HOW DOES AC WELDING DIFFER FROM DC WELDING
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #41
I thing i read somewhere that it does this 60 times a second and the DC if IIRC is like 60,000 but not sure probably need to look on that
Yes, 60 times a second ( thats where you get 60hz ), DC is a steady voltage.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #42
Here's my understanding ( and I could be wrong ), AC goes from a negative value to a positive value, doing so, it crosses the "zero value" line, making poorer welds than a DC welder which has a "steady" value of current. Expert welders compensate for this constant change in voltage/current drop on AC. Personally, I use my machine on DC only, I like the welds better.
AFAIK all standard industrial welders are DC. The smoothness of the welder depends on its AC to DC converting ability, if you just use a converter to transform the AC sinus into DC, it still jumps from max to zero, just with bumps instead of into the negative current. WElding machines use capacitators to store the energy of the AC bump to release it in the hole, to smoothen the sinus washboard.
For that reason, three phase welders are usually the better welders, as they have three overlapping phases filling each others current dips. Then the capacitators have a much easier job, and are able to get a much more constant welding current.
However, for welding aluminium you need AC. Its because the oxide skin on aluminium has a higher melting point than the pure aluminium underneath. Just try to heat aluminium with a torch, you won t get a melting bath like you get with steel: you dont see anything happening, untill the oxide skin breaks and a big two inch hole drops in the aluminium sheet you were trying to heat.
To weld aluminium you need AC because it blasts through the oxide skin with short AC blasts, without heating the entire workpiece to melting point which will blow large holes in it.
Last friday i tossed a purlin cleat 5 yards down from a ladder, because the MMA inverter welder i borrowed from work, tickled me. Missed a friends head by a foot. Lately i get some tickles from my 350A mig, but not as often as i remember from the good (poor) old days of stick welding.
Boy, when i got a MIG i sometimes used the stick welder for dirty steel or awkward positions. But now, first time stick welding in 5 or 8 years, i dont miss it a second.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #43
From my understanding, from Lincoln Electric,, The output is at a consistent current level all the time on DC. The OP can read some info here. It is also my understanding that "capacitors" are used to "filter" or smooth out voltage, not fill in the holes of a sine wave, rectifier's/diodes are used for this purpose.
DC vs. AC Polarity for SMAW
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #44
Correct. Capacitors oppose a change in voltage. Coils, chokes and inductors oppose a change in current. Both are used in a power supply derived from an AC source to produce a smooth constant DC supply of voltage and current.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #45
Filtering, smoothing,a nd filling the holes , for the purposes of capacitors and filtering rectified ac to dc, they are one in the same. filling the hole is the 'smoothing' ...
No.. diodes are used to convert the ac to dc. in simple terms, a single diode in an AC line gives you half wave DC. 4 diodes in an ac line in a full wave bridge formation, give you full wave dc..
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #48
No, they are not....cap's will smooth out a "peak" sine wave that has been "rectified" by "yes" diode's or a rectifier, they will not change AC to DC, ( fill in the hole, for the laymen term from a zero volt and up ).
I think thats what I said, the cap's "smooth" this DC wave out.:confused2:
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #49
When I started welding, it was on an old AC Sear's welder, somewhere around 175-200 amps or so, in ten years of outside welding, I've gotten bit on a few damp days here and there while putting rod in the tongs, but I never did or need to hold the ground clamp with one hand and hold the tongs with the other. There have been some damp days that I had enough of the jing-a-ling when putting the rod in that I started grabbing the rod with tongs. I think that's another benefit of mig welding.
I had a Century 250 amp AC-DC for 20 years(burnt up in shop 3 years ago) love to find another one. Nobody had mention this but the best thing about 200 amps of DC power is Carbon Arc Gouging, other wise known as, welding rod eraser, with a air compressor, a gouger,and 3/16 carbon, a lot of stuff that's welded together, with 1-3 weld passes can be easily be take apart with very little base metal damage.
For DC welding, here are some of the electrodes I liked and kept on hand. DC welding>7018, 11018, 6010, 6011, and on rare occasion, aluminum rod.
On AC, I liked 7014, I always tacked everything with 3/32 7014, then weld with 1/8-3/16, 7014 is a easy start, fast, strong rod in all positions.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #50
I bought AC/DC on everyone's advice, and I don't notice a night and day difference. Mine has lower DC max amps then AC; as do the Lincoln AC/DC tombstones. As for rods, I think the most generalist rod, as in, if I could only have one, I would have 6011 in 3/32". It will run from 70-130 amps, and weld fairly thin to fairly thick stuff if you work with it.
Edit: as a note, I don't think I've ever welded on virgin metal, it's all scrap, or rebar, or reused/repair, and is rarely as clean as it should be, so that affects my rod choice
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #51
I don't notice much difference either. Only that you have to run the AC at a higher amperage than DC for the same "heat". And that it sounds different. I have stuck alot of metal with both, and cannot thin of a single time using AC where I thought " I wish I had DC" ore vice versa
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #52
I can, the one time on a whim I grabbed some aluminum stick rods, that barely work on DC, and not at all on AC.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #53
Many years ago I was welding up some cracks in a 6' brush hog. The cracks were in the middle of the deck, so I was kneeling on the deck. It was close to 100 degrees in the afternoon, in the driveway, in full sun, on a very humid day and I was sweating so profusely even my welding gloves were soaking wet..... that's all I remember. :laughing: That, and it hurt. :rolleyes: I shut off the welder and went inside.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #54
Aluminum rod is the hardest rod I ever used t weld with, but it worked in a pinch and 6011 is a must have rod for scrap metal welding and thin farm equipment repair, that's why I always kept it on hand and before I had a cutting torch, 5/32 6011 was my cutting torch.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #55
I can relate to that, I went through your state in August of 07, it was somewhere around 105 degrees, and it was worse when I got to Missouri, 115', it don't get quite that bad here.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #56
No.. You said caps didn't fill the holes.. And that's exactly what happens when you put a cap across a rectified circuit.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #58
Not all the time, but sometimes I can feel the current when I touch the electrode and the grounded table.
Touching the electrode and the grounded cable brings up something thas has me puzzled. When I watch some of the weldors who are giving instruction on youtube some of them steady the electrode by holding it by the flux with their free hand. I thought this was a no no. Is it approved by the pros?
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #59
lol, I think our terminology is getting confused, caps don't fill holes ( as in a zero volt reference and up ) they smooth out " ripples"/"noise" of a specific voltage and are also used as storage cells. Anyway's, the point I was trying to make about a DC welder is that you have a steady DC current available at the rod which in turn gives a smoother weld, IMO, and thats what the OP was asking. And I could be wrong but could also be a little safer ( as in shock value) than AC. The only downfall I see is that a DC welder has a lower amperage setting value than its counter part AC machine. But for "personal" home type use, DC for me. Bigger rods will need more juice, and its always good to have AC available if needed.
/ HOW DOES AC WELDING DIFFER FROM DC WELDING #60
Well I'm no pro:), but that's how I've been doing it for years.;)
832856 (A61166)
832856 (A61166)
John Deere 6125R (A60462)
John Deere 6125R...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
1989 Corvette Convertible (A61574)
1989 Corvette...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
