Frozen tire ballast options
/ Frozen tire ballast options #1
GreatWhitehunter
Eastern CT
JD 110 TLB
The previous owner of my Deere 110 TLB lived in the Carolinas. He had added water to the rears as ballast which I found out the hard way last winter.
As soon as the weather was above freezing I attempted to drain the rear of the water and thought I got the bulk of it out. Fast forward to today and I find I must still have a few gallons in them, I'm guessing about 5-10 gallons.
So I'm trying to come up with a easy short term solution to allow me to use the machine. I'm thinking of adding a gallon of the RV anti freeze to each tire in hopes that will keep them from freezing again. I'm thinking that in the spring I'll take them to a HD tire place down the road and get them dismounted from the rim and ensure there's nothing else in them. Anyone else have any other ideas? I can't bring the machine inside and I don't have a bullet heater or means to thaw the tires at this point. But warmer weather is in the 7 day.
Matt
/ Frozen tire ballast options #2
Drive the tractor real slow . Ad the rv anti freeze , drive the tractor around a bit it may loosen the ice from the tire
/ Frozen tire ballast options #3
Isopropyl alcohol might be another option. You can rent "jet" heaters most places arround here.
/ Frozen tire ballast options #4
Rim Guard gets a little "lumpy" at -15F;good thing that doesn't happen often.Normally I wouldn't go out when that cold but had an older neighbor that had to get out.
I was wondering about using Isopropyl but worried it may damage the rim or rubber if it sits for a while. I can actually borrow some bullet heaters from work but it's supposed to warm up to the high 40's Tuesday so I was thinking that the antifreeze would mix with the water and solve my problem for now.
I'd agree that NE CT doesn't get this cold too often but the cold is sort of a mixed blessing in this case.
I've got a large red oak I've been waiting to fell once the ground froze up good. Of course it's plenty frozen now and I moved the tractor to put on the grapple and found the ice block tires. I don't use the machine much in the winter so this isn't an issue that I was thinking about.
Matt
/ Frozen tire ballast options #6
Add methanol. Either straight or as WWF. You may need to add as much as the 10 gallons of water that's already in there but you can leave it in as ballast. Methanol won't hurt the tires or rims.
Any idea where to get it?
Matt
/ Frozen tire ballast options #8
Auto anti freeze will be fine. even a 25% mix will just make slush and not freeze solid.the
/ Frozen tire ballast options #9
Even 10% antifreeze in a tire isn't going to freeze solid maybe slush. I mix 10% windshield antifreeze in my lube tank on the saw mill and it doesn't freeze.
/ Frozen tire ballast options #10
Matt
WWF obviously is available everywhere. The "winter" version has a higher concentration of methanol. Pure methanol is available from industrial fuel places. Often the same companies that sell heating fuel will also sell methanol in bulk. I forget exactly but I think WWF is about 30% methanol and the rest is water and colorant.
/ Frozen tire ballast options #11
Auto parts stores sell concentrate for mixing your own WWF might ask there.
/ Frozen tire ballast options #12
Using auto anti-freeze in tractor tires is a VERY bad idea!
It is highly TOXIC, and animals are ATTRACTED to it's sweet taste.
If you have a flat, you will likely also need to bury some animals.
/ Frozen tire ballast options #13
You can also use RV antifreeze - totally non toxic and good with rubber and plastic.
Thanks for all the replies, I actually picked up some rainx WWF concentration booster which appears to be mostly methanol. It claims to lower the freeze point even more. I was close to trying some of gas de water stuff called Heet, But the contents were vague. Should I attempt to add the stuff today or wait till it warms to the low 40's tomorrow?
Matt
/ Frozen tire ballast options #15
Matt
Does not matter when you add it, when the ice thaws it will mix in.
/ Frozen tire ballast options #16
The problem is the ice frozen in the tire. Rolling the tire with ice inside could and very likely will damage the inside of the tire. You need to find some way to melt the ice with either a bullet heater or perhaps by adding hot water to the tire if possible. Once the ice is melted, you can add whatever you want to make it freeze proof from now on.
P.S. 40 F isn't going to melt ice very fast but if you have sunshine on the tire it will surely speed things up.
I understand this isn't going to be a fast thawing process, we're still getting below freezing at night.
I'll see if I can get the WWF in and hopefully it'll thaw out before too long.
Matt
/ Frozen tire ballast options #18
It's only one more day, I would wait til it's 40 just for my own comfort
True but had the day off work today lol. After felling a large red oak I decided to wait until it warms up a bit to monkey with the fluid.
Matt
/ Frozen tire ballast options #20
Yup! I've got some animals around here I wouldn't mind seeing dead. And I can't remember the last flat I had that didn't have a good rain follow behind.
No one said to leave the stuff in the tire.
Safety cops piss me off!
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
