T330 Loader Control Valve
/ T330 Loader Control Valve
Greg more power to you removing the cap every time I thought it was a little pain in the rump to get the screws loosened and out with an allen wrench. You know the loader has a 2 year waranty. Not sure when you got yours so it may be something you want to bring up to dealer because TYM's design wasn't the greatest with the upside down valve with improper venting. Which reminds me to give my dealer a call and see what TYM responded to his letter he wrote because my warranty is running out in Nov some time.
/ T330 Loader Control Valve #42
Grut,
It wasn't very difficult to remove the caps on my design. The allen screw closest to the loader frame was not a "straight" fitment but came out easily.
But; I've yet to see how long that lithium grease lasts before it melts out! I wanted a grease that would provide good lube, (for those tiny balls & their small holes) but I believe I'm gonna hafta find grease wilh a somewhat slow melting tolerance. There was [red] grease residue left from the original mounting. I felt that moly grease - like I use on my loader fittings - would be too stiff? Maybe not though - I hadn't thought about the large heat build up!
I just came in for a cup of coffee after 1.5 hours of loader usage and my float was working perfectly now! We'll see how long it takes before the grease melts all out.
Greg
Greg I used the Lucas RED and TACKY same as the rest of the grease joints!
I shouldn't have complained that it was difficult but a bit agrivating, because the screws are on the tractor side of the vavle and working from the side the lines are in the way. I also had to do it outside in the dirt in the middle of my job. You happen to have a tooth bar for your front loader? Night and day difference, I love mine. Highly recommend if you have any dirt moving to do.
Well fellas seems TYM will only give me the LT350 valve and I would have to pay for the rest of the conversion. That is to have a correctly positioned joystick mounted valve mounted to the loader subframe. I emailed the dealer to see what the costs are for welding a plate one and a couple of hoses. That is pretty bad for a company which is of that size and has knowledge about the problem of the valve set up.
Maybe time for buying something else that has better customer warranty support when the TYM warranty runs out.
Les did you happen to start working on the write up for the valve replacement?
I am interested because why not upgrade to a better valve now and eliminate the problems you had and changing it over in the future. Which it seems everytime I need the machine something is r goes wrong with it(Stripped threads on loader frame, backhoe subframe bolts loosening up, frozen loader valve(condensation build up due to valve bing upside down), broken joystick because of valve corrosion, nuetral post on back hoe valve loosened during a job causing ball to pop out, and worn pivot bushings in the hoe), and it isn't due to maintenance because I am religious about that with all my equipment/toys.
/ T330 Loader Control Valve #45
Hey guys anybody have any problems with the control valve for the front end loader on a T330 tractor with a LT300 loader or similar brand(scorpion, etc.). Mine is/was hard to get into float position and getting it out is/was worse. It also has started to stick very slightly in the down position. Today I was using it and the joystick broke--the ball on the neutal post broke off causing the joystick to overtravel forward and break the plastic which covers the cable ball ends and attaches to the boot. No biggy but I was tinkering with it before it got dark and the up/down valve spool was actually causing the whole problem. It appears water entered the vent hole on top and rusted up the spring and I know the spool is sticking, not sure if the water travelled to bottom side haven't tore it off. I know the dealer had said that he figured out the control vavle was actually mounted upside down and to to seal the holes in the top(which is where the spring is) to eliminate water from entering. It was sealed by the dealer when he did some other warranty work this spring.
So much for getting the back of the house back filled!! Time for a beer or 4.
Well off to the dealer tomorrow to see what he has to say about this new deal.
Just got a T433 & cable broke first time using loader. I think they need to design joystick & cables a little different
Sorry to hear that Tbrey.
Hopefully your dealer gets you up and running pretty quick.
Keep us posted.
That is a nice tractor you have. How do you like it besides the cable?
/ T330 Loader Control Valve #47
I really love the tractor it is great & the dealer said he would overnight the parts & get me going so that is all I can ask for. I really think the cable was twisted when it was installed at factory. I'll keep you all posted of how it goes, thanks for your support & concern.
/ T330 Loader Control Valve #48
This happened to me the last few years to on my 330 HST. Fixed the rusted cable once but now the handle just plain broke. I wonder if this is a common after market item I can pick up at my local tractor farm store or if its worth the drive to go to the dealer. What do you guys think?
/ T330 Loader Control Valve #49
I was using my bucket on my 353 HST not a 330, today helping a neighbor move his snow pile from his ATV plow. My joystick locked up when curling the bucket, I brought it home to look at it and it seems like the cable is not attached any more. The pic shows the two curl controls. The right one moves freely without any tension. The left will not move at all. The raise/lower control moves easily but you can feel tension in the control. Do you think this is an easy fix? I did not take the cable off the bottom of the right control not knowing what I was getting into.
One other item, it sounds as if the hydraulics for the curl are still under pressure, if I need to use the tractor for snow blowing will it harm anything?
Sorry the pic will not load, but there are no signs of rust under the boot and everything under the boot seems well greased.
/ T330 Loader Control Valve #50
OK, here is the update, I broke the control cable going to the loader valve. I went to my dealer today and picked up a new cable ($50) and received basic info on how to replace it, the service side was closed today. I have reinstalled the cable now all I have to do is reconnect the joystick to the cable end which is a steel ball on a shaft. There are three, the center one in the picture which really is on a corner is stationary and the joystick pivots on it. The left and right ends in the picture controls the FEL and the bucket. I can get any two in their slots but not all three. I stopped today before I tried to force it and break the gray piece which is cast something. The joystick actually screws into the top of the gray piece and I don't know if it is available separately if I break it. I do know that the whole joystick control is $800 so I don't want to go there!
My question now is has anyone had to deal with this in the past? Any hints on how to get all three "balls" into the piece in the picture? I have tried many combinations of raising or lowering the cable ends, different angles etc.
/ T330 Loader Control Valve #51
I would think you have to remove the retaining plate to free the ball(s) and fasten it back when all three balls are inserted in the "swash" armature.
Edit:
The answer above is wrong. I just looked at FEL control on my tractor. I think you need to unbolt the "fixed" ball, insert it to the "swash" armature and bolt it back.
/ T330 Loader Control Valve #52
Ladia,
I tried that, when the other two are connected there is not enough room to slide the fixed one back in place. I will look at it again, I tried so many combinations already I may not have had the other two in a looser or higher position. Thanks!
/ T330 Loader Control Valve #53
BTW my tractor is over 10 years old, has about 1100 hours and so far I don't have issue with FEL control. But my tractor sleeps 99% of time inside.
/ T330 Loader Control Valve #54
Take the bolts out that hold the joystick unit to the tractor. Under the base that is a allen bolt that holds the center pivot ball in place. Remove the allen bolt and slide it out. Put the ball head in the triangle plate and angle it downward so you can slide it over the two cable ball heads at the same time as you put it back in the housing. When down in put the allen bolt back in and try the joystick. If all works bolt it back to the fender brace. Note- In some cases you may need to adjust the bucket and boom cables higher to get everything to slide together.
/ T330 Loader Control Valve #55
Pete, thanks I think I just don't think I have the cables high enough. I will try it and let you both know.
/ T330 Loader Control Valve #56
Ladia and Pete,
You both had the right idea, I just needed to adjust the ball ends of the cable more to finally get it to fit into the triangular plate. It still took a few more combinations to get it right. Thanks for being so helpful!! I have to give a shout out to my TYM dealer, Jordan's Tractor in Post Falls Idaho, for being helpful and having a good supply of parts in stock.
Ladia - I only "garage" my tractor in the pole barn during winter when I move my wife's jeep into town and move my truck from the pole barn to the house garage. My wife doesn't like driving down the mountain in the winter so I drop her off at her jeep when she has errands. The rest of the time I cover the tractor with a tarp but only to the steps. I figured that left enough airspace to prevent too much condensation, maybe I am wrong.
/ T330 Loader Control Valve #57
I know it's an old thread... hopefully, this will help some understand the loader valve issue on these tractors.
late.. reply..if anyone cares.
vmax540--yes these valves vent upward Causing issues. Not many options to remedy it. Tried slicone sealing holes and keep lubed. I had my vavle replaced adding a new lever mounted vavle and plate mount off of loader like the older tractors had. no cable crap to deal with... it has been awesome for the past 12 or so years.
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2016 Nissan Titan XD Crew Cab Pickup Truck (A66736)
2016 Nissan Titan...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2012 PROCO KILL TRAILER (A67714)
2012 PROCO KILL...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
