Odd happening
/ Odd happening #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Today while dragging stems out, the 3016 belched when the gearing was set too high for the load (3rd gear up an incline) The tractor just about died but caught and was moving exhaust out the air cleaner for a few seconds. Forward setting made the tractor go in reverse and reverse forward.(shuttle) I shut it down. Waited five minutes, and continued like nothing happened. Never heard of this effect nor care to duplicate it.
Pictured is the hitch it happened with. All the stems in the pic is the sum of 5 hitches. This tractor is just right for these woods and has the oomph to be a big time saver capable of dragging whole trees through dense forest. This is the second full year of skidding I've had with this new tractor. Although driving skidders through New England forests for 30 years has taught me how to maneuver through this type of terrain, apparently, this operator has some more to learn about his present machine.
/ Odd happening #2
You had the engine running backwards.
I've had it happen before myself. Nearly stall the engine, catch it with the clutch a the last second, the engine kicks back and starts up backwards.
/ Odd happening
Exactly. The sound was as if I blew a muffler out. Had me concerned with the reverse world I was living in for a moment..
/ Odd happening #5
It never happened. It's the exhaust fumes that are causing hallucinations. :)
/ Odd happening #7
I have never done that with my tractor (engine running backwards), but I have had it happen a couple times in the mud hauling pit coal with triaxle dump trucks.
Once with a Detroit 2 stroke diesel and once with a 2406 Cat.
I knew what had happened so I shut them down right away, started it back up and off I went.
/ Odd happening #8
Just check your air filter and make sure it has not burnt any holes it.
/ Odd happening #10
This is off topic, but from the pictures it looks like you can move the rear tires out quite a ways. For skidding logs like you're doing (and for doing just about everything else) having the tires at the widest position will make that tractor safer and more capable. I'd highly recommend swapping them side to side and maximizing the potential of that nice looking Mahindra.
/ Odd happening
Good notion motown. I actually had the dealer widen up the stance before they delivered it. I am not sure if they can be widened anymore as you may have a better eye than I but I asked the dealer and then stated "but not too wide as I have tight woods to go through".
/ Odd happening
Good idea! If it weren't for DK, I'd feel like a freak. ( I can live with the hallucinations as that is more natural)
/ Odd happening #13
be careful with that, some oil pumps don't do so well running backwards. I've done it several times on gas engines messing with the engine management-get the config/setup wrong and it'll light off at the wrong time and start running backwards. interesting and amusing stuff, no doubt.
/ Odd happening #14
I had the same thing happen with a 2 cycle motorcyle once.
/ Odd happening #15
Some snowmobiles do this for reverse. Push a button and the engine almost dies and then runs backwards. Had it happen on an outboard too.
/ Odd happening #16
Yes, my snowmobile ( 2 cycle) has the electronic reverse and that is how it works for reverse.
The oil injection pump is designed to pump oil either direction that the engine is spinning
/ Odd happening #17
Had it happen on a 2 stroke mc. Once I knew what was going on I tried starting it in reverse by pushing it backwards and popping the clutch. Was way too hard to drive.
429647 (A61165)
429647 (A61165)
2006 Ford E-350 Cargo Van (A61568)
2006 Ford E-350...
2016 Ford Fusion Sedan (A61569)
2016 Ford Fusion...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
6067 (A61165)
6067 (A61165)
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
