Used woods bh-90x
/ Used woods bh-90x #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I found a used woods bh90x backhoe attachment off a dk45. The guy is asking $5,500. for it. I assume all the hardware is included.
How's this price?
How the heck would I transport a backhoe attachment? The seller is 140 miles away.
/ Used woods bh-90x #2
When I bought my BH750-3 I transported it on my trailer. The previous owner loaded it onto my trailer with his tractor. I used many 4x4's and 6x6's to set it on and make it stable then chained it down. Used my loader to get it off once home. I'm guessing you have a trailer. If not surely you must know someone who does. If in good shape the price isn't too bad. I think the bh90 runs between 8-9K new.
Also not sure if the sub fame for the DK45 and 40 are the same but should be easy to adapt.
/ Used woods bh-90x #3
I recently paid $4150 for a used BH90-X no tractor-side subframe nor tumb. I felt like I got a good deal. I'd be wary that the subframe will be easily adaptable though.
I transported 2hrs on an equipment trailer. Bring LOTS of chains and binders. (like 8 to be safe)
For storage reasons I has to unload like this:
/ Used woods bh-90x #4
May just want to see if WOODS has a subframe and order a new one for it
/ Used woods bh-90x #5
Also might want to think about flushing the hydraulic fluid. (I made a thread about this titled: "how should I flush hydraulic fluid")
/ Used woods bh-90x
Whats involved in removing all the subframe hardware from one tractor and installing it on another?
/ Used woods bh-90x #7
Its a huge PITA. You need to remove the rear tires and then unbolt everything. It can be done without removing the rear tires, but it is easier to do so. I paid $4000 for a Kubota BH90 without the subframe. Check the cylinder rods for rust. Mine were rusted and it cost a pretty penny to replace them.
/ Used woods bh-90x
Thanks for the heads up. I might rethink this. In this case ,maybe paying more, and getting new might be the way to go.
/ Used woods bh-90x #9
Why do you need to remove the tires? My Kioti BH uses a front catch that mounts on the frame and a rear pin assembly that takes place of the hitch bar holder. Might Woods be that different?
/ Used woods bh-90x #10
New you're looking at more like 10-12k I think. I would've paid $5500. They are hard to come by used.
/ Used woods bh-90x #11
He is talking about mounting the subframe, not the backhoe to the subframe - that is as you describe and very easy.
If the subframe is made for your EXACT tractor it is some work to put on (as described above) but a one time deal normally. If it is for a different machine you may need to do a LOT of work (drilling/ cutting/welding/etc) to get it to fit properly.
/ Used woods bh-90x #12
Mounting the backhoe to the subframe is easy. I can do it in 5 minutes. Mounting the subframe to the tractor is a huge PITA, but you only have to do it once. You don't have to remove the tires to do so, but the manual recommends you do so. I didn't, but it would have been easier to do so. I later had to remove one rear tire to install the grapple hydraulics, and it wasn't as hard as I thought it would be.
/ Used woods bh-90x #13
I see, on a Kioti the subframe is mounted to the BH. Thats why its faster to install!
/ Used woods bh-90x #14
Yea, every **** time. I only have to do it once. Plus I don't have that thing sticking out in the way when I unhook the backhoe.
/ Used woods bh-90x #15
Plenty of room in my Barn and it makes it much easier and faster than a woods mount.
/ Used woods bh-90x #16
I'd have to see a video of you putting it on to believe that.
/ Used woods bh-90x #17
Spring time the Hoe goes on. My biggest task is to lift the rack up level after that drive forward and line up two pins.
Edit, I just remembered playing this game before.
/ Used woods bh-90x #18
Yes, we have played before, and I still don't believe it. From the few YouTube videos I have seen the Koiti is not easier. How long does it take to hook up your backhoe? I'm guessing 10-15 minutes.
/ Used woods bh-90x #19
Closer to 10 on average but you have them days that nothing goes right.
2022 EZ-GO ELITE...
Pig Statue (A64557)
Pig Statue (A64557)
(2) SUPER SAVER HEATERS & PARTS (A64278)
(2) SUPER SAVER...
GAS POWERED PUMP W/ HOSE & TARP (A64278)
GAS POWERED PUMP...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2007 Ford E-250 Cargo Van (A64556)
2007 Ford E-250...
