Satoh Beaver fluid level question
/ Satoh Beaver fluid level question #1
RandyG
Bradenton,fl
satoh beaver 370D
This is my first tractor so I'm going to be asking some stupid questions so please bare with me. Can someone tell me how to check the fluid level of the transmission? This unit has a rubber plug on top beside the gear shifter. I looked down in there and see fluid on the lower portion but where should it be? And is this the correct way of checking it? I'm going to be changing it soon so how do you know when its full? Hopefully not to the top because mine is way down in the bottom. And is this also you hyro fluid? Thanks.:confused3:
/ Satoh Beaver fluid level question #2
There is a plug on the left side of the transmission. If you're sitting on the tractor, the plug would be about level with your left ankle, but a little to the rear of the tractor. Fill through the top plug until fluid starts to run out of the lower plug.
I've always used Traveller Universal Tractor fluid, about $30-$35 at TSC for 5 gallons
Thanks Gunny!!:thumbsup:
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
Kubota GR2020G (A63688)
Kubota GR2020G...
SET OF UNVERFERTH LIFT ASSIST WHEELS & REACH ARMS (A63291)
SET OF UNVERFERTH...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
