5085e questions
/ 5085e questions #1
sacarmic
Member
Deere 5085e, 3320
So I am getting loose on a 5085e (upgrading from a 5303). Still haven't decided between cab and open air. I do have a couple of questions.
Is the DEF only on the 15+ models? The 13 & 14 still have the exhaust filters though, correct? How often do you change/clean?
On the cab model is there any upgrade to put 3pt high arms lift controls on the back fender? I know the M series has then. I haven't seen it on the E series, but there is a knock out hole on their fenders where it might go.
Thanks,
Scott
/ 5085e questions #2
Haven't looked at the E and M series that closely but they might use the same fenders. To get the rear hitch controls would require that you have electric/hydraulic control valves. Not as simple as just adding a switch.
/ 5085e questions
Also has anyone installed rear work lights on this unit? IS the wiring already there to run my own lights or do I need their kit? IT looks ike it just come with the lights and wire pigtails to attach them.
Thanks Scott
/ 5085e questions #4
Thanks Scott
The wiring is in place for the work lights but you still have to add the switch to the console. I added work lights to my cab using the Deere kit simple install as I recall.
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2022 John Deere 5055E (A60462)
2022 John Deere...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
