Crazy idea for a welding table?
/ Crazy idea for a welding table?
Apologies as I haven't read any replies yet... I love the idea... but I think the length of your plate is a little long and will not be flat. For that size you need better support reaching nearer to the ends in my opinion.
But I did just what you are proposing... I salvaged an old Craftsman roll away tool chest out of a recycle dumpster, fixed it, and tacked a 4ft long 1/2in plate on top of it. I have limited space and until I can afford the space and the cost, it does fine for small work. I use an auxiliary roller support table for bigger jobs and the real big ones still on the floor unfortunately. Make a custom stand with heavy duty casters and you can maybe build in a tool chest or shelfs or...
I agree, it will need some additional support. I thought I could incorporate it into the brackets to attach the top to the tool chest.
/ Crazy idea for a welding table? #43
Here is my welding table. I can load and unload the object to be welded from a truck and it is adjustable height. Like some other members I have a welding table, but has so much crap piled on it I use the forklift instead. Also my welding table can't lift a 500 pound backhoe bucket onto it. image-1044072023.jpg image-3516181774.jpg
/ Crazy idea for a welding table? #44
Don't forget to mention 'infinite height adjustment'! :)
Terry
/ Crazy idea for a welding table? #45
Don't forget to mention 'infinite height adjustment'! :) <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=458022"/> Terry
Not infinite, just between 0 and about 15 feet. 😀
/ Crazy idea for a welding table? #46
/ Crazy idea for a welding table? #47
Being a 'shorta$$', that's pretty much infinite to me. :D Terry
It is also higher than the ceiling where I park my forklift and higher than my mig leads are long. I could move to the other part of the shop and use the stick welder and a ladder though. dde00
/ Crazy idea for a welding table? #48
Problem with a larger table is the larger project you build on it then find out you have no way of lifiting it off the table. No, not going to say it was me.
/ Crazy idea for a welding table? #49
That is where my mobile table really shines.
/ Crazy idea for a welding table? #50
I just finished a 34"x60" table with an additional 24" cutting table on one end. I can totally see that happening!!!! :)
/ Crazy idea for a welding table? #51
Bridge crane makes a fun welding project. ;) Never worry about the project size/weight again. :D
*You'll thank me if you build one.
/ Crazy idea for a welding table? #52
I agree. My bridge crane is just about priceless
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2015 Ford Explorer Multipurpose Vehicle (MPV), VIN # 1FM5K8B87FGB13389 (A61569)
2015 Ford Explorer...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
1998 Link Belt HTC-8660 60 Ton Hydraulic Truck Crane (A60352)
1998 Link Belt...
2016 CASE IH MAXXUM 115 TRACTOR (A62130)
2016 CASE IH...
