Used woods bh-90x
/ Used woods bh-90x #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I found a used woods bh90x backhoe attachment off a dk45. The guy is asking $5,500. for it. I assume all the hardware is included.
How's this price?
How the heck would I transport a backhoe attachment? The seller is 140 miles away.
/ Used woods bh-90x #2
When I bought my BH750-3 I transported it on my trailer. The previous owner loaded it onto my trailer with his tractor. I used many 4x4's and 6x6's to set it on and make it stable then chained it down. Used my loader to get it off once home. I'm guessing you have a trailer. If not surely you must know someone who does. If in good shape the price isn't too bad. I think the bh90 runs between 8-9K new.
Also not sure if the sub fame for the DK45 and 40 are the same but should be easy to adapt.
/ Used woods bh-90x #3
I recently paid $4150 for a used BH90-X no tractor-side subframe nor tumb. I felt like I got a good deal. I'd be wary that the subframe will be easily adaptable though.
I transported 2hrs on an equipment trailer. Bring LOTS of chains and binders. (like 8 to be safe)
For storage reasons I has to unload like this:
/ Used woods bh-90x #4
May just want to see if WOODS has a subframe and order a new one for it
/ Used woods bh-90x #5
Also might want to think about flushing the hydraulic fluid. (I made a thread about this titled: "how should I flush hydraulic fluid")
/ Used woods bh-90x
Whats involved in removing all the subframe hardware from one tractor and installing it on another?
/ Used woods bh-90x #7
Its a huge PITA. You need to remove the rear tires and then unbolt everything. It can be done without removing the rear tires, but it is easier to do so. I paid $4000 for a Kubota BH90 without the subframe. Check the cylinder rods for rust. Mine were rusted and it cost a pretty penny to replace them.
/ Used woods bh-90x
Thanks for the heads up. I might rethink this. In this case ,maybe paying more, and getting new might be the way to go.
/ Used woods bh-90x #9
Why do you need to remove the tires? My Kioti BH uses a front catch that mounts on the frame and a rear pin assembly that takes place of the hitch bar holder. Might Woods be that different?
/ Used woods bh-90x #10
New you're looking at more like 10-12k I think. I would've paid $5500. They are hard to come by used.
/ Used woods bh-90x #11
He is talking about mounting the subframe, not the backhoe to the subframe - that is as you describe and very easy.
If the subframe is made for your EXACT tractor it is some work to put on (as described above) but a one time deal normally. If it is for a different machine you may need to do a LOT of work (drilling/ cutting/welding/etc) to get it to fit properly.
/ Used woods bh-90x #12
Mounting the backhoe to the subframe is easy. I can do it in 5 minutes. Mounting the subframe to the tractor is a huge PITA, but you only have to do it once. You don't have to remove the tires to do so, but the manual recommends you do so. I didn't, but it would have been easier to do so. I later had to remove one rear tire to install the grapple hydraulics, and it wasn't as hard as I thought it would be.
/ Used woods bh-90x #13
I see, on a Kioti the subframe is mounted to the BH. Thats why its faster to install!
/ Used woods bh-90x #14
Yea, every **** time. I only have to do it once. Plus I don't have that thing sticking out in the way when I unhook the backhoe.
/ Used woods bh-90x #15
Plenty of room in my Barn and it makes it much easier and faster than a woods mount.
/ Used woods bh-90x #16
I'd have to see a video of you putting it on to believe that.
/ Used woods bh-90x #17
Spring time the Hoe goes on. My biggest task is to lift the rack up level after that drive forward and line up two pins.
Edit, I just remembered playing this game before.
/ Used woods bh-90x #18
Yes, we have played before, and I still don't believe it. From the few YouTube videos I have seen the Koiti is not easier. How long does it take to hook up your backhoe? I'm guessing 10-15 minutes.
/ Used woods bh-90x #19
Closer to 10 on average but you have them days that nothing goes right.
2014 Jeep Patriot SUV (A64557)
2014 Jeep Patriot...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2023 Isuzu NPR-HD Mason Dump Truck (A64556)
2023 Isuzu NPR-HD...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
