hydrolic top link
/ hydrolic top link #1
fredflintstone
michigan
cub cadet LS4140
could someone with more know how explain the pros and cons of a hydrolic top link?
looking at possibly hooking one up to my LS 4041 and would think possibly aid in hookups
and staying in adj. place thanks
/ hydrolic top link #2
No cons except for cost, but once you start using it that con is quickly forgotten.
/ hydrolic top link #3
I have found no cons. The major advantage, for me, is the ability to adjust ground engagement implements "on the go". I initially thought they were just a lot of fluff. However, after using the hyd top link, I wouldn't be without it. Rather than just looking back and thinking "well, that's good enough" - you can tweak it until it is perfect.
/ hydrolic top link #4
What implements do you have? (Or plan on adding)
I haven't found any cons, and have found quite a few more uses for it than I realized. I have found that the ability to "float" the top link has really increased use and efficiency for the jobs I do. I certainly recommend getting one with the option to float it if your valve arrangement allows that.
/ hydrolic top link #5
One negative thing about how you will feel after realizing all the positives of a hydraulic top link is you will soon be coveting a hydraulic side link...
/ hydrolic top link #6
Depends on what implement you are using it with. I think the most use of the top link while actually using an implement would be with a box blade. Besides making it easier to hitch to the implement, once you are using your box blade you can at a touch of your finger tips adjust how the box cuts either by shortening or lengthening the top link.
Shorter equals more aggressive cutting and lengthening would put the rear cutting edge down for smoothing purposes or the exact opposite if you are grading in reverse which typically is not a good idea if done aggressively. Same applies to other implements as well, but a box blade is the most common that I can think of.
Take a look at this link, it explains how to determine what working length will work best for your application.
Good luck. ;)
/ hydrolic top link #7
The second most useful would be pallet forks or a fork lift:
/ hydrolic top link #8
I use a Quick Hitch on my Kubota. I also have TnT that I built. Makes most 3pt attachments much more useable. Also dramatically improves hitching to an attachment. It allows you to do this without leaving the seat.
/ hydrolic top link #9
Hydraulic top link+ quick hitch = very easy and quick change of compatible implements with out pushing pulling fighting kicking pounding straining cussing or even getting out of the seat.
I can change from my box blade to my pulverizer to my rake in seconds just by backing up to them and pulling levers. Plus I can adjust them on the fly with another pull of the lever.
Another plus for me is with a mower on you can really get a lot of lift when loading on a high trailer or going through a ditch. or angled drop if backing up to mow a sloped bank.
/ hydrolic top link #10
/ hydrolic top link
thanks for all the response im not using a box blade just the ease of changing out tiller,planter and disc as whell as
other 3pt equip
/ hydrolic top link #12
other 3pt equip
Yep, I understand that. Sure helps with those tasks.
Myself, I'm pretty lazy. That's why I like a Quick Hitch. :)
/ hydrolic top link #13
The hyd top link makes the quick hitch work even better. Extend the link outward with the quick attach plate. Hook the top link (but not fully) to the implement. Lift and pull in the plate. The implement aligns itself. Then lift and engage the locks. Done!
Cons, It ties up a remote.
/ hydrolic top link #14
I added a hydraulic top link to my previous tractors box blade and it was amazing how nice it was. Certainly worth it IMO. My current tractor had top n tilt from the factory and I find it useful as well. I'd highly recommend the kits sold by a fellow member. Made specifically for your machine they are hard to beat.
/ hydrolic top link #15
A hydraulic top link and a quick hitch are the best options I put on my tractor. I bought the quick hitch on sale ($200) and made my own top link. I had a hydraulic cylinder with a broken shaft. I got a new shaft made and cut the cylinder barrel shorter with my chop saw. The bolts holding the cylinder together were shortened and retreaded. Then I welded three point hitch top link ends onto the cylinder and I was in business. Total cost for the cylinder was about $100.
So to get around this "problem" I had a hydraulic spliter laying around so I plumbed it into my rear outlets. One way runs the outlets and the other runs the top link. I had hoses made up at my local NAPA so I could hook it all up.
The whole project, top link and quick hitch was about $450. I didn't have to pay for a hydraulic cylinder and the spliter so I saved some money there. It was worth it though.
/ hydrolic top link #16
Good luck. ;)
I don't know Brian, there you go again.:D
To the OP - this is my next investment for my tractor. Looking back there were many times I wished I had it, especially with my sickle mower to get the cutter bar pitch correct for the crop I was in. I now have a drum mower that will need the same fine tuning as I cut.
When I order it will be through Brian with Fit Rite Hydraulics. He set me up with a system to run rear remotes to the front of my tractor (search my user name), excellent quality, service, and he stands behind his work.
Keith
/ hydrolic top link #17
Keith
Keith, just an FYI, lead times for cylinders typically run about 8 weeks. I can only make them so fast and those are my big sellers. :thumbsup:
/ hydrolic top link #18
Now you tell me :) - do you have a kit (dimensions) for my CT 235? Email if you do. Ill get with you soon.
/ hydrolic top link #19
I love my TnT.
Downsides:
Cost
More hoses & junk back there in the way
Upside:
With a quick hitch I don't have to get off the tractor & can hitch up to really crookedly parked equipment
I love float on the toplink for mowing
Makes it easy to lift the mower higher for maneuverability
Makes it easy to swing a rotary cutter out over a ditch with the back wheel unsupported or what not
Makes box blade work easy & smooth. With the jerky 3pt on the L3200, I can get a perfectly smooth transition just slightly tweaking the toplink
I'll never own another tractor without at least a toplink if not full TnT setup.
/ hydrolic top link #20
I love my TnT.
Downsides:
Cost
Upside:
Well stated.
If you can only afford one, start with the top link. Then you'll want the side link even more.
I firmly believe a tractor that is purchased to do 3pt work needs triple rear hydraulics.
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
More info coming soon (A61574)
More info coming...
