New to me 2013 B3200HST
/ New to me 2013 B3200HST #1
Racenh
Stoddard, NH
2013 B3200 / 2002 753 Bobcat
Hello all,
Just picked up this 2013 B3200HST and trailer from a private seller. Tractor only had 110 hrs on it. It was just the size I was looking for to do some landscaping work around our new home and also maintaining some gravel roads on other property that I have. Currently I own a 753 Bobcat and trying to maintain the gravel roads takes alot of time with only the bucket. I am planning on purchasing either a box blade or a land Pride grading scraper. I also have a set of clamp on forks that came with the tractor along with a #300lb 3-point hitch weight. I am also looking at converting the FEB to a quick attach so I can use some of my Bobcats attachments. Would welcome any suggestions or comments you may have on attachments for the tractor. Take care.
Jim
/ New to me 2013 B3200HST #2
Very nice!
/ New to me 2013 B3200HST #4
Great looking purchase! Consider filling the rear tires- 300 lbs is handy, but not a lot of rear weight... and SSQA is a wonderful thing to have! You'll be glad you did. Telescoping stabilizer links are also available and useful mods- I think this tractor comes with turnbuckles?
I forgot to mention that the rear tires are filled. Thanks for the suggestions.
/ New to me 2013 B3200HST #7
Congrats on the new TOY! Looks like new.
/ New to me 2013 B3200HST #8
Great looking tractor and trailer! Congratulations.
/ New to me 2013 B3200HST #10
Make sure to check front axel fluid. Mine was low on my L and I bought brand new.
/ New to me 2013 B3200HST #11
Heck, I like the house, like the truck, and like the tractor but I can't comment about the Bobcat accessories.
/ New to me 2013 B3200HST #12
Ditto on the front axle fill- I've changed mine, carefully filled to the hole, and checked again later to find it needed more. I guess the oil flows slowly into the nooks and grannies.
/ New to me 2013 B3200HST #13
The B3200 has/had an option for SSQA.
If the B3200 had a factory option for heaven's sake go that route. Otherwise a good welding shop/machine shop could probably put a skid-steer adapter kit from almost any brand machine onto your loader frame. Not cheap but opens a wide range of goodies !
/ New to me 2013 B3200HST #14
[/ATTACH]Kubota does have an aftermarket SSQA kit- and anyone with a wire welder and some cutting, grinding and welding skills can install it. Mine was installed by the previous owner, an electrical contractor, and it looks factory- well, it is. A can of Kubota spray paint would also be needed. Sorry I don't have a better photo. Not sure about the weight, but the convenience is HEAVY!
/ New to me 2013 B3200HST #15
Hey! That is the right stuff. Some of the smaller machines (e.g. the stout but small, lawn tractors like BX2300, etc.) Are just not big enough to get into this and don't have the hydraulic pump capacity nor connections for serious operations. Larger ones -- maybe 30 hp and above -- like the 3200 should be good candidates.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
