AHWI RT 400
/ AHWI RT 400 #1
AvramenRus
Moscow
AHWI RT 400,Raptor 300,Raptor 800
Hi.I apologize for grammatical errors.
I propose to discuss mulcher AHWI RT 400.Features of operation,breakdowns,fuel consumption...
Working on this machine in Russia.Now a tractor in Siberia in the city of Turtas.The temperature outside is -37.Feels great)) image-6fd3159916e4fb5a97c9a24ada345d3fbb46ecdbcc6a455473f7694a2038109c-V.jpgWebasto helps.Tractor almost did not stop,work day and night!
Have any questions please ask,how we work in Russia!
/ AHWI RT 400 #2
Howdy from Texas! Wow, all the way from Russia. I won't ask how the weather is.. I can see it in your picture.
What is it like working in Russia? I've always wanted to visit and see Red Square and the Trans-Siberian RR and the fields near Stalingrad. I imagine a lot of your trees are like the ones we have in the western parts of N. America.. big and tall.
Do you have Bobcat machines in Russia? How is your AHWI machine? Do you like it?
/ AHWI RT 400
Nothing special to work in Russia.Acclimating and freezing temperatures too.
Very beautiful in Siberia,there will not argue.Because the nature has no bad weather))
To repair the mulcher in forest using a tent with heat gun.
Live in cabins with wood-burning stove.As we work in shifts(day and night) the driver of the tanker is on duty in the kitchen and preparing meals into free time))There is no womans in the forest))
Moving through the woods only truck Ural 6X6.
In another way,it is possible to get stuck for 2 days...until help gets here!
Yes we have a Bobcat.Mainly working on the construction.In the forest they are not.
The first reason why AHWI is a metric connection all the bolts.The second is the availability of the service and spare parts(AHWI collect in Europe).Yes and for so many years in the forest AHWI has established itself as the AK.I like it!!!
You are welcome to visit and I will show you Russia NOT from the window of a 5 star hotel!!!Especially since I live near Moscow.
/ AHWI RT 400
Hi.
Video AHWI RT 400 works after logging complex on the basis of the excavator.Nordic method of logging,where forest residues Harvester folds under itself.
http://www.youtube.com/watch?v=PZW6fDJCXC8
I'm not touching the stumps.Them I will uproot and destroy using shredder Hammel VB 750.
http://www.youtube.com/watch?v=OMo6TzjO2lI
Why I don't destroy stumps by means of mulchers AHWI RT 400?The resulting wood chips from a shredder I'm in a rush to biofuel production.
/ AHWI RT 400 #6
You can稚 be Russia . Looks just like Canada where I mulch . We Use exactly the same machines . Bron , AHWI , Valtra , Fendt Seppi , Plaisance, Pro Heat ,Webasto . Exactly the same as you guys .
I subscribed to your channel https://youtu.be/BiZgunuOyPI Here is a video from mine .
/ AHWI RT 400
Hi Bill.I always respect these hard workers.
I had GT 25 and GT 13.I am a little not satisfied with their performance.IMHO.Probably because they were used)) from the States!
http://www.youtube.com/watch?v=rd8F_ZNUemc
All connections in inches(in Russia in metric),rubber tracks,GT 25 for oversized cargo transportation by road...and most importantly, spare parts need to wait for the ocean 2 to 6 months)))
Notice I said nothing about hydraulics)))But work only on PTO!
/ AHWI RT 400 #8
I prefer the PTO myself . We can get good deals on AHWI here now . I believe it has been purchased by Prinoth , a canadian company . I like the Raptor . King of mulchers . I also see that the 300 and 800 have high rear sprockets . This should solve the problem of plugged tracks breaking drives loose . I have had that problem with every steel tracked mulcher that I have ever owned .
/ AHWI RT 400
Sorry Bill,I don't understand what you mean.
My Mama told me-learn English))
Officially, AHWI call it Delta-Track System.
The Delta-Track System improves off-road
mobility particularly, when moving backwards.
Also stress for operator and machine decrease
significantly. For Jobs in swampy areas, different
width grouser shoes are an option.
If only the moderators have not given red card for(to) me)))
If you are interested,can create a topic about the Raptor 300 and Raptor 800 separately.
Or rename my theme to the theme of mulchers AHWI RT 200,RT 400,300 Raptor and the King of Mulchers Raptor 800.
Thanks!
/ AHWI RT 400 #10
If you are interested,can create a topic separately.
Thanks!
No red card. I am enjoying this topic.
New topics about the Raptor 300 and Raptor 800 would be interesting to see.
/ AHWI RT 400
Thank You Xfaxman .
With your permission start threads separately.
On pictiure is turboclutch from AHWI RT 400.
If you broke the seal on it in the woods at a temperature of - 27,do not worry-everything can be repaired))
/ AHWI RT 400 #12
Is this the pto turbo clutch housing ? Would like to adapt that to our fecon bh 120 on our valtra
/ AHWI RT 400
Marek,write me the model of your Valtra.And correct me if I'm wrong,but bh 120 hydraulic hitch(mulcher)?Will have to remake almost everything to install Turboclutch.I think you will be cheaper to buy a hitch(mulcher) with PTO,than to do bh 120.
At AHWI RT 400 Turboclutch is in the engine compartment,between engine and main module.That is placed on the tractor as in AHWI Raptor 300 and AHWI Raptor 800.
In your case,you will have to put two(2) Turboclutch in the cutter,one on each side!,gearbox,cardans,the bearing assemblies,and the hydraulic pump with motor for oil cooling in gearbox.
Will do, let me know,I'll help!
/ AHWI RT 400
Hi.Recently hung the cutter head from AHWI RT 400 with turbo clutch on Claas Xerion 3300 TRAC VC.I'm not a big fan of wheeled vehicles(tractors),but this monster made me happy))
AHWI M 700 the width of the rotor 2300 мм.
https://www.youtube.com/watch?v=3XyV6PE0DNk
Excellent work in agricultural fields to clear of shrubs.You are deepened into the ground or soil to 7 cm!
Cutter head AHWI 700-2300 M attached Plug and Play on any tractor with three-point CAT 3 or CAT 4.
/ AHWI RT 400
Unfortunately on RT 400 no reverse post(operator's seat).But working with rotovation is also very convenient: you have rear view camera and side mirrors.This is like to Park the truck in reverse))
AHWI RT 35 и RF 1 rotovator - YouTube
Rotovator RF 1000 deepened to 50 cm,depending on the level of side skis,which are regulated!
/ AHWI RT 400
Logistics -- when the Lena river is frozen,and the other way to get into the city Мирный (a city in Siberia,where the diamonds are mined),it is necessary to transport the mulcher AHWI RT 400 through Siberia!!!
Had the honor of "walking" winter road from Ust-Kut to Mirniy(18.01-22.01.2017) in Siberia on MAN TGS 33.480 6x6 with trailer from Politrans with 32 tons on Board.
I was accompanied by a Nooteboom which transported mulcher AHWI RT 400.It was a convoy of 7 trucks.
Night temperature fell to - 43,the day was comfortable...-28)))
The length of the route is 955 km.
The average consumption of 88 liters(MAN)
Total 4-ro nights(4 nights+4 days)
Impressions for the transfer of force majeure has not been:
-on the second night (about 01:30) stopped working heater(hair dryer ) cabin.Had to start the truck.
-on the 4th night exploded inner left wheel 1 axle trailer.Now there is an understanding in the difference frame of the trailer and lean-to!)
-to destination arrived with empty tanks(main+ызфку),because of a зкщидуь on the second night.
-saved Solaris
-saved KAMAZ.
Thank God we arrived without any accident,all crew alive!!!
In the next post I will tell you how warm up the mulcher if the temperature outside is -43!!!
Зимник Усть-Кут-Мирный 18.1-22.1.217 на MAN TGS 33 48 6x6 - YouTube
/ AHWI RT 400
Hello.
As promised, photos of the frozen tractor,mulcher AHWI RT 400.
Warm with gun for 4 hours.Change the diesel,diesel separator filter and started the tractor!Thats all,boring))
/ AHWI RT 400 #18
Thanks for the update. :thumbsup:
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
2014 Ford Escape 4WD SUV (A61574)
2014 Ford Escape...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
