New land... need a tractor!!
   / New land... need a tractor!! #211
Please let us know how you and the new machine get on.
   / New land... need a tractor!! #212
Seems like a ROPS will only save you if your wearing a seatbelt- otherwise, you takes your chances!
Certainly, the best chances are with the ROPS up, and wearing a seatbelt. Still, ROPS up and no seatbelt offers a better chance than the ROPS folded...there's at least an open space left that you might wind up in.
   / New land... need a tractor!! #213
Lots of opinions on seat belts. Before I had the cage, I would wear the seat bet with just the ROPS when in the woods. That stopped the day it got tippy next to a tree that could have ended up across the seat without hitting the ROPS. With the cage I wear the seat belt again in the woods.
   / New land... need a tractor!! #215
Yep. I don't wear a seat belt.
I rarely where a seat belt. About the only time is when I am mowing a couple of my road ditches that have gopher mound issues.
   / New land... need a tractor!! #216
I wear a seat belt all the time in both motor vehicles and tractors. Seen too many MVAs in the ER to think it is reasonable not to. Rarely start the tractor motor without buckling up first. Too many slopes and uneven ground to ignore risk of rollover. Only time I've considered unbuckling was when turning on a steep slope and realizing that if the tractor did go over I would be crushed against a stump if my seat belt was on. I left it on but put my hand on the buckle as I SLOWLY turned.
So. I was able to put some hours on the tractor... Yes. I did put the ROPS up and put my seatbelt on. Here are my thoughts:
1) I'm very glad I followed everyone's advice on size. Smaller might have meant slightly easier to maneuver, but I really benefitted from the wider stance and heavier weight.
2) the station is pretty well laid out for me. I know where everything is basically without looking already. The only part I don't like is the tilt steering adjustment foot pedal. I hit it accidentally a couple times.
3) I love the grapple.
4) I really need to fill the rear tires. Might also go w Ag tires on the rear.
5) HST is so very nice for the clearing I was doing with the grapple.
6) easy to drive and great visibility.
Things I learned/missed/need to figure out:
1) I need to get better with the FEL hydraulics. I often get the bucket dump versus curl backwards. I also rested my hand on the joystick once while backing up and turned around to the bucket being up all the way. Whoops lesson learned. I'm sure I'll get this with more seat time.
2) the brakes need some work I think. They are somewhat mushy and occasionally seemed less effective than I thought they should be on hills.
3) after having it in the barn for a week we noticed a small amount of fluid under where it sat (didn't notice until I went to put it back in the barn). So I will have to figure it out. I am guessing hydraulic, transmission or perhaps brake fluid? Seemed to be clear in color typical oil-like consistency. Maybe this explains #2. I will look at this before moving tractor next.
4) need a couple retaining clips for pins on the grapple.
Overall, I'm very happy with it. It is going to serve me well I think.
   / New land... need a tractor!! #218
3) after having it in the barn for a week we noticed a small amount of fluid under where it sat (didn't notice until I went to put it back in the barn). So I will have to figure it out. I am guessing transmission or perhaps brake fluid? Seemed to be clear in color typical oil-like consistency. Maybe this explains #2. I will look at this before moving tractor next.
Did you get a Mahindra? Leak is likely from a Banjo bolt/crush washer. Keep us updated.
   / New land... need a tractor!! #219
Get some knowledgeable advice on just changing the rear tires to R1s with MFWA.
Justin- I was told that isue had already been fixed by the dealer... I'll certainly post back when I get it figured out.
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
