Good morning!!!!
/ Good morning!!!! #41,861
Glad to see the engineers.
Where are we wrong? I understand what you're saying, but most people aren't engineers or thinking in technical terms. If the average guy gets a shovel of powder ten minutes after it falls, then gets a shovel full after a 35° day in the sun, he's going to say it got heavier.
/ Good morning!!!! #41,862
Don;
Replacement guns are cheap at Northern Tool and other places. Your gun is probably stuck with minerals in the water?
No, I have fixed the switch 20+ by unscrewing it pulling the tiny plunger and putting lube on it. It will work for a few weeks before it gets stuck again.
This time the tiny plunger in the switch is stuck and no longer moves freely with the pressure change when the gun trigger is released turning the machine off.
/ Good morning!!!! #41,863
Terminology help needed.
What do you call the switch on a pressure washer that is connected right before the hose connection and turns the pressure washer on when the trigger is pulled and shuts the pressure washer off when the trigger is released.
That automatic switch is sticking bad, the machine cuts off and will not come back on until I unscrew the switch and pull the plunger out. I want to get a new one but I can't seem to find it using the phrase "automatic pressure on/off switch". I think I'm using the wrong words and the manual is no help.
Unloader. But it may be the gun.
/ Good morning!!!! #41,864
I think it's called a "doo-hickey."
You are about as good as me, but I got a little further calling it a flow switch, but still no image that looks anything like the switch I have.
/ Good morning!!!! #41,866
Unloader valve.
None of the unloader valves look right. Here is a picture of the switch. it is unscrewed from the black part so you can see the spring that is around the little plunger.
When I turn let go of the trigger on the gun the pressure in the valve goes up pushes the plunger in (toward the white box) which turns the electric off of the pressure washer. The opposite when the trigger on the gun is depressed.
/ Good morning!!!! #41,867
None of the unloader valves look right. Here is a picture of the switch. it is unscrewed from the black part so you can see the spring that is around the little plunger. When I turn let go of the trigger on the gun the pressure in the valve goes up pushes the plunger in (toward the white box) which turns the electric off of the pressure washer. The opposite when the trigger on the gun is depressed.
Try "Flow actuated switch". See if that gives you the results your looking for.
/ Good morning!!!! #41,870
Must be different than mine. Mine uses unloader valve to remove pressure to wand hose when you stop spraying. When it sticks, won't allow pressure go to wand.
/ Good morning!!!! #41,871
We should let Mexico keep the name. After all we did take almost half of their country.
Took all the way to California after the US Army battled down to Mexico city. We may have paid them a stipend, even though we had just kicked their rears. (This after many raids by Mexicans after Texans had defeated Santa Anna.)
Mexico took it from the Spaniards after the Spaniards had taken it from the Indians.
/ Good morning!!!! #41,872
Don, have you taken it apart to see if everything is moving freely?
/ Good morning!!!! #41,873
I'd buy the new gun. They aren't real expensive.
It's not the gun. I push the little plunger in and it works fine, but as soon as the pressure is increased when I turn the gun off, the plunger goes in and does not come out, and there is no power to the unit.
A lot of the switches I'm finding are connected to the burner, but I have no burner.
/ Good morning!!!! #41,874
Yes, and that is the problem, it is not moving freely, it needs to be replaced.:thumbs:
It was 70˚ outside today so cold temp is not the problem either. I just can't find a replacement part.
/ Good morning!!!! #41,875
Don,
Post the make and model number of your pressure washer. I would be happy to do some sleuthing on your behalf. I really enjoy the challenge. :)
/ Good morning!!!! #41,876
Any engineers or cooling experts out there? I need some engineering help.
I need to figure out how much of a glycol circulating cooling system I need to freeze a block of aluminum 2" x 12" x 12" to 14F by circulating the glycol in cooling channels in the block. Outside temp should not exceed 80F. Should I use Fourier's Law?
I can insulate the bottom and the sides with styrofoam. My initial calculations came up to around 154,000 btu/hr. Can that be right?
This is for a small project I have at work that I would like to implement in the shop. It would be great if I could sabotage an old freezer compressor, add a heat exchanger and a glycol tank and pump.
/ Good morning!!!! #41,877
Try disassembling the old one and soaking it overnight in vinegar. If it's hard water deposits that are making it stick, the vinegar will eat them up.
Google the make and model number of the pressure washer along with "parts diagram" or some such and maybe you'll get an exploded view that shows the part you need.
/ Good morning!!!! #41,878
2016-01-25, 0332
14 degrees right now, high of 35 today!
Took my wife out for dinner yesterday. We went to a local taproom (she and my step-daughter picked the place). Food was pretty good and they had a heck of a selection of beers!
Busy week at work this week...heading to Connecticut Tuesday, back on Wednesday, then down to Connecticut again Thursday and Friday.
/ Good morning!!!! #41,879
Morning. 16° here. Not sure if i will try to venture out today, at least not till daylight.
/ Good morning!!!! #41,880
25 going up to 53 today, nice sunny day.
Hopefully the ground will start to dry out after more than two inches of rain. But at least things don't have to melt...
TPL MECHANICS BODY LUBE SKID (A60430)
TPL MECHANICS BODY...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
