3PH / Backhoe hose loop bothers me.
   / 3PH / Backhoe hose loop bothers me. #11
Here are the images. In the second image, you can see the two hoses wire tied together which I'm referring to. I'd like to avoid looping the hose and your suggestion still does this. If there isn't any type of bypass, I may cobble some fittings with a ball valve to tidy up the rear and gives me two fixed coupler points.
Remember I was shooting blind before the pics. :cool: I still think you could avoid valves/shutoffs by just cutting/rearranging the hoses and a couple of new QDs and possibly bracket to hold them, similar to how your factory valve is now.
View attachment 457316 View attachment 457317
Seems a lot of manufacturers make the tractor siDe hoses kinda long. Could you just put shorter hoses on the tractor side and longer hoses on the hoe side?
That's how I did my hoses when I made my bh.
That's what I was trying to say - you stated it better...:thumbsup:
Something like this could be done on the tractor side, then a short jumper, a valve teed in between the to lines right behind the quick connects , that way you have nothing to keep up with to jumper it that way. Bunch of ways to do it , just have to decide which way you like and can do.
What CB says above - (more so in his pic), is what I am trying to suggest/convey. Make it easy to connect: on the hoe one male end, one female end, then match those up on the tractor rear end. The excess hose stays on the hoe, and the male/female ends connect, when not in use, to keep it clean. If the tractor hoses need to always allow flow when the hoe is off cut a short jumper to connect when the hoe is off. I take it the existing hoses are running off the FEL valve?
FWIW, my Kioti came with one factory remote set with QDs, and I installed a second, which gives me two levers at the open station, one detented, the other not. Then I added a diverter valve, which ties into the curl circuit of my FEL joystick, and it allows me to run a Fit Rite T-N-T via a joystick trigger on my loader stick/handle.
So two remotes, one diverter, and a joystick handle allow me to run a snowplow, a grapple on front, a T-N-T on rear BB, etc., and the hoe as needed. Kioti sells a 'kit' to allow the return to tank hoe hose to connect to the fill port of the tractor hydraulics- which increases flow of fluid, keeps things cool and increases overall speed of the hoe hydraulics.:thumbsup:
Like your nice clean tractor! Hope you'll post your eventual solution with pics...
I went to a "hose" store where they also have fittings, etc. got a few items and after looking over the tractor, I believe I have an excellent plan which would make the install look factory sharp. So good that I just might offer it as a bolt-in retrofit kit for 3520 owners w/ backhoes.
The ball valve fitting has no attachment points but I plan to weld mounting nuts on the bottom side and secure it on a fabricated bracket using the existing hardware from the top of the remote stack as seen in this top picture.
I'll get started on this in a week & post updates.
   / 3PH / Backhoe hose loop bothers me. #13
That will sure beat what you have now - one more suggestion you may already plan on - if your fittings to the hoe are one male, one female (opposite on the hoses of course) then when the hoe is off you can couple its hoses together to keep all the dirt/bugs out.
Then just a matched pair of QD caps on the tractor side, ball valve open and you're good to go... Steve
   / 3PH / Backhoe hose loop bothers me. #14
When I bought my Branson backhoe for my 4520R I just made the hoe connections both male and use one of the two hydraulic remotes on the back of the tractor. Is there a way to just remove the backhoe loop altogether from the loader valves and just use one of the remotes? Sounds a lot simpler and less expensive than all the additional plumbing you are looking at adding.
BukitCase - When the BH is off, the hoses are coupled together to keep the ends clean. It's a practice that I've done in my FF days with the hydraulic tools we used (jaws of life, spreaders, lifters, etc). Got rid of the caps it came with. Of course, on the tractor side, the plug/cap will be used.
coralhead - The backhoe loop supplies a hefty amount of fluids and it's an open loop setup, rather than having to try to hold the levers in one position to supply the BH. The tractor originally was equipped with the BH connections so I figured that this was the default way to provide BH hydraulics. I wanted two remote capabilities to the rear and a 3rd function on the front loader and they stacked the two remote valves on the back. Curious, what is your setup like originally & after modification and who did the mod/add-on?
   / 3PH / Backhoe hose loop bothers me. #16
[/QUOTE]coralhead - The backhoe loop supplies a hefty amount of fluids and it's an open loop setup, rather than having to try to hold the levers in one position to supply the BH. The tractor originally was equipped with the BH connections so I figured that this was the default way to provide BH hydraulics. I wanted two remote capabilities to the rear and a 3rd function on the front loader and they stacked the two remote valves on the back. Curious, what is your setup like originally & after modification and who did the mod/add-on?[/QUOTE]
I just removed the female quick connect from the backhoe and replaced it with another male quick connect. I then connect to the lower hydraulic remote like you have on your tractor and use a short cord to hold the lever next to the seat in the forward position. The cab tractor remotes have one with a detent to hold it in the flow position but the ROPs does not. The use of a cord to hold the valve open is crude but a lot simpler than having another valve setup on the back. Note that you have to make sure the correct fitting is in the correct coupler but having them color coded makes this simple. My tractor did not come with a backhoe when I purchased it but was bought later. Total cost was a male quick fitting and a piece of cord from the shop.
With your proposed setup what happens if you forget to manually move the ball valve to the open position when the hoe is off the tractor?
   / 3PH / Backhoe hose loop bothers me. #17
Looks like a good plan, but I am concerned about the NPT fittings. They are hard to get tight and pointed the way they need to be.
The "hose" store should have sold you O-Ring Boss (ORB) fittings that you put in position and snug the nut down on the o ring till it doesn't leak. SAE Straight Thread O-Ring (ORB) Hydraulic Fittings
Xfaxman,
You know what, you're absolutely correct. I'm going to take a few steps back and try to locate an ORB ball valve. I think I found one from Ball Valve, 3/4" ORB and I'm waiting for them to supply more info & pricing. I'm hoping this one has the means to mount it too!
I know I could have gotten adapters but that would just clutter up the rear so I'd thought I'd try to do it right as if I'm engineering the setup at the Branson factory.
Thank you!!!
   / 3PH / Backhoe hose loop bothers me. #19
You're welcome, looking forward to pictures of the finished project. :thumbsup:
Got the info and it looks that this ORB ball valve I mentioned will work well. It has means to bolt it to a mounting plate and thanks to Xfaxman, the correct valve is on the way to me! The minor downside is the company is from Canada and shipping & tariff amounts to about $30 for a $48 dollar part. Not too bad since the original valve is about $58 bucks. Had I stuck with the original valve, I'd have to buy adapters and it would make the assembly wider, cluttered, and I'd still have to fabricate a unique way to mount it. In all, I came out ahead!
It's a nice feeling to share an issue I'm having and you guys just gather 'round to offer suggestions as if you all were next door neighbors. Now the waiting begins and I look forward to completing this project and sharing it with you all.
Again, many thanks!
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
