Bucket level indicator on 3016
/ Bucket level indicator on 3016 #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
It's beyond me why the 3016 doesn't come with one. It seems most tractors have them.
I remedied that.
After some figuring how to best and easiest make one, I decided on the following approach:
1) drill and tap a 5/16 hole in the end of each of the pins that hold in the tipper hydraulic rams. The are VERY soft and easily drilled with a 17/64 drill and tapped with at 5/16-18 tap. You don't even need to remove them, drill them in place.
I went to TSC, got a 5/16 rod and a 1/2 tube. The rod fits into the tube very well, not too tight nor so loose that it will rattle like crazy.
I cut two 2 inch pieces of 1 1/4x3/16 band iron and drilled a 5/16 hole in each. I call them 'tabs'.
Thru trial and error I determined the proper lengths. I'll save you some trouble and tell you that I ended up cutting the rod 33.5 inches and the tube is cut to 28 inches.
I welded one tab to the end of the rod and one to the tube after determining the proper placement thru trial and error.
The tab on the tube was welded 4 inches from the end, measured to the center of the drilled hole. The tube could be a couple inches shorter, if you desire, but the upper end must be 4 inches as I mentioned.
These lengths make it so the end of the rod is even with the end of the tube when the bucket is flat on the concrete floor of my barn.
I painted the tube and tabs.
I inserted the rod in the tube.
The tabs must be free floating when fastened to the FEL pins, so that they will move with the motion of the FEL. I placed a washer on either side of the 'tab', and screwed a 5/16x18x1 1/4 inch bolt thru them and applied some locktite to the bolt. I screwed it in as tightly as I could while still allowing enough 'slack' to let the 'tab' turn in between the washers. When the locktite was dry, I put some oil on the 'tab'/washer points.
I found this is extremely handy. I went thru the winter without it and thought nothing about it. Today I was moving some piles of dirt and found that after dumping, I could lower the fel and adjust the bucket to the level position at the same time, so when the bucket hit the ground, it was level. Very efficient.
I hope I explained the process well enough. These dimensions will work for any 3016 or 3616 or other Mahindra that uses the ML115 loader with the SSQA unit on it.
/ Bucket level indicator on 3016 #4
It is interesting my ML106 was made with a level indicator. I guess it was a cost savings issue on later models. Why else would they not put one on there? I find mine an invaluable part of the loader.
/ Bucket level indicator on 3016 #5
Great job there Pilgrim. Simple and effective. One of the most concise methods for a level indicator as I have seen.
/ Bucket level indicator on 3016 #6
Nice job, I may follow suit. The ML120 loader on my 4035 (which I find amusing with the 35 series being what they call their "premium line" of compact utility tractors) only has a sticker on top of the bucket that says the word "LEVEL" on it. What or how that is supposed to be useful I have no clue...
/ Bucket level indicator on 3016 #7
That's awesome. I am have been trying to figure out a way on my 4035 to determine bucket level. I saw the sticker on there and said "how the heck is that useful in any way??"
/ Bucket level indicator on 3016 #8
My ML111 loader has the level indicator also and I like how it works . Easy to tell when the bucket is level .
Yup the word 'level' on a sticker sure leaves a lot to be desired.
/ Bucket level indicator on 3016 #10
I might just have to borrow your design....thank you brother.
/ Bucket level indicator on 3016 #11
I know this is old post put this is a great simple design - I have the KLM 116 bucket but I believe its identical.
Sure need the level moving snow on rock drives.
Thanks, Tom
you might just have to make the rod and the tube a little longer (or shorter).
/ Bucket level indicator on 3016 #13
Yes I planed on making it longer then cut to level- thanks for the heads up - I presume yours is still functioning correctly ?
works like it was designed to. I'd really miss it if it went away. For snow and other loader work, it makes the job much more efficient.
I put some 'witness marks' on the bolts that I loctited into the pins, just so I could keep an eye on them to catch any loosening. So far no motion at all.
I used blue as that's all that I had, but I don't see why either wouldn't work ok.
/ Bucket level indicator on 3016 #17
works like it was designed to. I'd really miss it if it went away. For snow and other loader work, it makes the job much more efficient. I put some 'witness marks' on the bolts that I loctited into the pins, just so I could keep an eye on them to catch any loosening. So far no motion at all.
I followed Oldpilgrim design and it works great I to would be lost with out it for loader work thanks again oldpilgrim for the design and all your help
Sent from my iPhone using TractorByNet
you're welcome, Ed. Glad it worked for you.
/ Bucket level indicator on 3016 #19
Just have tractor about 2 weeks but wish I had it installed today moving 8" of snow off stone driveway LOL
/ Bucket level indicator on 3016 #20
Ok we are welded up and getting ready to drill pins.
Is there a auto parts spray can match for Mahindra Red ????
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
IRANCH HYDRAULIC THUMB CLAMP (A60736)
IRANCH HYDRAULIC...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
American Flag Decorative Metal Sign (A61569)
American Flag...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
LIGHT TOWER (A56857)
