3rd loader function of 3032e
/ 3rd loader function of 3032e #1
dzemcik
Thief River Falls MN
John Deere 3032
Hello all. I have a 3032e. I will be adding a grapple to the loader, so I will be in need of a 3rd function for this. So I am looking for input on how to get this done. I was looking at the Artillian kit for adding this with a diverter valve, but this kit would not directly work as I do not have quick connects on the loader. But I think it could be adapted..Or should I head towards the rear remote kit from John Deere and run hydraulic lines all the way from the front end loader to the rear? It seems the diverter valve setup with a momentary switch would be easier to operate? Looking for any ideas or guidance? Maybe one of you have already ran into this? Thanks in advance!
/ 3rd loader function of 3032e #2
Hi! and :welcome: to the forum.
Not familiar with the kit that you mentioned.
I do know that some run the 3rd function off the rear SCV. (rear remote)
Or, you can pay a bunch and have JD change your loader valve out for one that has the 3rd function built in, and with the button control on the joystick.
/ 3rd loader function of 3032e #4
/ 3rd loader function of 3032e #7
Call Artillian and ask, or contact Ken's Bolt on Hooks. These guys work together on different things, I'm sure that they can get you taken care of. :thumbsup:
Thanks Brian,
One issue with the "E"'s is regen, just like the Kubota "L" tractors I think all the "E" JD's with the 305 loader have 3-way valves so regen is active all the time.
/ 3rd loader function of 3032e #8
Thanks Brian,
Use the lift circuit? Why does the 4000R series have this same 3 position curl circuit valve and the 3000R series has the 4 position like every loader should have? :confused2:
/ 3rd loader function of 3032e #9
I wish I knew the logic Brian, it just doesn't make sense to me either why the use the 3-way valves are being used again.
/ 3rd loader function of 3032e #10
I suppose I understand, (cost) but why use a lesser valve on the 4000 series and the proper valve on the 3000 series? :confused2:
But then on a $40K+ machine, you really do need to save that other $10-$15. :rolleyes:
2020 KENWORTH T880 (A67714)
2020 KENWORTH T880...
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2020 TAKEUCHI TL8R2 SKID STEER (A65056)
2020 TAKEUCHI...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
