Bucket level indicator on 3016
   / Bucket level indicator on 3016 #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
It's beyond me why the 3016 doesn't come with one. It seems most tractors have them.
I remedied that.
After some figuring how to best and easiest make one, I decided on the following approach:
1) drill and tap a 5/16 hole in the end of each of the pins that hold in the tipper hydraulic rams. The are VERY soft and easily drilled with a 17/64 drill and tapped with at 5/16-18 tap. You don't even need to remove them, drill them in place.
I went to TSC, got a 5/16 rod and a 1/2 tube. The rod fits into the tube very well, not too tight nor so loose that it will rattle like crazy.
I cut two 2 inch pieces of 1 1/4x3/16 band iron and drilled a 5/16 hole in each. I call them 'tabs'.
Thru trial and error I determined the proper lengths. I'll save you some trouble and tell you that I ended up cutting the rod 33.5 inches and the tube is cut to 28 inches.
I welded one tab to the end of the rod and one to the tube after determining the proper placement thru trial and error.
The tab on the tube was welded 4 inches from the end, measured to the center of the drilled hole. The tube could be a couple inches shorter, if you desire, but the upper end must be 4 inches as I mentioned.
These lengths make it so the end of the rod is even with the end of the tube when the bucket is flat on the concrete floor of my barn.
I painted the tube and tabs.
I inserted the rod in the tube.
The tabs must be free floating when fastened to the FEL pins, so that they will move with the motion of the FEL. I placed a washer on either side of the 'tab', and screwed a 5/16x18x1 1/4 inch bolt thru them and applied some locktite to the bolt. I screwed it in as tightly as I could while still allowing enough 'slack' to let the 'tab' turn in between the washers. When the locktite was dry, I put some oil on the 'tab'/washer points.
I found this is extremely handy. I went thru the winter without it and thought nothing about it. Today I was moving some piles of dirt and found that after dumping, I could lower the fel and adjust the bucket to the level position at the same time, so when the bucket hit the ground, it was level. Very efficient.
I hope I explained the process well enough. These dimensions will work for any 3016 or 3616 or other Mahindra that uses the ML115 loader with the SSQA unit on it.
   / Bucket level indicator on 3016 #4
It is interesting my ML106 was made with a level indicator. I guess it was a cost savings issue on later models. Why else would they not put one on there? I find mine an invaluable part of the loader.
   / Bucket level indicator on 3016 #5
Great job there Pilgrim. Simple and effective. One of the most concise methods for a level indicator as I have seen.
   / Bucket level indicator on 3016 #6
Nice job, I may follow suit. The ML120 loader on my 4035 (which I find amusing with the 35 series being what they call their "premium line" of compact utility tractors) only has a sticker on top of the bucket that says the word "LEVEL" on it. What or how that is supposed to be useful I have no clue...
   / Bucket level indicator on 3016 #7
That's awesome. I am have been trying to figure out a way on my 4035 to determine bucket level. I saw the sticker on there and said "how the heck is that useful in any way??"
   / Bucket level indicator on 3016 #8
My ML111 loader has the level indicator also and I like how it works . Easy to tell when the bucket is level .
Yup the word 'level' on a sticker sure leaves a lot to be desired.
   / Bucket level indicator on 3016 #10
I might just have to borrow your design....thank you brother.
Champion C80 B Motor Grader (A50322)
Champion C80 B...
2007 John Deere CT332 Skidloader (RIDE AND DRIVE) (A50774)
2007 John Deere...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
John Deere Van Brunt Grain Drill (A50515)
John Deere Van...
2002 Winston ProSeries 20K Tandem Axle Equipment Trailer (A47384)
2002 Winston...
