HOW DOES AC WELDING DIFFER FROM DC WELDING
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #61
Thanks Shield Arc. I guess I was wrong.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #63
Shield Arc,
Would you do it with an AC welder? That's all I have.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #64
Well I'm no pro:), but that's how I've been doing it for years.;)
And I know I am not a pro, and I hold the electrode to get started too.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #66
Shield Arc,
Some things to keep in mind. When your skin is wet, your gloves soaked thru, be CAREFUL!. If you don't have to weld, consider doing it some other time. If you have to, try real hard not to "complete the circuit". In other words, don't touch both sides of circuit at the same time. Don't lean on that bush hog and touch the electrode at the same time. The OCV (Open Circuit Voltage) measured between ground and stinger is not supposed to be over 80 volts, but 80 volts is enough to knock your **** stiff if you are wet.
On a dry fall day you could touch both stinger and ground and probably never feel it, depending on how calloused your hands are. Of course if you just touch ground and never touch the stinger, no current will flow thru your body. Also if you just touch the stinger and not the ground clamp, or the weldment, then no current will flow thru your body either.
Welding is just like working around any other source of electricity, the thing that needs to be foremost in your mind is "don't become part of the circuit". When I touch an electrode to steady it when striking the arc, I make it a point to not be touching the grounded workpiece. I also make it a point to not have wet gloves or wet skin. Dry calloused skin has a high resistance to the flow of current, but wet skin has a very low resistance to the flow of current.
Also keep in mind that a welders source of current is not very current limited from the point of view of the human tolerance to current flowing across the body. They tell us that at as little as 50 milliamps is enough to kill you. That is 50 thousandths of 1 amp. We often set our welder to deliver over 100 amps. That is thousands of times more than what is needed to kill us.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #67
lol, I think our terminology is getting confused, caps don't fill holes ( as in a zero volt reference and up ) they smooth out " ripples"/"noise" of a specific voltage and are also used as storage cells. .
Your the confused one!
what you are calling filling a hole, as in the space between the crests of the positive wave form as compaired to steady state dc.. and YES, caps will smooth / filter that bumpy DC to steady state DC .
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #68
here, this might help. and for the other EE's out there, this drawing is OBVIOUSLY not scaled.. freq, etc, waveform errors, etc. it's just a pictogram.
Skyhook... the first line shows half wave dc, an ac wave form ran thru a diode and it chops one half off as the diode oposes current flow in one direction.
the next line shows full wave dc, either a transformer and 2 diodes, or 4 diodes aranges so that the lower waveform is tossed 'up top'.. this makes for a riple-dc.
Now, if you take a capacitor and put across the ground reference and the positive test point. the capacitor will 'fill in' the space between those waveforms. ( of course you must have a large enough cap to filter with... loaded or unloaded circuit will effect that, yada yada..
the third line shows the full wave dc with a steady state line over it and a green hash shaded area.. that's what the cap is doing, the green shaded area.
to your vom, the 4 line is what gets reported... steady state dc.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #69
I considered doing this drawing, but I was lazy. I am glad you posted it.:)
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #70
I realize it's hard for those that are not engineers or tech's to visualize some of these concepts, and how cap's and inductors interact with circuits voltage and current, etc.
hopefully the drawing will help. it's a bad drawing, but i think it will work. the signal 'generator' ( my hand ) needs to be calibrated. :)
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #71
Actually I though your waveforms were not bad at all. I don't believe I could have done any better.:)
It all seems so simple for those of us that have been around these concepts for decades, but to many here it is all new concepts. Nothing wrong with that, as I am sure that the fields of endeavor that they work in seem simple to them too, and I would likely not have a clue about their work. I have started off into a new tangent of learning about health insurance in my advancing years, and leaving engineering behind.
Imagine my confusion and questions when I first jumped into this field. But hey, I am a professional now.:)
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #72
So, if I may ask: What's a good entry level DC welder? Something that's usable for typical farm equipment. I already have a Lincoln SP-175 Plus MIG, but I need something with a little more oomph for 3/8" and up material.
I looked at the old Lincoln AC/DC buzz box, but DC amps are only 125. Doesn't sound like enough.
Thanks,
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #73
Thanks,
Everlast Power Arc 200ST. Contact Mark on this forum for a TBN discount.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #74
Thanks,
The 125 amps DC would be fine, but I wouldn't spend "new" price for the AC/DC; think they are around $385-400 and there's plenty of options when you get in that range. I quick Google search returned $400-550; so I wouldn't pay that for one.
Edit: Hobart Stockdale LX235 is 150 amps DC/225 AC; for same price (at northern tool, new)
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #75
Thanks,
The everlast would be really nice for sure- If you have the coin
but on a tight budget Craigslist, at least what i see every week lots of great ac/dc transformer welders for $50- $200 most come with leads to which are worth at least $50.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #76
My little Everlast PA160 has done all that I have needed done. I paid $265 several years ago for it. I use it for TIG too.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #77
Shield Arc,
Sure! But with good welding gloves on. Back when I was working I welded a lot with just White Ox cotton gloves. Used those gloves mostly for rigging, but they worked OK for a few quick welds.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #78
Looking at the specs as we speak, thanks!!!
:beer:
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #79
:beer:
Ask Shield Arc about how he likes his. I can't remember how much the TBN discount from Mark at Everlast was, but it was a fair chunk. Send him a PM
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #80
Caterpillar Service Letters from 1960's (A63117)
Caterpillar...
Caterpillar 322B/ 322BL Excavator Service and Parts Manuals (A63117)
Caterpillar 322B/...
Reichardts Green Fit Kit for C Series RoGator (A63117)
Reichardts Green...
JMR 78in Dual Cylinder Grapple Rock Bucket Skid Steer Attachment (A61572)
JMR 78in Dual...
Caterpillar 416/426/428/436/438B Backhoe Service Manual (A63117)
Caterpillar...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
