Geothermal - what if?
/ Geothermal - what if? #1
Jim Timber
Metro/Brainerd, MN
JD 5065e MFWD w/553 FEL
What if you skipped the compressor part of the system and just circulated ground temp fluid through a cement slab when the temps were above or below where you wanted them to be?
Would having that much thermal mass at least temper the temperature in the building? So in the winter, it would potentially keep the building above freezing, and in the summer it would keep it from being overly hot. Would that work?
/ Geothermal - what if? #2
You would need a LOT of ground loop or wells to dissipate the heat. The main reason for the compressors.
If you could loop the pipe through a lake that is over 40ft deep you may get where you want to be but would probably need 500ft of pipe per ton of heat/cool load.:2cents:
So if I tap the water table I'm good to go? :laughing:
I'm seeing 400-600' per ton advised on a regular system, so you're saying it wouldn't change anything.
I'm not sure how much system I'll need yet, but keeping the shop over 45F with a circulator pump would pay dividends over propane given our recent gas prices.
/ Geothermal - what if? #4
You will get some effect out of it, but nowhere near the efficiency or punch of a system with a compressor and working refrigerant, where the ground loop is just used to reject heat from the refrigerant cycle (which is the primary heating/cooling mechanism).
I suspect it would be usable for small areas, but it really depends on how well the area is insulated, etc. Just think about how deep you have to go to get below frost line in winter -- obviously the ground temp gets overwhelmed to that depth.
No doubt the electricity needed to run the pumps could be used more efficiently in a system with a compressor. They are just so much more efficient.
I'll need to go rather deep regardless of what I do, if I end up doing this at all. I was just thinking if the ground remains 54F, then having the slab at 45F wouldn't be too much of a stretch (yes?), and that much mass at that temp would keep the air at least above freezing for the cost of a circulator pump. Closed loop, gear pump - wouldn't hardly draw a load in a horizontal system.
Our frost line hit 7' last winter. I need to clear a bunch of ground for the building, house, yard (truck turn around area), and lumber storage for drying and storing whole logs. So I've got the room to dig up if it'll be worth it.
I'm investigating all the options right now. Not even close to building anything yet.
/ Geothermal - what if? #7
By the seat of my pants if your goal is just above freezing your best bet is to just build a very well insulated building with properly spec'd south facing windows and forget any of the half baked geothermal systems. If you do all the work of tubes and pumps and no refrigeration/compressor you are missing out on a lot of potential for the money spent. Better off putting all that money into insulation and windows.
We have weeks where the daytime temps don't get above 0F more winters than not.
Insulation is a given. Windows alone aren't practical for the layout of the building (monitor barn). The middle bay would be dark and thus cold.
Solar is a strong possibility. I've measured 132F at 4" beneath the sheathing in our roof with "weathered wood" asphalt shingles when the temp was in the mid 60's outside, so there's certainly some potential there to be captured. The vacuum tube solar collectors are also interesting (as was the pop can heater). We did parabolic mylar hotdog cookers in 8th grade and I knew even then that such a technique had more useful applications than bursting the edges on Oscars wieners. :laughing:
I'm looking at roughly 5000sf with a nominal 12' ceiling for the main floor for the shop, and something around 2-3K for the house. So roughly 10Ksf of heated floors between the two buildings. So by using the slab to take the bottom edge off the heating needs, and then also using it to help chill the area when the outside temps are high, I think there's possibly some merit in exploring that. Ground loops are only one technique. You could have buried heat exchangers with barrels of water acting like a water body. It's entirely possible I'll hit the water table too, as I have a spring fed seep maybe 400' from the house site and it's only about 20' lower in elevation.
What'd be sweet, but completely impractical would be to drill down deep enough to get 100F core temps and place an exchanger there. :D
Honestly, reading about the costs of short lived geothermal pumps makes buying propane and simply having 2000 gallons of it on hand while buying in the summer when prices drop a better solution than doing GT heating at all. I'll be encasing the whole exterior in 2" of high density foam and sealing it again. My current shop has 1.5" pink foam and R19 in the cavities and it's pretty darn efficient even given the fact I made it drafty intentionally so I could get air moving when I'm welding. The new shop won't be drafty, I'll have some make up air ducting in place instead.
/ Geothermal - what if? #9
Around here if you circulated cold water in the slab I'm sure there would be times that the floor would be wet from condensation in hotter humid weather.
/ Geothermal - what if? #10
What is this talk of short lived geothermal pumps? Granted I have only been living in my house for 18 years, but my system keeps working. OK, I was victim of the crummy quality coil common 18 years ago in practically all systems and it started leaking. Coil was replaced and all is good again. The brand I have reportedly has had systems in service 30-40 years. My neighbor has a tech at her house 3-4 times a year for her not geothermal system. The rest of the neighbors have heat pumps and traditional systems without all the service calls. I question her install as at most, a visit every few years to check the system should be enough.
I have a tack room in the barn. Concrete slab. 1" foam caulked to the outside walls and r19 fiberglass in the ceiling and walls. An incandescent light bulb keeps the room above freezing when we get our 0-10F spells.
/ Geothermal - what if? #11
I think you are wasting your money for the little gain.
Think about this......a house with no air conditioning but a full basement. Hot 85-90 degree summer days. The basement slab and below grade walls will rarely get above 50 degrees, so you would think there would be a real pronounced cooling effect in the basement. But you would be lucky if the basement stayed 10 degrees cooler right?
Now just think in reverse. 45-50 degree slab (with no below grade concrete walls to help) and outdoor temps of 0F and no other heat source, I doubt you would be able to keep the garage much above 10 degrees. Infact I would be worried about your lines freezing in the concrete with sustained 0F days. For 5000sq ft you would want SHORT runs and flowing pretty fast to a manifold. And SEVERAL to cover that size slab. Which will require a heck of a pump. Just running a single LOOOONG loop or two in 5000sq ft, your water would have done given up its heat and froze by the time it got to the end unless you were pumping it through very fast.
Our basement stays cool year round. Wife can't live without A/C - which is why I'm trying to reduce the demand on that system as much as possible.
0-10F for a couple days is cute. We're talking lows in the -20F's highs of -5 for a sustained period.
I have access to lots of wood, but I want the main system capable of being autonomous in the event we're not here.
As for failed pumps - it's within the top 5 threads on this page. Guy's spending $1600 on a motor or $3600 on a replacement unit that's not 10 years old.
Our house isn't particularly well insulated and we have a natural gas furnace which costs us around $200/mo for a 2600sf floor plan (two stories, 1300sf foundation) to heat and roughly $100/mo to cool and power the lights/oven/stove etc. Electric rates aren't very different where the new shop and house are going. Wife insists on keeping it 74F in the summer. I'd rather drop it down to 72F if it didn't add so much to the bill.
/ Geothermal - what if? #13
I don't understand the problems with other units either. I went with geo due to five people I know use geo and have never had a problem. My barber's geo is 25 years old and still working fine. Others have had theirs for 10 years and no problems.
My garage is not heated just well insulated. A warm engine keeps it above freezing when down near 0. I use CFL lights and that helps as well keeping above freezing.
What's your electric bill using the 25 yr old system and what volume of air is being heated?
CFL's are junk. I've never had one live to it's expected lifespan. We'll be going LED on everything in the new house.
/ Geothermal - what if? #15
My barber has no complaints with the cost to operate his 25yr old system. I don't know what he pays for his place.
My system is 5yrs old. I heat/cool 1350sft. I have total electric house with a large hot tub running year round. Winter bills (4 mo.) run between $94 and $124. Summer cooling (6 mo.) run $55 to $65. Two months out of the year the bills are around $39 to $49.
The best part is I don't have to listen to a noisy outside unit sucking up electricity for two motors or pay $29 per month to the gas company for the privilege of just hooking up.
We don't have natural gas available, so there's only the $25 fee of being hooked to the power lines. Well water, septic system waste.
/ Geothermal - what if? #17
I have a Rockton geothermal unit. In summer the cooling is passive. No compressor at all. I seem to recall the CoP is 14.
My configuration is open loop. It uses a source well and a return well.
It cools the house very nicely. I also have powered attic fans, which are a huge help in keeping the house cool.
I'm not wasting any money. I'm asking questions 6 months ahead of the first pour because I don't want to waste money.
/ Geothermal - what if? #19
I have a 16 year old 5 ton unit that I would do again without a doubt. 1800 sq.ft x 2 floors. 2x4 walls upstairs that I am almost done firring out to 2x6 and R19 and updating very crappy windows, so I hope the monthly will decrease eventually. Average $60 to 100 a month. Basement is unfinished but insulated except for the tuck-under 30x30 garage which is finished and heated. Only thing I would do different is I would heat the floor downstairs. LOVE the heating and the cooling is even better. Very constant temperature. Only maintenance needed is filters.
/ Geothermal - what if? #20
Only makes my point more valid.
Even if you are one of the unlucky ones that has to replace a pump after 10 years (which is NOT common), it is still better than spending the money on a system that WONT WORK.
There is a reason why people dont just hook their wells up to their pex loop in the concrete.
You would have MORE benefit if you took the kw required to pump the water, and converted that kw straight to heat. (resistance heater, light bulbs, whatever). I think that would get you MORE heat in the building for the same consumption of watts
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
300 GALLON PORTABLE FUEL TANK (A64280)
300 GALLON...
