Ford 5000 (233d) crankkey dimensions?
/ Ford 5000 (233d) crankkey dimensions? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Anyone got crank key dimensions for the 233 diesel crank?
Long story but mine is broke and a new one is very pricey from CNH. Don't have crank in my possession and won't til Monday. By then I'll be off work til Thursday with no mill access and was wanting to get the rebuild underway.
And I seem to have misplaced the broken one.
It's not a square key. It's 3/8 wide by something less for depth. With only having the gear to go off of, reverse figuring the key depth formula, and assuming the crank was cut standard depth, I come up with .323"
So my gut tells me it's 3/8 x 5/16. Anyone confirm?
/ Ford 5000 (233d) crankkey dimensions? #2
online CNH parts shows - 5/16" (7.94mm) x 3/8" (9.53mm) x 2.86 (72.64mm), Start Year: 01-JAN-65 C9NN6N250A
The website I looked it up on didn't list the dimensions. Thanks. Will get one made now
/ Ford 5000 (233d) crankkey dimensions? #4
FYI I did it through Messicks site
That's where I looked a few weeks ago and could have swore the size wasn't listed.
Thanks again
/ Ford 5000 (233d) crankkey dimensions? #6
we have made them out of a nail before, bend a 90 in it a hammer the head flat, works good when your in a bind
Not sure how a nail would replace a 3/8 x 5/16 crankshaft key that holds the gear that drives the camshaft and injector pump, and keeps things in time
/ Ford 5000 (233d) crankkey dimensions? #8
didn't read well enough,thought you were talking key for starting
/ Ford 5000 (233d) crankkey dimensions? #9
/ Ford 5000 (233d) crankkey dimensions? #10
Landhonor Quick Attach Grapple Bucket (A66285)
Landhonor Quick...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
2001 Ford F-550 (A66408)
2001 Ford F-550...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
