Folding Cutting Table Question????
/ Folding Cutting Table Question???? #41
Now wait a minute Terry..... I just now finished building the folding braces. Only took 4 hours..... :)
I wanted to create a lever system that you could step on with your foot and lower the casters. Some sort of locking method that only required another step on the peddle to release and let the table down on the leg pads.
Then I thought about it and decided I would want adjustable pads so I could level the table wherever I parked it. So I took the easy way out. :)
Why don't you do something like what those big movie stair cases have at menards, lowes,etc... I think that would give you a good base design
I don't make it to town much. So I have no idea about that??? :)
/ Folding Cutting Table Question???? #43
Me neither! Sounds interesting. Farm Boy 00....?
Terry
/ Folding Cutting Table Question???? #44
The pink is a flat bar. The red are c-channel to hold the flat bar. Flip up the table, slide the bar into a holder. Do this for both sides. The flat stores out of the way on the table. No extra parts needed. Make it half the length of the swing up portion so it doesn't stick out. Easy!
I don't know why this thumbnail is upside down and I can't remove it.
/ Folding Cutting Table Question???? #45
I had a beer when I got home from work to better prepare myself to help you solve this problem. Which led to another... and another... and now I don't think I'm much help.
I'll try to sketch up the geometry needed for the folding, no tools, no floppy parts (of the table) idea that should work for you... but it might not be tonight! *grin*
/ Folding Cutting Table Question???? #46
How about a swing out arm with an adjustment rod/bolt -- mounted on the inside of the orange legs. (Opposite face of where the hinges are.)
Instead of the threaded rod use a bolt that you can use a cordless impact to raise to the right height.
If you mount them offset at different heights (or depths) they will fold completely out of the way if you lower the bolts.
Inspiration:
/ Folding Cutting Table Question???? #47
Okay guys, thank you very much for all the ideas!!!! I have committed to folding braces.
Thanks to LD1 for giving me two bits of critical information in the design. 1) distance from the hinge pin at the table down to the bracket at the bottom of the table leg, and the distance from the hinge pin at the table out horizontally to the bracket on the cutting table MUST be the same length. 2) The two pieces of flat bar that make up the hinging brace have to be drilled exactly the same length between the hinge pin hole and the hole at each end.
Paint is drying . I'll post pics tomorrow. Thanks again to everyone!!! :drink:
/ Folding Cutting Table Question???? #49
So they are already made? And work okay?
If not, you could always mock some up with strips of cardboard for confirmation on the design
/ Folding Cutting Table Question???? #50
I think Farmboy may have meant this (my phone puts words in my mouth too :D )
https://www.grainger.com/product/COTTERMAN-Stock-Picking-Rolling-Ladder-3UU86?functionCode=P2IDP2PCP
If you mouse over the pic it expands, but it's still hard to see the actual mechanism - we used these all over my last workplace, but they weren't real easy to lift onto the wheels EMPTY, might have to mod the geometry a bit to get one to lift a serious weld table.. Steve
Yup. Got to love phones. Got a samsung s6 and the key boards are "supposed to adapt to use" and I don't check half what I say so I have alot of mistakes
They work great. Thank you very much for the "tips". :)
/ Folding Cutting Table Question???? #52
I think we'd ( well I for sure) would like to see the finished project and perhaps close ups/ details of your cutting table.
Terry
Okay, okay...... I'll work thru my lunch posting a thread...... :)
Caterpillar 330/330L Excavator Service and Parts Manuals (A63117)
Caterpillar...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2013 Freightliner...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
