be done, then I would just sand it as good as I could. Then I would go to a place like Sherwin Williams and get a product used to seal and kill rust. I forget what it's called, but it comes in a spray bottle and you just squirt it on and let it dry overnight. Then fill the rough areas and holes with bondo, sand, prime and paint. Rustolium has a really good primer. It's a couple bucks more per spray can, but worth it.
/ Best way to fix these? #9
rust reformer is the product you were thinking of.
Amazon.com: Rust-Oleum 215215 Stops Rust Rust Reformer Rust Reformer 10.25-Ounce Spray-Color Black: Home Improvement
/ Best way to fix these? #10
That's not what I've used. It comes in a squirt bottle like windex and it has an acid in it, along with other stuff. You wire brush and sand the rusted areas, then spray it on the bare metal. I've used it on railings and outdoor brackets for clients. The next day it has a bit of a sheet to it that you just paint over.
I looked on their website and didn't find it. I just tell them at the store what I want and that's what they sell me. I know there are others brands out there, that's just the one I have experience with.
/ Best way to fix these? #11
I have used and still have some of the brush on kind, I suppose you could put it in a spray bottle as well.
Rust-Oleum Rust Reformer, 8 oz - Walmart.com
/ Best way to fix these? #12
Might be the same thing. I know that Sherwin Williams re-labels some things. How did the brush on stuff work for you?
/ Best way to fix these? #13
If you can't find a replacement or want to try this first, clean up the rust, use converter then try some tiger hair ever coat. Then sand it again and try body putty to smooth it more, sand, prime and paint.
/ Best way to fix these? #15
The active ingredient for rust repairs is phosphoric acid. I have a gallon jug from Lowes under the Ospho name or something like that. It converts rust to iron oxide and turns it black. Have sprayed it on, let it dry, and painted right over it.
On that fender I would just treat the rust and bondo it.
It's a work tractor! Rattle can the sucker.
/ Best way to fix these? #16
Pretty well, It turns the rust into a black, surface. that paint will stick to. And stay stuck on. of course it still like like a rough surface, but at least the rust is halted and the paint will stick.
/ Best way to fix these? #17
Sounds like the same thing, or it's very, very similar. Probably a lot cheaper at Walmart. I think I paid close to $20 for a bottle similar in size to window cleaner the last time I bought it from Sherwin Williams
/ Best way to fix these? #18
The watery stuff that can be applied with a spray bottle is Skyco OSPHO, I have a gallon in the shop. It's good for getting into areas like behind fenderwells in car trunks and such. There are also several thicker ones that you brush on that kind of encapsulate the treated rust in an epoxy-like shell, which works really well on battery trays and marine application where rust has taken particularly egregious action. Duro makes one that I know of. My neighbor used POR-15, if I recall it was a two part polyurethane type that was a bit labor intensive but produced fine results.
/ Best way to fix these? #19
I used rust converter many years ago with great results, but haven't seen it or used it in many years. I need to pickup a can. Very handy to have around with tractors and equipment. I really like using it in cases where there are seams or places you can't get to or see.
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
